Everything posted by G.L.
I start the outside planking with placing the wales. Inspired by a lot of Triton cross section builders, I decide to make the wales in an anker stock pattern. Accordingly to 'Historic ship models' of Zu Montfeld the planks were 384 cm long and 12 cm wide at the ends and 24 cm in the middle. It is not possible to keep those exact sizes due to the frame intervals and the wales with on the cross section drawings. I draw a pattern with wales of which the dimensions are as close as possible.
While applying the inner planking and rectifying my mistakes with the port holes and the frame lengths, I continue laying the gun deck. Like on the lower deck only the portside will be fully planked. At the starboard side planking will be omitted from the starboard topsail sheet bit on. I lay the first two planks on each side of the forward hatch.
Thank You Hakan, The 'Ostend shipje' has some similarity with the British smack, but it is only half the size of it. Flemish fishermen who evaded to Great Brittan during the 1st World War got acquainted with the smack and introduced the type in Belgium after the war. I have somewhere a smack cross section project on the shelf, but have to finish first my HMS Triton cross section. G.L.
Part 13: Making the rudder. 13.1 The rudder is made of three oak planks, the main piece and two after pieces. Because the main piece is thicker than the after pieces. I lay a small sheet of brass of half the thickness difference below the after piece planks to glue them together. I lay also a similar brass sheet on top of the whole to put some pressure on it while the glue is drying.
