Everything posted by hornet
I am currently working on the Harriet Land from Model EXPO. Unfortunately the kit arrived without anchors, ship’s wheel and figurehead. I have sourced a ship’s wheel and anchors elsewhere but not a figurehead. I have tried contacting Model Expo without success. Could someone who has completed this model please photograph a close up of the figurehead and post it here. I am going to attempt to carve it myself thank you.
hornet replied to MintGum's topic in Modeling tools and Workshop Equipment
I have the chopper II. My only gripe with it is that on thicker stock (5mm+)the blade tends to distort resulting in an angled, rather than square cut. It’s great for deck planking. -
Recommended First Machine
hornet replied to vvvjames's topic in Modeling tools and Workshop Equipment
As the owner of 10 Proxxon tools, I’d go with the disk sander. -
I’m a retired Primary/Elementary school teacher. I have taught model making with students in the 11-12years age group. I used plastic models - a simple Spitfire model. Most were able to follow the instructions and complete the build with some support. I wouldn’t attempt a wooden ship model with this age group. My guess would be around 14 yrs old for this challenge.
Ship base display advice
hornet replied to mastic's topic in Painting, finishing and weathering products and techniques
Brass pedestals are available on EBay. I mount models on a base after the hull is complete. You can cut down the ‘slots’ on the pedestals to suit the width of the keel. I also use a router mounted in a home made stand to create the base. -
Mara thread - what colors do you use for fabricating ropes
hornet replied to Sterling59's topic in Masting, rigging and sails
I usually use black, brown, tan and sometimes grey. I tend to use cotton or linen rather than polyester. I usually pick up my threads an antique stores. (People collect cotton reels here in Australia.) -
Vanguard afficianadios...... Cutter Alert vs Brig Adder
hornet replied to bigcreekdad's topic in Wood ship model kits
I’ve just finished Adder. Very well made kit. Instructions and plans also very good. I would imagine Alert would be constructed in a very similar fashion but with less rigging. -
Dusting finished ships
hornet replied to bigcreekdad's topic in Painting, finishing and weathering products and techniques
I bought one of these canless Hurricane X3 rechargeable systems. It is designed to clean computer components but works equally as well on my models. -
I’m currently building the Vanguard Adder and am scratching my head as to why the ropes from the ships wheel are not linked to the tiller as I have seen in other builds. The ropes from the wheel go below deck and are,I assume, linked to the rudder by ropes and blocks/pulleys. Is the tiller there as a fail safe or am I missing something
Worst Planking Job Ever
hornet replied to rhephner's topic in Building, Framing, Planking and plating a ships hull and deck
Try to start tapering your planks from the bulkhead that starts to reduce in size( length measured with a tape measure - if that makes sense) you really should be tapering planks to around 50% of their width by the time they reach the bow. Also try not to twist or bend planks unnatural or against the grain. Best of luck, don’t give up. -
Vanguard MDF
hornet replied to hornet's topic in Building, Framing, Planking and plating a ships hull and deck
Hi Chris. Yes, I got your message. However, I was interested to know if other modellers were having the same problems or if it was just me being a klutz. -
Has anyone else had trouble with the MDF frame and bulkheads in Vanguard Models? I have found they are very brittle and easily broken. I wish they were ply like many of the others I have built.
Received partially-built Corel Victory -- worth salvaging?
hornet replied to SaltyScot's topic in Wood ship model kits
I built this kit many years ago. There is a great deal left to do and I don’t think you would come out the other end with a satisfied feeling. In my opinion you should put the rest of the kit into your store of spares and write off the hull. My Corel Victory pictured below. -
I recently completed the Endurance. I found a number of problems. The funnel was the incorrect shape. Belaying pins supplied were too big. Supplied rope was not always to scale, only two sizes of deadeyes when more sizes would have allowed for more accurate representation. Anchor chain also out of scale(links too small) Portholes on side of cabin were out of scale (too small) Propeller had 3 blades and should have only had two. Supplied flag incorrect. Should have been a blue ensign not a white ensign. I wouldn’t recommend this kit to you if you were keen on historical accuracy.
Having built the Corel version, I would say the dimensions don’t look quite right.
Might I suggest you invest in some planking screws. They make a fiddly job much easier. https://www.modelerscentral.com/modeling-tools/hand-tools/holding/planking-screws-p12/
Mine is made of a piece of poly pipe with 2 end caps. It has a four bladed sandpaper impeller. Fitted with a motor that is hooked up to a variable speed switch box.
Perhaps you could experiment with Model Aircraft Dope which is used to seal and tighten the ‘skin’ on model aircraft. I’ve not tried it but it may be worth a try.
