G.L.
Everything posted by G.L.
  1. Thank you Christian. To give you an impression of the size: below a of one of my modelling friends examining my cross section during our monthly meeting yesterday afternoon. G.L.
  2. 14.15 The port forward rail with belaying pins. The pins are made as described in my post 12.2.
  3. 14.13 The forward rails have five holes for belaying pins, the aft three.
  4. 14.12 There are also four rails for belaying pins on the sides. The shaping of them is done in the same way as the bollards.
  5. For the upper layer of outboard trims I use the same profile, but this time upside down. This time the trims are glued directly on the outboard planking.
  6. Some small nails in pre drilled holes keep the trims on their place when the glue is drying. As You can also see I glued little pieces of wood to lengthen the frames which were a bit too short.
  7. I saw the back side of them to the correct angle with the help of the adjustable table saw.
  8. To make the outboard trims, I make a scraper with a piece of a cutter knife.
  9. 14.9 The top of the bollard is filed in shape with triangular and round files.
  10. 14.7 There are four bollards on the deck, two forward and two aft. I make them of small oak bars.
  11. Here they come, Patrick. 14.6 The bulwark is at the outside strengthened with seven vertical planks on each side.
  12. This is the point where I lost my log in December! From here on we will continue the building log with new posts.
  13. 14.2 Now I can shorten the excesses of the frame futtocks. They are sawn so that the extend about a millimeter above the bulwark.
