Everything posted by G.L.
12.10 To give the hatch the same curve as the roof I glue it together on top of the roof. A piece of paper between both prevents that the hatch is glued on the roof. When the glue of the hatch is dry, I sand it and make the hatch rails. On the front side the pincher is holding the front plank in place while the glue is drying
12.7 I glue the bottom-, top front- and top middle beam between the 2 sides and fill the so formed front frame with planks. The width of both top beams was almost double as it should be. When the glue was dry, I sanded the topside of the deckhouse arched with the band sander as can be seen on the picture.
12.2 I add also the a small rail with 3 holes for belaying pins, connecting the jib boom support with the knight head. The belaying pins are made on the lathe of a spar of beech. 1. I first cut the thin part of the pin. 2. With a round file I shape the body of the handle. 3. I then cut off the pin from the spar and turn it around with the thin part in the chuck and I round the upper side of the handle with a flat (triangle) file. 4. The result. 5. The pins in the rail.
Part 11: Laying the deck: 11.1 Only the port side of the deck will be closed. I will leave the biggest part of the starboard side uncovered to preserve a view on the deck beam structure and the interior. I start with making and placing small filling pieces between the bulwark stanchions. On the sides of them I glue a strip of black cardboard to imitate the caulking.
