Posts posted by David Lester
Breakage of the bulkhead extensions is a pretty common problem and can (and probably will) occur anytime until they are planked. Fortunately it isn't a difficult one to repair. Often the break will have a ragged edge in which case you can even glue the original piece back in place without any problem.
David
Hi Brian,
Thanks for your imput; very much appreciated. I'm quite interested in the micro saw and mitre box you mention. I have a very old (40+ years) xacto saw and mitre box, but they have seen much hard and inappropriate use over the years and are not functioning at their best. It looks like I could add these two new ones without breaking the bank.
David
Good Morning All,
Just a brief update. I've done quite a bit of backtracking, so no pictures util my next post. I added the four rear gun carriages on the port side and just to compare with the starboard side, I left the flemish coils off.
I now had some decisions to made and factors to take into consideration.
1. I was torn between which look I preferred.
2. My rigging on the second set of four was considerably cleaner than on my first set of four
3. If I decided on going without the coils, it would mean removing the first four which would leave quite a mess on the deck where the glue was.
4. I had been a bit sloppy and had two dabs of glue on the deck which I covered with some paint. It was passable but not really very nice.
5. If I was going to make any changes, it had to be now before I had any more details in place.
All of this was rolling around in my mind and it seemed to leave me with two options - either carry on as is and add coils to all of the lines and live with the two dabs of glue and so-so rigging on first four carriages or (shudder) remove the eight cannons, strip the finish off the entire deck, refinish it and then start over, being much more careful with the glue.
So, I set all that aside while I considered my options and built the mast top for the main mast which was quite an enjoyable diversion until I reached my decision. In the end I removed the carronades, masked the entire model from stem to stern and removed the finish on the deck with paint stripper. I've applied a new finish, which turned out to be better than the first one and I've now masked most of the deck to help ensure a tidier job as I reinstall the carronades. As for the coils, I'm going to install all of the guns without them and will decide whether or not to add them later.
I've have a couple of pictures in my next posting.
David
Hi Matt,
I believe the stem and stern pieces should be beveled, but not the keel. This is what I did on my model. Bevel them to about 1/8", leaving them full thickness (1/4") where they meet the keel. The bevel extends pretty much the full length of the stem piece and the leading edge of the stem piece is rounded over. The stern piece is beveled from the point near the top where it curves in slightly all the way to the bottom but the edges are left square. On both pieces just blend the bevel in where they meet the keel piece. Hope that's of some help.
David
Hi Matt,
I wouldn't worry too much about the bulkheads not matching the drawings perfectly. The main thing is their relationship to each other and that after fairing you have a good smooth contour. I paid no attention to the bevel lines on the plans and just glued the bulkheads in place on the keel and only then began to fair them, frequently holding a test strip of planking across them until I was satisfied with the contour. Something that is important is that they line up properly with the top of the keel and that they meet the bearding line. I think it's best to make them line up flush at the top first and do any fixing that's needed at the bottom. If one or more of them falls a bit short of the bearding line, which might happen, just glue a strip of wood along the edge of the bulkhead from about the middle point down and sand it into shape. I had to do that on a couple of mine. If one seems a bit too long, just sand it back. Similarly, as you're fairing and you hold a test planking strip along the side, if a bulkhead seems to cause a low spot, you can glue a strip to its edge and then sand it into shape. I think you'll find that approach will give you a satisfactory result and save some frustration trying to reconcile the parts and the plans.
David
Hi Matt,
I'm not really at the mast stage yet. I have been skipping around a little bit. I still have much to do on the deck and hull. While the sequence for the build is important in many areas, there are still many aspects that can be treated like separate projects, worked on for a while and set aside without interrupting the flow of the work. For example I started working on the four boats ages ago, but still don't have any of them finished yet. Also, I build the set of gun carriages long before they were needed. I think I'll complete one mast and then set it aside and return to the deck details. It's just nice to have something else to turn to when the mood strikes. Of course, by the time you're at the rigging stage, most alternative options are gone and it's just rigging until the end. I wouldn't worry too much about the rigging though. I generally don't find it very hard to do but there sure is a lot of it on this model and it can be finicky and requires lots of patience. The main knots you need are the clove hitch for the ratlines and a seizing knot (I think this is the same as the hangman's) for pretty much everything else.
I'm not brave enough to start making modifications to the kit, so I have left that sort of thing for others; I'm happy enough to get through the build as it is.
Using styrene for certain components would never have occurred to me, but I've been working with the Bob Hunt practicum and he suggests it in several places, so that's why I've been using it. I find that I really hate using it too, but have to admit that it does seem ideal for some of the ship's features - detailing on the stern and head rails primarily. I have also made a couple of other very small components from it, when they're going to be painted anyway and the basswood would be hard to cut cleanly in such small sizes. I was really doubtful that I'd have satisfactory results with it for the chafing fish, but I was actually pleasantly surprised. I think it's a matter of what's going to work best for you.
I am really not in a position to share "advice" with anyone as I'm fairly new to the hobby myself and there are many more qualified people out there. So please understand that I'm just sharing my experience which I'm happy to do if it's of some use.
David
Hi Matt,
Welcome to the forum and especially to the Constitution group! I've been working on mine for about 10 months. Parts of the model are challenging, but so far I've found it to be all doable and very enjoyable.
It looks like you're off to a good start; I'm looking forward to following along.
David
Hi All,
I'm still just barely started on deck and hull details, but nevertheless felt like a change of pace, so I started shaping the lower masts. I was curious to find out how well the styrene would work for the chafing fish. I find that styrene very unpleasant to work with generally and it seemed to me that the .03 sheet would be very resistance to bending around the masts. However I was pleasantly surprised to find that it worked like a charm and wasn't even too hard to do. The secret is to do it in stages and to hold it in place with large paper clips and leave it for a long time. I often make the mistake of thinking CA glue is instant, but for something like this it needs to set for quite a long time.
I first applied glue only to the lower narrow part of the piece and clamped it in place. Then to the centre only of the upper wider section. Then to one side of the wider section and finally the other side. That's four separate steps to the process and for the one mast it was actually five as I needed to give the extreme outer edge on one side another gluing and clamping.
I sanded the edges and once it's all painted it should be just fine.
As always, thanks for checking in.
David
- CaptainSteve, Elijah, mtaylor and 5 others
- 8
Thanks Dave,
When I was doing some google research on Flemish coils, most of the references I found were to modern sail boats rather than old war ships. It seems there is a school of thought that overuse of these coils can be considered "yachty" which is evidently a pejorative term. I don't know enough about sail boats to have an opinion one way or the other, but I guess to some I will have a very "yachty" Constitution!
David
- mtaylor, Elijah and CaptainSteve
- 3
Hi Geoff,
Thanks for your quick response. I will use the mast sizes directly off the plans too. I think what I'm seeing in the practicum is a small error, there are a few in this practicum. My dowels don't seem to be too bad, except for one, which is quite different than the others and is some kind of very coarse grained wood which I recall from my AVS and had to replace. It was almost impossible to shape and had huge rough grain. All of the others are very smooth grained, not sure if they're basswood or just what they are (look like maple, but I somehow doubt that.) They're very light in colour and seem ok to me.
Running rigging always seems to present me with a problem. I bought a lot of cotton line from Blue Jacket to replace the kit supplied, (I did that too for my AVS) and it seems to be quite good. The black presents no problem, but the white is very white. I dyed it for my AVS but was only somewhat happy with the colour and found the dying process a real pain in the neck and a bit of a crap shoot. I bought some crochet thread online this time which seems ok. I could find it in size 10, 20 and 30 which corresponds to much that's required. I can't find a conversion chart anywhere to know what sizes it actually is; I'm just going by eye. I think I need something a little smaller than 30, so have located a different supplier and ordered some size 80 which should be quite thin. I think those four sizes should cover it more or less. The colour is a sort of taupe-y shade which looks great on the spool, but seems a bit too light on my deck (gun rigging). It will probably be ok as the running rigging though. I'm nowhere near ready to get involved with rope walks and such at this point in my ship-building career. I might order some more crochet thread in a darker colour, but it's quite a nuisance ordering online, not knowing for sure what the colour will look like and having to wait for it. I wish I could just pop into a store and see the colours for myself.
Anyway, thanks again for your input, much appreciated.
David
Hi Geoff,
I'm enjoying your build log. I believe you have the LLS practicum as I do and I've been reading ahead in it a little bit. I have a question that maybe you've already come across as you're ahead of me in the build. It appears to me that Bob only addresses the mast measurements for the fore mast and skips over the main and mizzen and furthermore it appears to me that there's a discrepancy between his measurements for the fore mast and those in the plans. Specifically he says to measure up 4" from the top of the mast boot, whereas the plans say to measure up 4" from the deck (or bottom of the mast boot.) Did you find that to be the case, or am I misreading something. It appears that we must take the measurements for the main and mizzen from the plans and if that's the case then I'm inclined to take the measurements for the foremast directly from the plans too, rather than the practicum. I'm just curious as to how you handled this part of the build.
Thanks,
David
Thanks Skip, Now I'm fussing that the line is too white. It isn't actually white at all; it's a real taupe colour but it looks white against the deck. It seems I'm never happy unless I'm unhappy about something! I noticed in the picture you indicated (I can't imagine that there's a copyright problem with simply including a link) has quite light coloured rigging too.
Thanks again,
David
- CaptainSteve, Elijah, skipper1947 and 1 other
- 4
Good Moring All,
I have a brief update. I've pretty much finished preparing all of the components for the deck and have begun installing them. I'm working from the stern to the bow and completing all the elements for each area as I move along. I've eliminated some of the rigging on the carronades. There are supposed to be two sets of tackle on each side, but I'm just modeling one of them. The scale of the blocks seems too big to me and when I tried to include the shorter set of tackle I ended up with the two blocks sitting very close together or even touching. It just looked too crowded and messy to me, so I've stripped it back a bit and leaving it at one set of tackle plus the breech line. I'm not sure if coiling the ends of the rope on the deck is historically accurate or not, but I'm doing it anyway for two reasons - I like the look of it and it's not hard to do and it tends to draw the eye away from some of my less skillful detailing.
David
- usedtosail, WackoWolf, mrshanks and 10 others
- 13
Hi Skip, Thanks for checking in. It's the miracle of out of focus photography that makes my skylight look ok, but thanks for your comment nevertheless. The decking is painted - it's just basswood. In Bob's practicum he tries to approximate the way the decking looks today, which is quite dark, but I'm not sure if that's the way it was intended to look or if it's just the result of thousands of tourists walking on it. I suspect the latter. In some photographs of the actual ship you can see areas where it isn't worn and it appears to me to be more of a honey colour. Bob mixed brown and gray paint, applied it and then rubbed much of it off. The photos of his model match the current appearance of the decking quite closely. (I should say until recent appearance, as the Constitution is now in dry dock, having another restoration.) I was afraid to apply paint as that seemed to me like a heavy handed treatment, so I tried a number of times to stain it. I had every colour under the sun on it at one time or another and they all looked terrible. The basswood doesn't seem to take stain very nicely. I stripped each one of them off and then went the paint route. I mixed some orangey-brown paint I had kicking around with some medium gray, painted it on and rubbed most of it off. It actually worked quite well. If it isn't perfect, it's certainly better than anything else I had tried and isn't too bad a match for it's (until recently) current appearance.
David
- Elijah, skipper1947, CaptainSteve and 3 others
- 6
Thanks for the input guys. Mark, I was pretty sure this tackle was in place only when needed and Mike, I agree with you about the scale of the model. For these reasons I am going to leave it off. Depending on how many of my eyebolts vanish into the abyss that is my basement floor, I may install the eyebolts on the deck though. I've already added them to the carriages.
Thanks again,
David
- mrshanks, Elijah, CaptainSteve and 1 other
- 4
Hi Again,
Let's begin with the premise that "there is no such thing as a stupid question." With that in mind, I have a question (but it's possibly a stupid one even so.) What are people's thoughts on rigging the gun carriages with the train tackle (I believe it's called), the one that connects the back of the carriage to the deck? I notice some modelers include it and others don't. My inclination is to omit it, simply because there is so going on the deck as it is, it seems it might be adding too much clutter. On the other hand if it should be there then perhaps I should add it.
I realize that my question is naïve as I don't really have a clear understanding of how much of the equipment on a ship such as this was actually used. If I understood how and when this tackle was used I would be able to answer my own question. Was this tackle in place all the time, or was it removed and replaced depending on whether or not the guns were in use? If it wasn't a permanent fixture, then there's justification for modeling it either way. If it was a permanent fixture than there's a stronger case for including it.
Many thanks in advance for any input. Also, thanks for checking in and the likes.
David
- CaptainSteve, mtaylor and Elijah
- 3
Hi Tim,
Thanks for checking in. I just stuck the copper plates on and plan to leave them alone. I can live with whatever happens to them. I don't know if the copper tape I used has a finish or not but I'm thinking it doesn't, because when I opened the roll of tape, the first outer bit of the tape was tarnished and rest of it was bright and shiny. So I anticipate that the hull will darken down some and that's fine with me. I did take one precaution though. Through my reading I learned that the one roll of tape included in the kit was not likely to be enough to do the whole hull and several people found that when they finished the hull with the second roll, there was a noticeable colour difference. To avoid that I ordered a second roll well in advance of needing it and when I did the coppering, I worked from both rolls at the same time. So if it does change colour it should all change at the same rate. You definitely need the second roll. It might be possible to cover the whole hull with one roll, but you would need to not waste one single plate. That was not the situation in my case - I have quite a bit of copper bits stuck to my basement floor. I probably have the only coppered basement floor in all of Cobourg if not the county!
David
- CaptainSteve, Elijah and WackoWolf
- 3
Happy Wednesday Everyone,
Just a quick update today. It doesn't look like much progress, but for some reason it has taken a lot of time. I'm working away on the components for the deck, so I've been working off the model. I'm almost finished and ready to start attaching things. I've finished the gunport lids, made the pin rails, prepared all my cleats, made the skylight, binnacles, wheel, ammo scuttles and capstan and the carronades and cannons are all ready for rigging. I've just placed a few of these on the deck for the picture. None of them is actually installed yet.
Throughout the build, I am approached various jobs with fear and trepidation, only to find they weren't too bad after all. On the other hand from time to time something jumps up and catches me off guard. The latest in this category was the skylight. I found it to be one of the hardest parts to make yet. My final result is nothing to write home about, but it's about my sixth iteration, and it's as good as it's going to get. I tried forming the hexagon from individual pieces and I tried cutting it from a sold block. I tried using wood and I tried using styrene and most attempts ended in an amorphous blob covered with glue. I don't have any miniature machine tools; only hand tools. This final version is cut from a single piece of basswood with styrene trim and I can live with it, although the six sides and not exactly even. The trim on the upper portion is half round styrene and flat strips on the base. The bars on the windows are very fine brass rod. I wasn't sure what to use for the cap, so went searching through my basement and in my drawer of lamp parts I found a hollow brass ball which was on the end of a lamp's pull chain. I filed it down until only about half of it was left and popped it on top. The tops for the binnacles are the same. I tried using a couple of the brass beads from the lamp chain, but they were just a bit too big. This morning I went into a local jewelry making supply store we have in town and found these very small hollow brass beads which I was able to use in the same way by filing them in half. I only needed a couple, so the owner of the store just gave them to me - the advantages of small town living!
That's it for now; soon on to rigging the cannons.
David
Your wheels look amazing Tom,
David
- CaptainSteve and GLakie
- 2
Armed Virginia Sloop Patrick Henry by DocBlake - FINISHED - Lauck Street Shipyard - Scale = 1/32 - POF Admiralty Style
Hi Dave,
They look amazing.
David
