CDR_Ret
Everything posted by CDR_Ret
  1. Here is my reconstruction of the Galilee's capstan, based on the DTM photo of the upper 2/3 of the actual capstan, with reference to a 1915 Hyde Windlass Company catalog and a random photo of another similar capstan I found on a photo sharing site. While Sketchup can support creating such models, there is a lot of fiddly mesh editing that is required, involving many hundreds (thousands?) of faces and edges. To minimize this cleanup, I created a clean version of a one-sixth sector of the capstan, then did a rotational copy five times to duplicate the sector, resulting in a complete model. The next step will be to marry the capstan to the windlass, then place them in context with the decks and structural members as they would have been on the ship itself. This will help me work out the details for framing in the vicinity of this machinery. Terry
  2. I finally finished drafting up my reconstruction of a Hyde windlass that could have been installed in Galilee. It uses components from Hyde and windlasses found in ships contemporary with Galilee that served on the West Coast of the USA. Since the prototypes were found on ships larger than Galilee, I will likely have to scale this down to a size that will fit in her forecastle. I am hoping to develop a model of her capstan, then show the combined capstan/windlass machinery as it might have been installed in the ship, with appropriate timbers and decking. Oh yeah, and that band brake operator contains a true 2-inch trapezoidal ACME thread developed from ANSI references. Quite fun to make! So far, most of the major components have been separately built in Sketchup Make 2017, and are manifold, which means they could be 3D printed if desired. Terry
  3. You are correct, Druxey . Never heard of the play Paul Pry I wonder if that is where the phrase "prying into someone else's business" came from?
  4. Update on my reconstruction of Galilee's capstan. I am three weeks out from a repair of a 25-year-old hernia repair, so I've been recuperating rather than sitting at a computer... (for you older guys, my surgeon informed me that redos of inguinal hernia repairs in men are quite common. The joys of aging!) These images show progress and corrections from the previous post. I have most of the key components modeled in Sketchup Make 2017. The only things left for the windlass are the controls (ratchet pawl, wildcat band brakes, and capstan clutch lever). I realized after the fact that the double pawl wheel shown previously was applicable to the lever-style capstan I was using as a reference. It has been replaced with just the windlass pawl ratchet wheel. Please feel free to ask any questions. Terry
  5. Note that Sketchup's default image import resolution is pretty low. To maximize the line sharpness of imported images, which is essential for tracing plan lines, do the following (applicable to Windows systems): 1. Navigate to Sketchup Preferences. (Window|Preferences) 2. Select OpenGL 3. Check Use maximum texture size. 4. Click OK. I included a screenshot of a windlass plan in the default and max resolutions so you can see the difference. These are rendered using a high-end graphics processor, so you can see that it is Sketchup that is affecting the appearance. Large images at maximum texture sizes will slow down the editing process without a good graphics card. See the Warning screenshot.
  6. Here is the current status on reconstructing Galilee's windlass using the resources I have available. The diagram is constructed in Sketchup Make 2017 using the basic tool set. This part is probably the hardest to create, with all the curved surfaces in the wildcats and the crown gear. All that remains is creating the operating gear and the mounts to the ship's frames. I suspect that the windlass was mounted to the deck structural timbers, similar to the Lucerne and Thayer, rather than having a separate metal foundation like the Balclutha. I'm hoping that this will be 3D-printable, but the level of detail at the anticipated scale of the model will probably be lost or not printable. Terry
  7. Thanks Roger—good call. Sadly, the Thayer's windlass is actuated by a rocker-type mechanism. It has a standard capstan forward on the forecastle, but there isn't any indication it is linked to the windlass. However, it is a Hyde windlass, so I should probably be able to pattern the wildcats and related hardware based on these drawings. It seems this type of windlass was bolted to a pair of bitts. However, Galilee had only one large bollard samson post located centerline and forward of the capstan. Evidently, the windlass supports were incorporated into the forecastle deck framing.
  8. Took a few hours today to do a detailed search of the Web on this topic. The only things I came up with were the following. Balclutha, which is one of the premier museum vessels held by the San Francisco Maritime National Historical Park, is extremely well documented through the National Park Service HAER program. Several of the scale drawings in that program include diagrams of the anchor windlass, which is shown below. Though the Balclutha is much larger than Galilee, she is almost contemporary to the brigantine. The following diagram shows Balclutha's hand-powered anchor windlass. The photo below that I found on Pinterest of capstan/windlass of the sunken Lucerne (check out the Wikipedia article) is probably more similar to the one Galilee carried. Since there doesn't seem to be any contemporary diagrams available of a Hyde windlass, I'll have to approximate one when developing the ship's plans.
  9. Bill, thank you for the link to that HWC catalog. It is my impression that, by 1917, Hyde had dropped their manual/hand-operated windlasses for all sorts of powered types, which are described in the catalog. During the transition period (probably around the time this ship was built), steam windlasses still had a capstan for motive power when steam wasn't available for some reason. That is why the capstan is geared into the windlass from a point above the unit, as shown in the brass model I posted above. Still, the book is an excellent reference, which I will definitely save. Roger, any windlass originally designed for operation by steam won't work for my purposes. Galilee was one of the last of the sail-only brigantines built on the West Coast for merchant service. She originally had a small steam donkey engine amidships for handling cargo and boats, but that was removed during the time my grandfather sailed in her. The crew operated the capstan/windlass by the traditional means—capstan bars and hard work! I'm pretty sure the windlass was operated from the capstan above. As the photo below shows, there was no room for the crew to operate the machinery for raising and lowering the anchors between decks. [Looking forward toward the forecastle on starboard side during heavy weather.] Photo courtesy of the Department of Terrestrial Magnetism, Carnegie Institution, Washington DC. Thanks again for your responses and interest. Terry
  10. Hello, All. I've been searching for any plans/photos/schematics of a Hyde Windlass Company (HWC) hand capstan and windlass assembly. This would be sized for a 350-ton sailing merchant around 1890. The brigantine Galilee was launched in 1891 in California and seems to have been equipped with a Hyde capstan (see the photo below). Photo courtesy of the Department of Terrestrial Magnetism, Carnegie Institution, Washington DC (c. 1907) (The attire of the men is somewhat strange. The research crew's surgeon is on the right and his steward/surgical assistant is dressed for surgery.) What I really need is some information about the windlass, which was located in the open forecastle under the deck. I would like to render this equipment as accurately as possible, since it will be visible in the finished model. An entire windlass/capstan assembly has been modeled; its images are available on the Web. However, all that i have been able to find are steam windlasses, like the one shown here. Galilee's windlass was strictly manual. I have already contacted the Maine Maritime Museum in Bath, ME. They have some extensive archives pertaining to the HWC (which became the Bath Iron Works Shipyard), but their staff is limited and they haven't been able to find what I need so far. If any members live in or near Bath and would like to look into this, I would be very grateful. Terry
  11. Floyd (fnkershner), I would be happy to provide some Sketchup coaching for your project at no charge. I am a retired professional educator and enjoy helping people learn new things. What you want to do utilizes just basic functions of Sketchup. Solid objects created in Sketchup are inherently manifold and 3D-printable unless you break the envelope or introduce extra geometry in an uncontrolled fashion. Please PM me with your email address if you are interested. Terry Colorado Springs, CO
  12. Here is a quick-and-dirty build of Galilee's hull I did in Sketchup a number of years ago using an old set of plans I developed back in 2002. Just wanted to see how it would work to display hull form. Unlike parametric 3D programs and for-the-purpose naval architectural software (e.g., DELFTShip), the result shows distinct polygons when you display hidden lines. It is also a lot of work creating the intersections at stations and waterlines. Terry
  13. Here is the instructional PDF for creating sockets in 3D objects. Please let me know if there is anything that is unclear, and I will try to explain it. A real power-user of Sketchup may be able to come up with a quicker method. I've been using Sketchup almost as long as it has been around, and I'm afraid I've become entrenched with some habits picked up years ago. Terry Creating the Hub of a Ship's Wheel.pdf
  14. Sailor1–0, How familiar are you with the Intersection feature of Sketchup? You might want to try creating models of the wheel hub and spokes, individually grouping each element and arranging them as in the final object. (Save a copy of a spoke for later.) Then explode the hub and intersect the spokes with it to define the spoke cutouts in the hub. Regroup the hub, then explode the spokes. Intersect the hub with the spokes to define the spoke socket walls inside the hub. Delete all of the spoke components except for the parts that lie inside the hub. Explode the hub and delete the surface areas inside the spoke sockets. If the work is done carefully, the hub now is solid volume with the spoke sockets arranged where they need to be. If needed, recreate the spokes from the copy and insert them into the hub. The process is somewhat complicated but straightforward. I can provide a PDF with images of the key steps if that will help visualize the process. Terry
  15. Status update:
    Finished house renovations—check
    Sold house in Greenville, SC for nice profit—check
    Loaded 26-foot Uhaul truck and drove 1500 miles to Colorado Springs, Colorado—check
    Moved into a 1-bedroom apartment; temporarily stowed the rest of our stuff in two storage rooms—check
    Sadly, there is no shop and all my tools are packed away. Will try to get back into working on my Galilee plans soon.
    1. CDR_Ret
      CDR_Ret
      Update:
      Bought a quaint two-story house in Colorado Springs, Colorado, USA with a 400-square foot (~37 m²) garage. The down side is that the garage has only one outlet and one light bulb (and a lot of remaining boxes).
      As we get the painting and other move-in repairs accomplished, I will be taking time to rewire the garage so that I can actually do some work in it.
  16. Thanks for the comments, guys. At the time the photos in post #1 were taken, the vessel's charter did not include entry into icebound waters, so no protection against ice floes was needed. The photos themselves don't show enough details of the hull covering to draw any firm conclusions. However, the photo of the Pitcairn in #8 shows the distinctive rectangular blotchy appearance associated with copper plating. The plates themselves are of about the same vertical dimensions as the linear marks in the #1 photos, so I am going copper plates. The darkness of the hull in the old B&W photos is likely due to the color response of the film in use at that time, which wasn't sensitive to the red end of the spectrum.
  17. Jud, Setting your vessel's length to the overall dimensions is a good way to avoid negative axial coordinates. My drawings of Galilee were all dimensioned starting with the aft perpendicular, so, to avoid remeasuring all the stations, I just went with negative X values at the transom. The program can handle them. It's a computer after all. Terry.
  18. Here is a post I made a while back on getting started in DelfShip Free. These instructions were based on the program several versions ago, so some of them may be out of date. My biggest complaint to the company was that they don't clearly define the terms they used in their manual. An abbreviated DelftShip Offset Table glossary: X-coordinate—[Edited] distance forward from aft perpendicular. 0.0000 is the AP. Negative values are aft of the AP. [sorry about that. It's been over a year since I used the program. See the image from the DS manual below.] Y-coordinate—distance athwartships from the model centerline. 0.0000 is the centerline. Negative values appear on opposite side of the centerline from "face" of the hull. Z-coordinate—distance above the model baseline. For practical purposes, this should be at the height of the rabbet line for wooden ships. Making the baseline at the bottom of the keel really gets ugly unless you have a smooth, round-bottomed vessel. The "Draft" value should take this position into account. Waterline—self explanatory. Defined by a common Z-coordinate above the baseline at all stations. Station—self explanatory. Defined by a common X-coordinate at all waterlines or other longitudinal feature. Deck Line—defined by the highest X-coordinate at each station or other longitudinal feature. You can't have the "Deck Line" lower than the tops of the stations for this feature to work. Basically the moulded rail line in conventional drawings. Aft contour—the line defined by all the waterline/station points with a Y-coordinate of 0.0000 from the centerline at the aft end of the model. (It may also work for non-zero values if they define the distance of the rabbet line from the centerline. Never tried that.) Forward contour—the line defined by all the waterline points with a Y-coordinate of 0.0000 above the baseline at the forward end of the model. (Ditto as for "Aft Contour".) Flat of bottom—for flat-bottomed vessels like tankers, I think this tells the program to extend the bottom station Y-coordinate in the offset table to the centerline. Length—must agree with the Project Settings length (between perpendiculars) value. Beam—must agree with the Project Settings beam value. Draft—this is the setting that determines where the waterline is drawn on the hull above the baseline. It must agree with the Project Settings draft value. These are my best guesses, based on limited experience using the program. I recommend building the entire table in a spreadsheet, then exporting it as a plain ASCII text (.txt) file. Be aware that I had the best results by adding zeros in each column where there was no data. And you can't stick additional data between established waterlines to better define a sharp curve! Page 35 of the current manual (manual_809_296_mc0.pdf) shows the file architecture. Waterline data are arranged horizontally; station data are arranged vertically. Cheers!
  19. Nuclear warships present a special problem as museums or for disposal. The reactor compartments retain radioactively contaminated systems, even after the nuclear fuel is removed, so containing the residual radioactivity and shielding the visitors from radiation is challenging. Sinking the ships presents the problem of releasing radioactivity to the environment, not to mention granting unrestricted access to classified hull construction technology to divers. To my knowledge, the only complete nuclear warship accessible by the public is the USS Nautilus (SSN 571) located at its museum in New London, Connecticut, USA. It required special radiation shields to be added outboard of the reactor compartment, and the engineering spaces are not accessible. All other decommissioned US nuclear submarines have been sent through the "ship and submarine recycling program," where the first step after removing usable equipment is to cut out the reactor compartment (and the missile compartment in the case of boomers) and weld the two halves together for towing to the recycling yard if applicable. The reactor compartments are sealed and transported to the storage facility at Hanford, WA. Fortunately, civic and military organizations have seen fit to preserve the sails of many important subs. Preserving the sails in lieu of the entire ship is a good compromise between economy and memorialization.: USS Nautilus (SSN 571)—Entire ship, New London, CT USS Triton (SSRN 586)—Sail, Richland, WA USS George Washington (SSBN 598)—Sail, New London, CT USS Woodrow Wilson (SSBN 624)—Bangor, WA USS Nathanael Greene (SSBN 636)—Sail, Port Canaveral, FL USS Sturgeon (SSN 637)—Sail, Keyport, WA USS Tautog (SSN-639)—Sail, Galveston, TX USS George Bancroft (SSBN-643)—Sail, Kings Bay, GA USS Lewis and Clark (SSBN 644)—Sail & rudder, Mount Pleasant, SC USS Grayling (SSN 646)—Sail, Portsmouth Naval Shipyard, Kittery, ME USS Mariano G. Vallejo (SSBN 658)—Sail, Mare Island, Vallejo, CA USS Hawkbill (SSN 666)–Sail, Arco, ID USS Parche (SSN 683)—Sail, Bremerton, WA USS Boston (SSN-703)—Sail & rudder, Buffalo, NY (This list may not be up to date) I am hoping that the last remaining Los Angeles-class boat, USS Bremerton (SSN 698), which I commissioned back in 1981, will be similarly preserved. She is currently homeported in Pearl Harbor, HI. As a matter of interest, the only US nuclear merchant, the NS Savannah, has been designated a National Historic Landmark, and is currently moored at Baltimore, MD, awaiting funding to permanently provide a memorial park for her.
  20. I checked out your site and it has great possibilities. Make sure you provide links to the ship Historic American Engineering Record (HAER) web pages at the Library of Congress and National Park Service. For example, here is the schooner C.A. Thayer's HAER page. Terry
  21. Hi Wayne. You are expressing the lament of all who attempt to categorize a diverse area of knowledge into searchable, logical bins. One approach would be to use a keyword search, but assigning keywords to links can become very time-consuming and laborious. Another would be to use something akin to the Dewey Decimal Classification system, or for us old navy folks, the SSIC (Standard Subject Identification Code) system. In the end, no system is perfect. Best wishes on your project! Terry
  22. With respect to my original question, I think I may have found an answer. I learned today that Matt Turner built a two-masted schooner for the Seventh Day Adventists church missionary work at Pitcairn Island. In fact, the vessel was named the Pitcairn. She was launched in 1890 at Benicia, CA, at the same yard and less than a year before Galilee. Since her service was in the Pacific Tropics, and Pitcairn Island (home of the descendants of the HMS Bounty mutineers) is only 7 degrees south of Tahiti, Galilee's intended area of service as a packet ship, it is very likely that both were equipped with copper bottoms. Attached is a good photo of the Pitcairn on the construction ways. Need I say more? Terry P.S.: Considering the timing of Pitcairn's launch, the vessel in the background could be Galilee herself under construction. The rocker bow is distinctive. Wouldn't that be something?!
  23. I apologize for not responding sooner. For some reason, I'm not receiving notifications of comments on this topic. Pat, in reference to your 26 May comment, you made several interesting observations. I hadn't noticed the angled upper edge of the door before. However, taking all the perspective cues into account, like the door panels, it seems that the upper edge is simply not quite parallel to the track or framing above it. If the door were hinged adjacent to the opening, then the near side of the door would have to be higher than the hinge side because everything is made to conform to the deck sheer in this area. Nothing is square. When closed, the edge of the door toward the bow would be higher than the aft edge. In the image you enlarged, there does seem to be some kind of plate where a door handle/latch might be located. Last night I was reading in my copy of The American-Built Clipper Ship in a section that dealt with doors and cabin joinery. The book mentioned that on clipper ships, weather-deck doors on the outboard bulkheads of deck houses invariably were hinged on the forward edge. Then when exposed to boarding seas, normally flowing forward to aft, the water would tend to close the doors minimizing the amount of water shipped in the cabin. If Galilee's side door were hinged, it wouldn't be following this very logical consideration. Of course, clippers were built around 40 years before Galilee, and mainly on the opposite coast. Steamschooner, thanks for that photo of a sliding door. It's framing is far heavier than shown in Galilee, but it doesn't negate the idea. I have been thinking that, with the significant modifications to the forecastle required for the second cruise, the regular deck house door may have been removed. There is a photo of the ship before that modification, shown below. These doors might have been the main access to the forecastle, and the port-side door was added after this section was removed. I hadn't noticed something else before tonight--both of the doors in this photo were sliding! The starboard door is slightly open. So, for this ship at least, sliding doors seem to be part of Turner's design. I wonder if this was typical of the U.S. West Coast vessels in the 1890s, or if this was his particular inclination? Anyway, I will continue to tease details out of the photos and other records available to make a decision. Have a blessed Memorial Day, for those of you in the U.S. Let's remember all of our fallen dead who served our respective countries to preserve our freedoms. Terry
  24. Re: mothballing--naval technology is advancing so fast that some warships are becoming obsolete before their planned service lives. The 1st flight 688 subs are a good example. They were the quietest things in the ocean when they were built, but long before their 30-year service life, their base sound levels were already well above that necessary to remain tactically viable. So for ships that depend on advanced technology, mothballing isn't really an option, especially if they're nuclear powered. Carriers are so big that they can be upgraded repeatedly almost indefinitely until it becomes too expensive to replace legacy parts. Then there are the Ticos, that Congress wanted to scrap as a sequestration cost-cutting measure. Fortunately the Navy brass want to keep them and upgrade this very capable and good-looking class of ships. Nothing like the Zumwalt abomination or the LCS jokes for warships. IMHO. Terry
  25. Thanks for the responses. I'll take a look at the possibility that the door is actually hinged, but there just seems to be too much external hardware for a standard door. Besides, there isn't a door knob or handle evident at the aft edge, which is reasonably clear. W. H. Curtis's diagram of a conventional door frame, which I have attached, is much simpler and looks very much like a conventional door, even with the high deck coaming. My reconstruction of the forecastle can be seen at my build log. The earlier photo is taken on the ship's weather deck looking forward at the aft port corner of the forecastle deckhouse of the brigantine Galilee, built by Matthew Turner in Benicia CA in 1891. She was hired for Pacific Ocean magnetic survey work in 1906 by the Carnegie Institute's Department of Terrestrial Magnetism (DTM/CIW) and served in that capacity until 1909. My grandfather was one of the survey physicists on board for the second and part of the third chartered cruise. Check out Galilee's Wikpedia page and the Ocean Magnetic Surveys pages at the Department of Terrestrial Magnetism website. Attached here is another photo, very grainy, of the Galilee's port side, showing the relation of the forecastle to the ship. A small galley structure was added for Cruise II forward of the foremast. You can see that there is no exterior door evident, which means it must have opened into the galley. The galley is structurally similar to the forecastle in all respects except for size. The forward end of the magnetic observation bridge is above the forecastle. Terry
