Bob the Builder
About Bob the Builder
  • Birthday 06/02/1964
  • Gender
  • Location
    Raleigh, NC
  • Interests
    Wounded Warriors Project, UNC Children's Hospital,
    Goathouse Refuge, Motorsports, Model Building, Model Restoration, Land and Sea Dioramas
1,357 profile views
  1. I appreciate your careful, methodical approach, Charlie -- there's no reason you will come up with nothing less than a jewel of a model. Watching your build is like an instructional segment, with the way you present your progress, and show the tools, templates, and materials used. I have something to learn from you.
  2. Chuck - I may end up doing that, but first I think I will try Alan's advice on building my own (I have tons of extra lumber), I was hoping not to spend any more on extras for this build.
  3. I got on a scratch-building kick, before opening the kit bags. I'm gonna go back and use the cast gratings supplied with the kit. I think I can detail-paint to make those appear to be wood.
  4. I wasn't really sure how to make gratings without those notched pieces that I saw in the practicum that were purchased separately. Maybe I should slice some openings in each piece of wood, and push them together so everything finishes on one plane?
  5. From posting these pictures right after a day's work, I've learned that maybe I should make some pictures, and then study them to see what details can be finished in a better way before I post them for all to see. It gives an honest perspective that I don't have staring at the project all day on my bench...
  6. The transom is next - I've added height to the overall shape as Mr Passaro outlines in the practicum, and I too, will give depth and dimension by stacking two 1/32 sheets together (the first layer will hold the window detail, the outer layer will show architectural details...
  7. I'm doing a combination hand-building some things, and using some of the cast-metal items supplies with the kit, such as the windlass, binnacle, galley stack, and figurehead. The windlass will be improved upon with hand mixing and painting for the impression of Oak, then weathered a bit...
  8. Made the volutes from rolled up air-dry clay, and blended in to the cap rails. Looks like some more sanding shaping is in order.
  9. I built my own gratings according to the practicum, and made a ladder to down below...
  10. That's the kind of advice that will help me learn, Chuck! Now that you point it out, it seems obvious the planks should appear to be fastened where they begin and end-- that's just good logic, and I missed it....but it will be fixed tonight. Also, I was able to right-click on the diagram and save it so I can print it out and put it on my cork-board as a reminder. Great help -Thanks for taking your time to help me be better!
