Everything posted by hornet
Hull filler.
hornet replied to bluenose2's topic in Building, Framing, Planking and plating a ships hull and deck
I have found that if you are careful about hull shaping as you apply the first layer of planking, packing out/ trimming planks as you go, there is very little need for filler of any sort. If you are concerned about small gaps you can make a wood dust & PVC paste to fill them. I you are concerned about planks drying out and cracks appearing you can use bandage gauze and PVC - a bit like fibreglassing on the inside of the hull. -
Anyone using electric plank bender?
hornet replied to MESSIS's topic in Modeling tools and Workshop Equipment
The beauty of the aeropiccola bender is the spring loaded roller attachment. It allows you much more control of the bend. I normally use mine while the handle is clamped in a vice. This allows me both hands to work the plank. You could do the same with this bender. -
These are the bees knee. Not sold any more. I have had one for over 30 years. If you can find one second hand, snap it up! -
Favorite Paint
hornet replied to Koa4225's topic in Painting, finishing and weathering products and techniques
Admiralty Paints for me. -
I hate making tree-nails
hornet replied to barkeater's topic in Building, Framing, Planking and plating a ships hull and deck
1 mm is easy with Byrnes draw plate but I have found that for a 1:64 scale model, 0.5 mm is more to scale. When drawing bamboo down to this size it I have found it does get tedious and fiddly. -
1:64 Copper plating
hornet replied to Peter Y.'s topic in Building, Framing, Planking and plating a ships hull and deck
Whichever plates you choose, I probably wouldn’t overlap them. I think it would be very difficult to get a neat and tidy finish. I’ve done 3 models using your option 1 - I bulk ordered the plates from Cornwall Models and they were a bit too expensive to bin. While not completely satisfied with the size of the rivets/dimples on the plates, I was happy with the overall effect. If I was choosing again, I would probably go something with much smaller rivets but I still wouldn’t overlap. Below is my current build - HMAT Bounty with option 1 plates attached.- 14 replies
- pickle
- caldercraft
Google ‘squadron precision glue applicator’ It is specifically designed for applying CA glue. I use it when attaching copper plates. Works very well.
I also only use diluted wood glue on rigging. CA glue fumes are also very toxic. Cause flu like symptoms. I only use CA when fixing copper plates. I put puddle on the bottom of an upturned glass jar and use a glue applicator (like a metal hook that holds a drop of CA) purchased from a hobby shop. I only use CA while working outside on a verandah in the open air.
I have about 10 proxxon tools. The drill press is one of my favourites. Check their website if you want to see it in action. Excellent quality product.
Black wire for eye bolts/rings
hornet replied to Johnnyreg's topic in Metal Work, Soldering and Metal Fittings
2mm cannon balls can be obtained on eBay. Type in 2mm steel ball bearings. I was able to blacken mine but you could paint with dull (metal) black from Admiralty Paints. -
bending planks
Ripping to 1mm and soaking, heating then bending should work. Maybe you could also score the rear of the planks at close intervals with a No 11 blade before attempting to bend. This has worked for me in the past. -
bending planks
I have found mahogany to be very brittle at the best of times. I’m not sure that soaking it for an extended period will make much difference. I suggest you rip it down to 0.5 mm and use it as a veneer over limewood or something similar. -
I forgot to say, don’t leave items in the solution for too long, I have found that the blackening tends to come off if you do. I don’t know why. Rinse in fresh water and leave to dry on absorbent paper. Soak again if necessary. Some people dilute the solution and get good results, I usually use it undiluted. Experiment and see what works for you. I have collected the medicine cups that come with cough mixture and use them for this job, as well as to mix and dilute paint. Always use tweezers to pick up your copper/brass items so as not to get the oil from your fingers on them.This will affect the quality of the blackening. Cheers Steve -
John I’ve never found a situation where there was enough pressure on the ring to open it. So, for me, silver solder in this situation is unnecessary. -
Hi dgreen. If you haven’t read the tutorial from this forum on planking, I suggest you do.There are a few good ideas there. I use a ‘plank bender’ after soaking planks for 15 - 20 minutes in warm water. You can also use your hobby knife to cut slightly into the rear of the planks at close intervals (about 1mm apart) This makes bending without breaking easier and is not visible from the front. It is still best to soak the planks and use a plank bender as well. I pin the damp, planks to the frames and filler blocks until they dry (overnight) and they usually retain their bend. Never try to glue down damp planks as they tend to shrink when dried and gaps between planks result. Hope this helps Steve http://modelshipworldforum.com/resources/Framing_and_Planking/Plank_Bending.pdf
- 6 replies
- sark constructo
- on cutty
- (and 2 more)
Yes, blackening solution will work on silver solder. You may have to apply more than once to get s good coverage. Just wondering why you need to silver solder your eye lots though? Seems like a bit of overkill to me -
Might I suggest when you use the blackening solution, you treat the wire BEFORE you make the eye bolts. Run the wire through some very fine emery paper then soak in white vinegar to remove any grease, such as the natural oil on your fingers, then follow the instructions on the blackening solution bottle to blacken your wire. Steve -
Occre diana 1/ 85 scale
hornet replied to Snow's topic in Painting, finishing and weathering products and techniques
Try Admiralty Acrylic Paints sold by Cornwall Model Boats. They make a yellow ochre which may be what you are looking for. -
Airbrush question
hornet replied to Antonio Vasquez's topic in Painting, finishing and weathering products and techniques
Yes, you will get some overspray. I solved the problem bu purchasing a small, portable spray booth from eBay. Cost around $100 au. As long as you vent it to the outside via the supplied flexible hose, you can spray inside to your hearts content. The booth folds up into a small ‘suitcase’ for easy storage. -
Adding to what Amateur has explained, the shrouds were also wrapped or ‘served’ in a smaller diameter tarred rope where they looped around the mast and for some distance below the cross tree. The forward shroud was actually served for its entire length. This was done to prevent wearing or chafing of the shrouds against each other or against other components of the rigging. You can buy a serving machine from the Syren Model Ship Company (manually operated) or from Domanoff Workshop (motorised) both are listed in the SPONSORS tabs on the right of the MSW Home page. I have the Domanoff version which works well. For this aspect of rigging and many others that are often not well explained in model ship instructions, I can thoroughly recommend the book Rigging Period Ship Models by Lennarth Petersson. It has many great illustrations and I refer to it constantly. See below the rather dusty pic of ‘served’ shrouds from one of my models. Cheers Steve
Having built a number of models myself, I know that every mistake I make, and don’t fix or replace, stand out to me (even though nobody else would notice). For that reason, if it were my model, I would sand and strip the affected area back and redo it. Put it down to experience and since you have not planked a Hull before, take advantage of the chance to practise and develop your planking skills. Take Druxey’s advice and always test your stain on a piece of the SAME timber next time. This way when you finally finish you will be much happier with your model than you would be if it is compromised by such a large boo boo.
Air Brush Paints
hornet replied to Worldway's topic in Painting, finishing and weathering products and techniques
Admiralty acrylic paints (see caldercraft website) are excellent quality, accurate colours and thinned with water to the consistency of milk. Have used them for a few years and am very impressed. Steve.
