IgorSky
Members-
Everything posted by IgorSky
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Hello to all! Thanks for the support, friends! So, on the last weekend I continued to work with this project. At first I finished the planking of the main house deck.
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Hi Nils! As usual, I just do not find the words ... Your work is incredible! What diameter should the steering wheels have for your model? Best Regards! Igor.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Hi Jeff! My sincere condolences to you and your family... And good luck in the continuation of your project! Be careful in combining CA and white glue - they do not always work well in close contact. Igor.
- 185 replies
- jolie brise
- pilot cutter
I continue to build one of the entrance tambours
- 185 replies
- jolie brise
- pilot cutter
At this stage my vacation is over. Now the pace of work will slow down significantly
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Next, I cut through the deck in the places of the entrance tambours and lined the walls of the holes with planks. I do not know for sure whether there will be open doors in the entrance tambours, but, just in case, decided to refine these holes in the deck
- 185 replies
- jolie brise
- pilot cutter
Then I glued the steering plate. I was thinking of making imitations of fastening loops, but they are built-in on this boat and are unlikely to be visible under water.
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Then I finally grinded the planes connecting the upper and lower parts of the hull, cut out the plate replacing the waterline and processed the entire hull assembly.
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Patrick, Hornbeam is the kind of trees - https://en.wikipedia.org/wiki/Hornbeam I use strips of this tree, which are pre-painted right through.
- 185 replies
- jolie brise
- pilot cutter
Next, I glued the posts to the inside surface of the bulwarks. Because The bulwarks themselves gradually reduce their thickness in the process of grinding them from the outside, then their additional strengthening will be very useful. In addition, they will be very useful and to increase the area of gluing when installing gunwales.
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
Many thanks, Patrick! Next update. On the bulwarks above the scuppers there is a narrow red strip. In order not to bother about drawing these strips, I decided to make them too from hornbeam.
- 185 replies
- jolie brise
- pilot cutter
- 185 replies
- jolie brise
- pilot cutter
