bigcreekdad
Everything posted by bigcreekdad
  1. Then Woodcraft is selling mislabeled stuff. BTW....I've added a few pics of my previous 2 builds. 1) Occre's Dos Amigos with cherry I milled, 2) Vanguard's HMS Speedy with kit supplied pear.
  2. Sorry I didn't mention this up front. The ship is Jotika's HMS Brig Supply.
  3. Rich...I appreciate your thoughts. How big are those files....they look huge, but maybe just the close up effect. Actually, I was pretty much going to send this to the dry dock of the dead. I was going to revisit my scratch Cutter Cheerful build. I had set it aside when I got to needing a drop plank. For some reason it baffled me. Up to that point my planking of the ship was quite good (IMO). The thought of screwing it up was a huge block. I hope to finish the Cheerful while I'm still on the grassy upside, but might try your suggestions and see if I can get (reasonably) back on track. I do like the ship itself.
  4. Actually...this was a rhetorical question. Sorry for confusion, but I am half way through second planking and already see that , when finished, I still had a bit (maybe a lot) of work to go on the hull. I've attached some pics which will speak for themselves. Honestly, I am not at all happy with my effort. See the pics I've attached. I've built two very nice (IMO) ships with very nice planking results. And the Supply is my second ship milling my own planks with a Byrnes saw and thickness sander that have turned out quite well (again..IMO). I'm not sure how I have lost my edge, other than if I was to start over, I would mill the strips (cherry) a bit thinner. In any case, I am at a crossroads......continue on or shitcan it and try to do a better job on another. I'm in my mid 70's so I don't have may ships in the wings, and I hate slugging along on this one not at all liking my results. I was not planning on painting....I know that's an option I would have to hide my mediocre planking. I'm rambling
  5. Second planking, while done, needs a lot of sanding and finishing. Assuming you are not painting your hull, what do you use to fine up the hull?
  6. Fantastic build!! Can't wait to see your next one. Have you given any thought to what it might be? Hopefully, this will not be a solo venture. You have too much talent. I, too, hate walnut, and have been using cherry on my last few builds. That would you use in your next build if you could choose? Have fun!
  7. Into second planking on the HMS Brig Supply. Never been a big fan of walnut, so I've cutting my own planks from a light cherry piece. Before I go further, I need to decide whether I will continue with cherry, or go below the wales with something darker for some contrast. Likely will not be painting the lower hull. Any thoughts?
  8. Where to buy the larger toothed blades? What great advice on this board!
  9. Had the washers correctly placed. What a difference! Getting a little light burning, but I need to clean the table up. Also, ordered that device recommended above from NRG. That's all for the great advice!
  10. I feel stupid, but I have a large washer on either side. Is that what you mean? And how do you know if they are set correctly?
  11. NO IDEA........I am exposing my limited knowledge......Can you explain the "arbors" thing?
  12. What am I doing wrong? Haven't milled strips in a couple years. Also, I changed blades and am not sure I've got the washers on either side placed properly. Any help there?
  13. Lovely build! I built this about 10 years ago. One of my favorites. Sadly, I gave it to my son and a buddy of his knocked it off a shelf. It's now in a bag waiting for me to fix, but I just haven't gotten the urge to do it.
  14. What you all say is quite helpful....thanks!
  15. I have never used them for hull planking. However, they seem to be included by the hundreds in most kits. I also see a few builds here that included their use. I must admit, using clamps and such to hold planks in place til the glue dries is a pain in the elbow. Thoughts?
  16. I know it's primarily for underplanking, but I find it a pain to try to bend...both ways. And it breaks easily IMO. Maybe if they made it thinner. Thoughts from others?
  17. I had the one that has two clamps that slide along horizontally. Worked fine until I lost a clamp (seems like it should be designed to prevent clamps from sliding off...oh well). I inquired from place I I bought it from about a replacement clamp with no response. In any case, what are you using? Also, is anyone using a regular table vise rigged with something to hold more than a couple inches of keel?
