Kevin Kenny
Everything posted by Kevin Kenny
  1. On another note i spent and hour or two reviewing the 3D files. I cant tell you how much i get from looking at these pictures. Looked at the bow deck hook and Eiking and made up a temporary mahogany piece. I struggled with the one on the lower deck. This was a breeze this time. Still made some mistakes but the approach was so much easier to understand with the 3D
  2. Hi Greg i use the Preac sander to sand the concave section. It does an excellent job once the convex curve is correct and has no bumps. I still take the big bumps on the concave side off with sandpaper and then pass in through the sander. It takes a little while to get the technique, but once you feed it correctly it works geat. The end of the wing transom knee was where the problem was. The upper edge was fine. Still cant believe i did not notice the rocking. Wow. Age is a bitch.
  3. Haha, life in the Tropics. Finally got some nice LEDs and a stand mounted at the back. Three more coats of rub on poly and back to work.
  4. It’s been a long day. Got the two inch Mahogany work bench top installed. Lots still to do.
  5. While i am waiting on the wood for the top of the work table, i have rearranged my two workshops, installed a vacuum system in the outside shop, threw out lots of stuff that i have not used in ages, rearranged the inside shop, moved the vacuum into a cupboard so its not so loud, moved the Byrnes and Preac to the old work bench, mounted the drill press on the old wine chiller. Wow, i now have space. Even Susan my wife seems happier.
  6. Trial fit. Not sure of the finial height yet. Currently at 33”, considering 34” as the finial height. I have a week to decide as will not get the Mahogany until next Saturday.
  7. It would be a shame to put this nice vice on my old work bench so I decided to build a new work bench, a job I put off for many years. Went to my friend and best joiner ever Richard Hadeed to discus the project and he gave me this old workbench that needed a lot of repairs but was exactly what I was considering building. I have repaired all the draws and am now waiting on a slab of 2” Mahogany for the top. It will be 44” by 20”.
  8. Santa was very generous this year. Lee Valley best of the best. unfortunate they will be sent to New York to be picked up some time next year. hope you were all as fortunate as i was. best to you snd your family. kevin
  9. Henry This build is in it self a teaching opportunity. My view of errors is that at this stage most of the mistakes will in fact be covered by later parts of the build, so unless it was a fatal error i would simply move on. I continue to make errors. If there is a lesson learnt it is that the flow of the work is almost more important than the actual measurements. I too made errors with the port notches and felt as disappointed with my errors, but once i realized that i planned to plank both sides, no one will know about the error except myself. So plung on, correct if you want or have to correct as you go. In fact that why i am building many of the internal pieces that no one will ever see. This is 101 ship building. what i have also found very use full is to follow some of the restorations that are found on YouTube. Tally Ho restoration by Sampson Boat co. With Leo Goolden is one of the best.
  10. Greg Two points. 1.should the deck planking be slightly thicker to cater for finial sanding. My planks never seem to have perfect thickness even though i put them through the Preac sander. 2. What clamps do you use to get nice tight joins between the floor planks. Using the blow drier worked well to get the shape locked in but they still needed some pressure. The best clamp that worked was the large tweezers.
  11. Completed. I take this opportunity to wish all of you and your families a very bless and happy Christmas. May we all have many successful modeling days in 2021. https://youtu.be/oysIf3QMBI0
  12. Just the last two deck strakes to install. Thank goodness the deck covers up my inaccurate carlins. This will not happen on the main deck. One of the main reasons for installing the full deck is to learn from my mistakes and make sure when i lay the main deck it will not have these errors in it. Experience is the best teacher. I have learned so much. This build is the best teaching course one could attend in model building. I am so appreciative of the time David and Greg put into this practicum.
  13. I am now using heat to curve the planks. Wish i had done so earlier. This means that it will be better on the next deck. The coffee wood turns out to be excellent for planking. The grain is so fine and when i heat it, it holds its shape well.
  14. Hi Greg the 3 D images have added so much to the build. Thanks for allowing me to use them in the videos. The aft hatch is centered so it must be an illusion. What i have found is that i need to run a line from bow to stern to get a correct centerline. I had established centerlines each time i installed a beam. These were not always accurate which mean when i installed the carlings a few were off center, as a result two of the hatches were also off center. I was able to recenter the hatches when i started the planking. I left the off center carlings as they would have been covered up in any case. Thank goodness for PVA and alchol.
  15. Used a hardwood template to start curving the aft floor planks. This worked pretty good. Next time i will use a temporary block in the center to place the first curved plank. Time solves every problem if you just give it a chance. painted the bitts red as in the 3D file. will be working on the model until the 18th then off to Tobago for 2 week holiday.
