Jolley Roger
Everything posted by Jolley Roger
  1. I like the pastes from Solder-It http://www.solder-it.com/shop/category.aspx?catid=6 Comes in a syringe type applicator and no flux required.
  2. Nice to see some activity in the cross section department! I'm also planning on doing this build, so are watching your progress with interest. Have fun!
  3. We have a product in South Africa called Waksol F, which amongst other things, are used by beekeepers to treat beehives.(It takes about 2 weeks to dry completely) It contains mainly Bitumen and some beeswax, which is cool, cause it attracts bees! Available in 1 litre bottles to 200 litre drums. Over here 1 litre cost less than 3 USD. Maybe your local beekeeping supplier stock something similar? Smeared some on a mini chisel this morning to see the effect.
  4. I will do so Nick. Just waiting for snailmail to deliver to this side of the world...
  5. I just bought one of these to play around with(it's still in the post, so i'm waiting in anticipation!) It was on special for USD200, so just couldn't resist it... https://www.kickstarter.com/projects/820277733/mini-cnc I'm gonna see if I can cut some frames with it for an upcoming Triton cross section build.
  6. Vallejo specifically, I know their latest range is cadmium free, but there might still be older stock around with cadmium in it. Anyway, it is only good practise to wear a respirator when airbrushing.
  7. Just keep in mind that some acrylics contain Cadmium, so wear a mask.
  8. Birchwood Casey also have a product available for blackening Aluminum https://www.birchwoodcasey.com/Refinishing/Metal-Finishing.aspx
  9. If I remember correctly, you can also dip it into a mixture of ammonia and water, as ammonia reacts with aluminum. Best to test on some scrap pieces first though.
  10. Looking good so far Worldway, very similar to how mine looked after the first planking. The wood strips for the second layer of planking should have been included(it were included in my kit), unless the newer versions of this kit expects you to paint it instead of planking it. It might be a cost saving measure on AL's side.
  11. I use this stuff: http://www.microscale.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=MI-9
  12. It was on OLX, from a lady running a second hand shop in Bloemfontein. I was 10 minutes too late...
  13. You are flying along C6H14O Looking good. (PS. I could have picked this kit up for R300 about six months ago, still kicking myself!!!)
  14. Hi Cindy, Where do you live in SA? Most of the stuff you need can be sourced locally.
  15. Also, a good steel ruler with both imperial and metric units. Measure twice, cut once!
  16. Beakhead finally installed, it took a bit longer than I thought it would. Gunwales done. Busy with the stanchions and futtocks, one side is almost done. Must say, my vocabulary has improved wrt ship parts(that is if AL got it right)
  17. That's very cool Daniel! I like all of them, but if I had to choose I would go with B, assuming a Statenjacht would have been well maintained being close to home. For ships doing long distance cruising far from home, I would go for C.
  18. Hi Ken, Yes, drilled by hand, I use a piece of masking tape to make sure it is in a straight line (sort of )
  19. Hi Keith, Interesting build, wish I had the skills and tools to build a ship from scratch. For interest sake, the correct spelling in Afrikaans would be 'Weerligstraal', we also make use of word 'Bliksem straal' as Piet mentioned above.
  20. I'm a big fan of the Vallejo Model Color range: http://www.acrylicosvallejo.com/en_US/model-color/family/15 It can be applied with hand brush or airbrush and is an acrylic.
  21. Well, the painting is finally finished! Definitely not my favorite part of the build, but I wanted it to look as good as possible, so I spent a lot of time on it. I also decided to change the bulkhead from mahogany to cherry wood. I made the little window with lead wire and Microscale Kristal Klear ...and last, but not least, I am attempting my hand at treenailing the deck. I still need some fine tuning on the technique, but it looks alright for a first attempt. (i still need to finish the set on the right, just need to pull more bamboo through the drawplate!)
  22. She's still around: http://www.hokulea.com/ They visited Cape Town in December last year.
