Ainars Apalais
Members-
Everything posted by Ainars Apalais
Hi Justin Regarding the cannons, I decided to go the easy way- bought already made. For the next model I will try to make them by self as new interesting challenge.:) From my memory"Caldercraft" was manufacturer for them. From package they coming as polished brass finish. I just applied one coat with black primer spray. After that 2 cots with black enamel/mat paint. Only for paint I use brush to create more rough finish. For all wood parts I use Wipe-on poly/clear satin/minwax finish. I apply 3 coats and sanding between them with high grade/600,100,2000/sanding pads. Looks like anyone have different approach how to finishing they models. But the way how I did it satisfies me, and I think it looks pretty good. In any case, I hope the information above will help you build your model, that already looks beautiful.
Hi all Finally that moment has come. When I can say the work are completed. I just recently added last missing piece - main mast. Thanks one more time to ChadB for all details for that. And with that, the model is done. I have already started work on stand and display case. So one more small/last build update will coming soon. Thanks to anyone for help and good words.
MONTAÑES by Amalio
Ainars Apalais replied to Amalio's topic in - Build logs for subjects built 1751 - 1800
Amazing work!!! Even the every smallest detail looks perfect. -
Hi Justin My Idea to add locker, pump room comes from ChadB built model. Thanks him for inspiration. When i start build your model as a guideline i use Chadb model. "tkay11" and "AnobiumPunctatum" also help me with recommending good reference book. The Fully Framed model HMN Swan Class Sloops 1767-1780 by David Antscherl. And of course a lot advice I found here on the forum simply browsing other models. Putting all information together I create my own vision about pump/locker room details and measurements. I hope that the information provided will helps to you.
I can only agree with Alex "True Masterpiece"
- 589 replies
- le gros ventre
- cargo
Thanks Chad The idea about initial block was taken from "tkay11" Triton cross section build. Thanks to him for that. I just do it a little changes. I make it a little longer and with 3 carriages in one time. The principle is quite simply. I pre cut all parts by sizes and right mitre. After glue them together. Only I use glue on ends of parts/Red line/ When all milling,sawing and preparing works was done I simply cut off glued parts/Green line/. In my opinion it worked quite well. Only I'm not sure if I'd do the same if I had to make for example 20 Carriges In any case hope information given to me helps to You. Regards Ainars.
MONTAÑES by Amalio
I am like always excited about Your work.
