IgorSky
Members-
Everything posted by IgorSky
I again disassembled the entire structure to continue working with the hull of the boat. Here the mast with sails is almost complete.
- 82 replies
- boat
- lak-design
Hi Nils! Many thank for your fedback! Yes, and boat and figures are in scale 1:72.
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
First, for the assembly of the model, I glued a double-sided scotch to the boat support onto the timber bar. Then I realized that it's easier to make another normal slipway
- 82 replies
- boat
- lak-design
Deadeyes I made round blanks. Glued them in pairs. Then I sanded them with the sandpaper and attached the guys. Then I drilled holes.
- 82 replies
- boat
- lak-design
The next stage is the making of the mast attachment to the bench. Staples of thin sheet brass. Pins made of wire with glued washers.
- 82 replies
- boat
- lak-design
Then I painted the boat and the mast with a diluted bitumen lacquer. I also use it for tinting sails and rigging yarns, if necessary.
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
Between the matter I cut a couple of oars and tried the figurines :). Because my bottle does not allow to make a version with oars, the oars will just lie in the boat, but I will have to make a mast with a sail.
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
- 82 replies
- boat
- lak-design
Hello to all! One of my current projects is a boat in a bottle. As a basis, I took a set for the construction of a boat from LAK-Design. This boat is on the 91st scale, but I plan to place a crew there, so it will be adapted to the 72nd scale. So, a pair of keel frames from the pear 0.7-0.8 mm was prepared in advance and I proceeded to assemble this kit. First I prepared a "skeleton" from a double keel frame, frames and conductor.
- 82 replies
- boat
- lak-design
Cutty Sark by NenadM
IgorSky replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Hi Nenad! Several years ago I visited this village of Kusturica Kustendorf (Drevengrad) too. This place is just amazing!- 4,152 replies
- cutty sark
- tehnodidakta
I wanted to achieve greater authenticity
- 185 replies
- jolie brise
- pilot cutter
Hi Carl! I added a few new items in the rigging of this model. This leads to complicating the process of assembling the model in a bottle.
- 185 replies
- jolie brise
- pilot cutter
Yes, Carl, I'm trying to understand, but I do not have confidence yet...
- 185 replies
- jolie brise
- pilot cutter
ancre La Salamandre by tadheus - 1:24
IgorSky replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Amazing... just amazing work, Pavel! -
Many thanks Carl! I'm starting to worry about HOW I'm going to assemble this model in a bottle...
- 185 replies
- jolie brise
- pilot cutter
