IgorSky
Everything posted by IgorSky
  1. Thank you Bob! So, one more evening - one more sail )) Best Regards! Igor.
  2. Thank you Carl! I hope to continue tonight ))
  3. Thank you Patrick! Yes, it's a SPECIAL match! )) Best Regards! Igor.
  4. Hi everyone! Small update was made yesterday. In during one evening was made only one sail )) Best Regards! Igor. P.S. And of course, I again did the photo with my special match ))
  5. Hi Amy! The scalpel N3 with the blade N11 is my favorit tool during many years Best Regards! Igor.
  6. Hi Bob! I will find my special match and I will do the photo a little later )) Best Regards! Igor.
  7. It's just incredible, Patrick! Congratulations! Best Regards! Igor.
  8. Thank you Piet! I am sure that you easily can place your ship in a bottle. So, the next small update here: Best Regards! Igor.
  9. Great job Tadeusz! I look forward to the sequel! Best Regards! Igor.
  10. Hi Ian! In this case, I used the medical steel needle with a diameter of about 0.5 mm. In fact I could not find a brass tube diameter is less than 0.8 mm, but the needle may has a diameter of 0.3 mm. This is no rod )) I use a conventional needle to handle edge of the tube. So I rule out the sharp edges of the tube, which can cut the thread. I often use medical needles of different diameters for my models. I did portholes, davits, gears for winches, mast's elements, etc. Best REgards! Igor.
  11. Hi everyone! Many thanks for your interest to this project! Here is the little update per last weekend. Best Regards! Igor.
  12. Excellent work Patrick! The details are amazing! Best Regards! Igor.
  13. Oh, sorry! Proxxon is a mini drill. I use it for many works. I will try to take a photo in the coming days. Best Regards! Igor.
  14. Hi Piet! This boat is a great choice! I like it! Regarding the fabric ... I think it would be easier if I just send you a small piece of tissue in the letter. You can write your post address in PM and I'll send it to you. I have used this fabric a few times for my models: Best Regards! Igor.
  15. Hi Jeff! I admire to your fundamental approach to solving technical problems! Bravo! By the way, I often use the needle from the syringe when I need small diameter tubes with thin walls. I use my Proxxon to cut off a piece of the tube of the desired length. I am clamping the tube in Proxxon and I cut it with a scalpel. I process the pipe end with Proxxon also. Best Regards! Igor.
  16. Hi everione! Small update. Over the weekend, I have prepared the cloth for the manufacture of sails and the blanks for gaffs. Best Regards! Igor.
  17. Yes Ian, in this case, I used double-sided tape for fixing of the ship. Sometimes a kind of tangle thread scares me too, but in the end everything falls into place. )
  18. I like this ship long time too. http://www.jocham-schiffe.de/html/start.html
  19. Hi Patrick! You made this day for me! I laughed for a long time ))) My alibi - the photos of my childhood )) But seriously, these small details are quite simple to manufacture/ Best Regards! Igor.
  20. Many thanks Piet! I think that to build a ship in a bottle is not a difficult task for you. In any case, I am ready to help if necessary. What kind of Dutch fishing boat are you talking about? Can I see the photo? Best REgards! Igor.
