Everything posted by hornet
Hi Rick. You say that you 'shaved' your deck area down suit the transom. That is what I am suggesting too That is how I would describe what is done on the video. The ply deck and the ply support underneath is faired (shaved) to meet smoothly with the transom. The edge of the transom is also faired so as to allow for a smooth run of planks. I have taken a photo of the transom of my Mermaid. See below. Cheers Steve
Hi Cabbie. It's been a while since I finished my Mermaid so I went back and had a look at the video on the ship's construction that I bought from Modeller's Shipyard to remind me what I did with this problem. In the video the deck is faired back to the transom. I took a photo of my tv screen on pause at this point in the video. See it below. Hope this helps. Steve
The paint that is sold by Caldercraft/Jokita is Admiralty Paint. It is acrylic and has very good coverage. The colours are supposedly accurate for 18th century ships. The yellow ochre is NOT bright yellow. I would best describe it as mustard. I have painted some on a slip of paper below. Total accuracy online is difficult to achieve because it very much depends on the screen you are viewing, but you get the idea. I have used it on my Caldercraft 'Supply' if you want to check it out, go to my gallery link below. Cheers Steve
Inexpensive powered rope walker
hornet replied to hornet's topic in Modeling tools and Workshop Equipment
Thanks Mark. Post some pics when you've build yours. Cheers Steve -
Nah Brian, I'll leave the commercial side of things to others who are much more qualified than I. I've got lots of great ideas from this site so I'm just sharing an idea that may spark others to create something similar - or better - for their own use. Cheers Steve. -
Ha Ha Brian. Building one was enough. Cheers Steve -
While completing my previous build, I was very unhappy with the anchor ropes supplied because they were completely out of scale. After some research I decided to build my own rope walker. It only cost me about $50 AU to make. The main cost was the motor and coupling. Perspex I had left over from another job and the variable speed/on off attachment from my Domanoff Serving Machine proved most useful. Mini bearings were very cheaply sourced from eBay. I have labelled each picture in an attempt to show how it was constructed. I intend to make as many ropes as possible for my current build - Caldercraft's Bounty when the time comes. Hope somebody gets some ideas from this post. Cheers Steve
In Praise Of Lacquer
hornet replied to Julie Mo's topic in Painting, finishing and weathering products and techniques
Julie Mo Yep you are probably correct for modern boats such as those you have pictured. However, for period models (which take up a large portion of this site) gloss is not appropriate. I think that is what Jaager was trying to say anyway. I usually apply matte or satin polyurethane 50:50 with low odour turps using an airbrush. I apply 3 - 4 coats to the hull sanding very lightly between coats. Cheers Steve. -
Agree with Jaager, matte or satin finish. Never gloss -
Transform a brass chain into iron chain
hornet replied to MESSIS's topic in Metal Work, Soldering and Metal Fittings
There are some good suggestions on using Birchwood casey on this thread. I love the stuff Cheers Steve. http://modelshipworld.com/index.php/topic/9781-blackening-brass-problem/?hl=%2Bbirchwood+%2Bcasey#entry289798 -
Steam Bending
hornet replied to Julie Mo's topic in Building, Framing, Planking and plating a ships hull and deck
I use a plank bending tool. It heats up like a soldering iron. I have had it for over 30 years. It came from aeropiccola - not in business any more. -
Red Paint or Red Ochre
hornet replied to davyboy's topic in Painting, finishing and weathering products and techniques
We've got a bit of red ochre down under as well. It is commonly known as Central Australia I took a pic of a sample on a recent trip. The rock in the background is quite well known. -
Steam Bending
I built something similar to what Bluenose2 describes. It works well. I ended up putting a tap in one end for easy draining because the Admiral got somewhat sick of me spilling water all over the floor. Cheers Steve -
soldering iron or torch? advice please
hornet replied to Mark Pearse's topic in Metal Work, Soldering and Metal Fittings
Mark I have done similar jobs using silver solder. You can purchase what you need - including a micro torch - from Jaycar. Cheers Steve. -
Get yourself a cheap fly tying vice - used to make flies for fishing. There are plenty of cheap ones available on eBay. I use mine extensively when rigging. Steve
I am currently building the Caldercraft version. I'm happy with the quality except for the walnut planks included or the second layer of planking. I've built the Caldercraft Supply and have the Caldercraft Endeavour on the shelf. This is an ongoing issue with Caldercraft. I wish they would look at improving the quality of this timber. The only consolation is that they provide plenty of planks. Plans are OK but I am using the the A.O.T.S - Bounty - as well. I will also probably scratch build many of the fittings. Steve
This clip should help you. It's the method I use too. https://m.youtube.com/watch?autoplay=1&v=WUrRb66VSSE Steve
Building scratch deck furniture is my favourite part of a build but I do enjoy rigging. I have just built my own motorised rope walker and will be making my own ropes for my current build - The Bounty - when the time comes. This should make rigging even more satisfying.
That is exactly what they are Richard. They can be cut to size for different sized grates then framed all around with some timber the same height. I found that the easiest way to make them was to dry fit them together them drop the grate into a bath of thinned down wood glue. Let them soak for a few seconds then allow to dry on greased or oven bake paper (so they don't stick)
- 396 replies
- Idea
- Bright Idea
Terry Below is a pic of the stern of the Powerhouse Museum Model as well as the stern of my Supply (My Supply on top). I used a piece of black card and glued the timber frame of the windows to it - then glued the windows to the stern. The `glass' was in fact a 2 part clear epoxy which is used to cover/protect the 'whipping' on fishing rod guides (I also build my own fishing rods) but I suppose you could use clear plastic for this.
