CDW
Everything posted by CDW
  1. Got all the wash done to my satisfaction, now adding a few places where NMF appears. Exhaust areas get burnt metal. There are a few places that will get a Radom tan color then will begin applying decals before adding LG, doors, pylons and ordnance. Some light weathering will follow all that.
  2. Love that B-25 and the way you’ve displayed it remarkable. Beautiful!
  3. The fellow featured in the video passed away, the oil company exec.? That’s sad to learn.
  4. This lucky guy was able to buy his very own Blackburn Buccaneer. Wow!
  5. In this short video of an obviously out of service Buccaneer, probably on display somewhere, the maintenance panels and panel lines stand out rather proud. One can presume this is at least in part due to weathering as it sits out in the open. Other than photos of engine maintenance where the panels around the intakes are removed, I have not yet been able to find photos of other panels opened for maintenance. I will just use my imagination to show some wear on various random panels for this model.
  6. Next will repeat the same process on the bottom.
  7. To achieve a more subdued look, simply remove some of the panel line wash using Solvent 110. It seems this product is a refined, odorless white spirits but I have not experimented to find a generic equivalent of it. What I do know is that it works well to remove excess Tamiya or Mr Color wash that’s been applied over Mr Color lacquer paint without harming the paint in any way. Your results may vary over different paint types. On the opposite side of the model I used a dark gray panel line wash to compare to the black wash used on the first side. A slightly different look but not much different. I’ll end up using the black on both sides to keep everything consistent. The key is how vigorous the cleanup after application. im going to try and find some photos that show the commonly used access panels so I can show some light wear around those. If you’ve run across any photos like this please share them with me.
  8. Thanks Arthur. You could also use a lighter shade for the panel line wash. I used black. I’ll be using some oils and pastels for various highlights on the model later on.
  9. First a pin wash, second a cleanup of the pin wash excess, then last a side by side comparison of with and without the pin wash that captures panel line/rivet detail. Some like it, some don’t. Suit yourself. This gives an idea of what to expect with or without it.
  10. With Easter weekend finished got a few more things done on the Buccaneer. Lots of small details to pull together now.
  11. Other than the minor fit issues you described the overall molding of the parts is superb. What riveting tool are you using? Rosie the Riveter tool has become almost impossible to find now. I guess the company went out of business?
  12. Those launches look fantastic Jeff! A remarkable job on your MIKASA.
  13. Don't worry about a thing. I still enjoyed the photos very much. Beautiful work, Jeff.
  14. I think maybe it’s time to break out the new lighting systems my son gave me for photographs. Two bright LED light banks that sit atop adjustable tripods. Each one has a sort of diffuser that softens the light and something like adjustable blinders that help focus the light. Gray seems to be a color that’s hard to photograph to me. I’m thinking that light is the issue.
  15. Here’s the model with both shades of gray applied, the top one being the finish color. Next will wet sand to lightly expose some of the lighter shade of gray underneath and hopefully achieve the lightly weathered effect I want.
  16. Love that paint work, RGL!
  17. Did the kit advise how many links were required per side to fit the sprockets and wheels? I lay all the links down on a flat surface using a straight edge to keep alignment, then glue each link together with Tamiya thin cement. Before the cement completely sets and is still soft, shape the track links around each side then reapply cement if/as necessary to each link. It's a real pain in the **** for sure.
  18. Never taste tested any of the three but I have heard from reliable sources that Iguanas are truly good tasting meat. In a tight spot, I can survive but as long as I am able, opt for more traditional domestic food sources. Peacocks are a smelly bird. If they tasted anything like they smell, it would be awful. There used to be (maybe still is) a Rattlesnake Festival near where I live each year. Rattlesnake is on the menu, I've tried it but was not overly impressed with it. Same with Alligator. Ever tried fried frog legs? Alligator tastes a lot like that, a cross between chicken and fish. Gopher tortoises and snapping turtle are absolutely delicious when prepared correctly. 😄 Nowadays gopher tortoises are a protected species. When my forefathers came to Florida in the early 1800's, it was completely uncivilized, a wilderness. They learned to eat/survive on native game and found creative ways to prepare it so it was good to eat. Time changes everything, food along with it.
  19. With a light wet sanding, the Mr Surfacer primer becomes smooth like glass. Not sure how well it will show up in the photo but the bottle on the left is Mr Color Dark Sea Gray which will be my top coat. Under it will be the color on the right which is the top color knocked down a few notches with a lighter shade of gray. The combination of the two colors will be to help achieve a slightly worn/weathered look. I will lightly wet sand the top coat until a little of the lighter gray shows through in random places.
  20. Even though Mr Color Surfacer 1000 goes down very smooth, will wet sand gently with Tamiya extra fine sanding sponge before applying color coats.
  21. Didn't mean to infer it was. Simply that the old saying, to the victor go the spoils of war, is now, was then and will ever be true. Look back at history as far back as we know...the artisans, experts, and "scientists" have always been kept as spoils of war. ordinary men and women are expendable. That's the cold hard truth. There is no reason whatsoever for me to believe it would be any different today.
  22. Paperclip A guy I knew was guard at a prisoner of war camp here in the USA during WW2. He told of the special prisoners kept here back then.
  23. Can anybody say: Hans-Ulrich Udel? Talk about a ground target smasher, this was THE man. Over 500 tanks destroyed, ships including a battleship, a cruiser, dozens upon dozens of artillery emplacements and untold numbers of softskin vehicles. He was even credited with shooting down nine aircraft.
  24. Mr Color has one out called super chrome silver, applied over gloss black through an airbrush. With a clear varnish it looks phenomenal. A couple of other “super” metallics in this particular line. Very fine pigments.
