Bob the Builder
Posts posted by Bob the Builder
  1. That's the kind of advice that will help me learn, Chuck!  Now that you point it out, it seems obvious the planks should appear to be fastened where they begin and end-- that's just good logic, and I missed it....but it will be fixed tonight.
    Also, I was able to right-click on the diagram and save it so I can print it out and put it on my cork-board as a reminder. Great help -Thanks for taking your time to help me be better!
  2. Chuck, I can take more pics of the side planking so you can see my trunnel work and butt-ends, but I have to find another photo resizing program --
    my trusty program vanished with my last updates!
    As for the deck planking, I fully intended to add trunnels and butt-ends there too after a final sanding, was just waiting for the stain to dry.
    Now you've got me re-thinking about the butt-ends up on deck. (I really like the look, but if it's not accurate...?)
    I knew I would have to make some compromises when I committed to ship-building with historic accuracy. In plastic, we say "It's your model,
    make it like you want it", but this (to me) is different.
  3. Tamiya paints are the best I've ever ever used - I pick up these up locally at Raleigh Hobby, or they can be ordered and shipped anywhere in the continental U.S. from Tower Hobbies. The spray cans designated with the "TS" prefix are synthetic lacquers...they dry fast, and sand easily.
    I use these for 90% of my work. If you're using an airbrush, their bottle acrylic paints are designated with an "X" prefix for gloss colors, and "XF" for flat colors.
    If you find a gloss color that's perfect for your need, they also have a flat base you can mix in to make it as flat as you want.
    NOTE: Be sure to use an appropriate primer first though! I use Krylon spray primer w/ 10-minute dry time.
  4. Using Chuck's advice once again, I painted the wales, trim, and fashion pieces off of the model for a neater job.
    From the plastic hobby, I've used Tamiya Lacquer paints for years, and after wood is properly primed, the paint works just fine here too.
    I used Tamiya Racing White for the hull color. It gives the schooner a slightly weathered look in my opinion.
    The insides of the bulwarks are Tamiya Dull Red (not sure if historically accurate, but it looks right to my eye)
  5. The volutes will be next (the curvy decorations where the cap rails break)  Chuck made his from Sculpey, which has to be baked.... I will use DAS air-dry clay, which I have experience with. The only drawback to air-dry clay is that it shrinks a bit when dry, so I'll make them about 1/16" larger than needed, then sculpt them down to size if I need to -- glue-fix them in place, and paint-blend into the cap rails.
