hornet
Everything posted by hornet
  1. I’ve built two Caldercraft models and am on my third. They are quite good quality for the money and have a good range of models for different skill levels.
  2. I use my own home made rope walker. I scour antique stores for cotton and linen thread. Apparently old cotton reels are collectable. I’ve found that old thread is often better quality than modern thread.
  3. If making your own rope, haunting antique and collectable shops is worthwhile. Apparently the old cotton reels are now collectable. I’ve managed to gather quite a collection of linen and cotton threads in a range of colours and diameters that are much better quality than modern thread.
  4. I used Admiralty paints on my Bounty. Excellent. - French Blue - Red Ochre - Yellow Ochre http://www.jotika-ltd.com/Pages/1024768/PSA_Paint.htm
  5. Check out my build. Posted yesterday. Copper bottom.
  6. I have an older model of this machine. I improved it by adding another length of threaded rod to the front to hold a reel of thread. It makes the job a lot easier. I simply drilled and bent up two right angled brackets in Perspex then drilled a hole in the front (base) of each of the legs on the serving machine. I bolted on the the brackets then threaded the rod through holes drilled in the top of the brackets. I can change thread reels simply but undoing one of the nuts on the threaded rod and changing reels.
  7. I use 2 part epoxy designed for coating fishing rod guides. Mix together then add very small amount of enamel paint. Place oven bake paper under window frame and apply mix. When dry, peel off oven bake paper and you will get realistic looking glass - concave or convex shapes can be achieved depending on how you apply mix. I usually use a toothpick.
  8. I wouldn’t be without my cheap fly tying vice. Excellent for many jobs where a third hand is essential.
  9. If you do a google image search for the Byrnes draw plate you can see the step down between hole sizes used. This drawplate is brilliant. As to cutting bamboo cleanly, I use a pair of cutters with very, very sharp, fine jaws.
  10. this is my ropewalk. Works a treat. https://modelshipworld.com/topic/14464-inexpensive-powered-rope-walker/?tab=comments#comment-449106
  11. I have spent quite a lot of time haunting antique shops. I have collected a lot of old cotton and linen thread - people actually collect cotton reels - which is (in my opinion) often better quality that the tread produced now. I calculate diameter then make up appropriate diameter ropes using various numbers of threads on my home made rope walker. It is now one of my favourite model related pastimes.
  12. I use a length of polypipe with endcaps cut into a trough and mounted on a wooden base. A tap on the end allow most of the water to be drained when finished
  13. Gday Mate, the rope walker in your pic is the one I built quite a while ago. I have made many great looking ropes with it since and it is now one of my favourite aspects of the hobby. In answer to your question, I didn’t put a motor at the other end of the Walker, but after I make a length of rope on the walker, I have found that attaching a cheap battery powered screwdriver on a low speed setting to the rear of the bolt on the trolly to which my rope strands are tied and giving it 50 - 100 rotations tightens up the rope even more. The rope still needs to be under pressure i.e the lead weight is still attached to the trolly. After removing the rope from the Walker I always run it backwards and forwards over a curved , hard surface to ‘harden’ it. The pic attached is my trolly with the screwdriver sitting on the bolt which goes through a bearing to a ring onto which I tie my threads - it is not set up to make any rope - just a demo pic so you can see what I mean. Hope this helps. Steve (hornet)
  14. My Caldercraft Bounty - nearing completion appears to be very close to the 428mm
  15. Larry Leno cogs are marked z24. Diameter 25mm. Wheels (pulleys) on trolly are marked 1-05. 30mm diameter.
  16. I hold this size block in a fly tying vice, ream the hole out slightly with a very fine drill bit then use a doubled over very fine piece of copper wire taken from the core of a piece of electrical wire. BTW an upturned glass jar (with concave base) makes a good receptacle for a few drops of CA glue.
  17. Thin brass rod from 1mm and upward in diameter is available on EBay. I’ve found it to be useful for a variety of applications. Usually comes in a pack of 5 & lengths of 300mm
  18. Building the PVC tumbler was a bit of work Y.T. but it was a fun project and gave me a sense of achievement (not dissimilar to building a model). I have to agree with Mark though, the inflexible blades on a food mixer may be a little harsh for the job. You might like to consider making a whole new sandpaper ‘impeller’ to replace the blades on the spline completely or cut the blades off the attachment and replace with something more flexible. Post your endeavours as I would be interested to see the results.
  19. I use the variable speed control from my Domanoff serving machine ( which I also use on my home made rope making machine) I experimented with different grit sandpaper in the tumbler and ended up deciding on 180 grit. I tumble them for a couple of minutes but because I use the variable speed control the number of revolutions in the tumbler depends (obviously) on the motor speed - not too fast, not too slow. I check the blocks as I go. Another pic of tumbler and some tumbled blocks below.
  20. Just spent the day putting together a block tumbler using PVC pipe and end caps. Had to cut the end caps down a bit but it works well. The whole thing comes apart by taking one nylex nut from the end of the shaft. Bearings were obtained very cheaply on EBay. Added a small 12 volt motor and now I can tumble a handful of blocks very quickly. Cheers Steve.
  21. I’d probably add a keel clamp of some sort to your list. Check out the thread above for one that I made cheaply and have used on 10 builds.
  22. I have recessed a set of these into a piece of timber. Covers most sizes of dowel I use. Push dowel into recess, centre marked, job done. https://www.ebay.com.au/itm/8Pcs-Dowel-Drill-Centre-Points-Pin-Wood-6mm-8mm-10mm-12mm-Dowel-Tenon-Center-Set-/351989788914
  23. Lots of great ideas here.
  24. I have found that if you are careful about hull shaping as you apply the first layer of planking, packing out/ trimming planks as you go, there is very little need for filler of any sort. If you are concerned about small gaps you can make a wood dust & PVC paste to fill them. I you are concerned about planks drying out and cracks appearing you can use bandage gauze and PVC - a bit like fibreglassing on the inside of the hull.
  25. The beauty of the aeropiccola bender is the spring loaded roller attachment. It allows you much more control of the bend. I normally use mine while the handle is clamped in a vice. This allows me both hands to work the plank. You could do the same with this bender.
