wernerweiss
Members-
Everything posted by wernerweiss
Hello Ian, you' re on the right way, the plan is quite simple....."just" fill and sand and fill and sand and....until the hull looks like made of plastic without the slightest indication of planks.... My way was as follows: when I was content with filling and sanding, I gave the hull a coat of parquet lacquer. When it was dry, I polished the hull with a polishing disc on a drilling machine Regards Werner
Hello Ian, The sheer from the center towards the bow is right and there should be a sheer toward the stern as well, but this is not as distinctive as the sheer forward. I would say there is no problem if you build a flat deck in the aft section. I suggest to have a look on the models of Peter Beisheim or Rüdiger Eschker for example....
Hello Ian B, targa4403, I built this model a few years ago, you will find pictures of it in the gallery. Enjoy your build, Regards Werner
Hello Nate, as one of many builders of the Confederacy kit from Model shipways I look forward to follow your build of the 3D model. Best regards Werner
- 107 replies
- Frigate
- Confederacy
Hello Harshil, I agree that the window frames provided with the kit are not of the best quality, and I see that scratch-building them ist not at all a problem for you.... I accepted the provided frames as they fitted perfectly into the openings. What I did was to order another set of frames (thanks Model shipways) to double the frames of each stern and gallery light with the acetate inbetween. As you may see in the pictures showing the openings for the stern lights I glued a 0.5 x 0.5 mm stripe on the bottom and top edge (not visible) as a rabbet for the inner frames. They were glued first, then the acetate and last the outer frames. In other build logs of various models I saw pictures where the builder depicted the window glass with micro crystal clear, and I preferred the acetate..... Regards Werner
- 60 replies
- Confederacy
- Model Shipways
Hello Chuck, thank you very much for your personal appreciation! I would never have thought so far when beginning with the build...... Best regards Werner
- 60 replies
- Confederacy
- Model Shipways
@all, thank you very much for your comments and your likes!
- 60 replies
- Confederacy
- Model Shipways
Hello modelers, with this post I continue the gallery with the latest pictures, but first some remarks: Even if you build very carefully, for example the bow curve of the finished hull may differ from that of the prototype. Due to the bow curve of my model I had to make the shown adjustments with the cheeks to fit on the bow curve. The laser cut cheeks turned out to be too straight, so I hat to reshape them with a rounder curve to fit to the hull. Regrettably the cast trailboards were not inversely equal. The starboard trailboard was a bit longer, thicker and wider than the port one. This is not what I would call high quality. My next step will be the installation of the main head rails. Between them runs the so-called head beam, and sheet one shows two knees connecting this beam to the main head rails. These knees are not mentioned in the instructions, so I have to decide whether to omit them or not. At the end of chapter 15 on page 134 it is suggested that the catheads are glued in place. I would suggest not to do so at this time. In the next chapter the main head rails are installed and for that purpose an appropriate angle has to be sanded at the corners of the beakhead bulkhead showing towards the stem. This is much easier without the catheads as an obstacle for the sanding tool. See yourself, questions and remarks welcome.
- 60 replies
- Confederacy
- Model Shipways
Hello Harshil, Congratulations on this progress, excellent work as always! Yes, you have to be very careful not to spoil the great cabin' s deck with its pattern.....but so it is with the much bigger area of the gun deck, the basswood is very soft and does not forgive tools falling on it, but, as modelers we ARE careful.. I am going to update my Confederacy build log soon showing the progress of the forecastle deck and the bow stem Greetings Werner
A beading tool is in principle a nail with a grip......see Google
- 488 replies
- Indefatigable
- Vanguard Models
Hello Harshil, once again, very clean work! Yes, one has to be very careful once the cabin floor is finished, and later on there are two cannons and possibly furniture to be positioned and glued..... Did you print the pattern directly on the card? I printed it on self-adhesive paper (is this what you mean with label paper?) Werner
Hello Harshil, wonderful work with an amazing result - highly recommended for imitation! With this attention to detail I look forward to your finished model! I must admit that I was too lazy to paint the bricks in different shades..... It is a pity that most of the brick surface is later on covered by the stove.
Hello Harshil, regarding the gluing of the hatch coamings and the brick platform on the false deck I would highly recommend not to follow the instructions and plank the gun deck first. This makes it much easier to sand the gun deck all over its length because then there are no obstacles for your sanding tool....but maybe you already thought about it.
Hello Harshil, again, very clean woodwork...did you use the provided basswood or another kind of wood, e.g. beech? I cast the "bricks" with moulding cement and cut/sanded it to shape to fit in the wooden frame. Then I painted it red to resemble "brick". Afterwards I painted it all over with grey (not too thick) to fill the grooves and immediately dabbed the grey paint off the "brick" surfaces leaving a rest of grey paint....I think this method should also work on your wooden "bricks" (As the height of the cast didn´t match the height of the frame, I glued the cast on a piece of thick card) Werner
Hello Harshil, some remarks on the brick platform for the stove. In the building instructions it is made of provided wood strips which are grooved, glued together and painted to resemble bricks.....I didn´t like that at all and looked for an alternative. I found a silicone casting mould for brick walls for rail modelling. The "bricks" cover an area of 72 x 49 mm and imo meet the size, so I made a cast and was content with the result. The rest was cutting to length and width, painting red and "washing" with grey.....
