Everything posted by mikiek
Old NRG Article on Deck Plank Spacing
mikiek replied to mikiek's topic in NAUTICAL RESEARCH GUILD - News & Information
Mark - maybe I misunderstood. I thought that article was going to be posted in the NRG How To Library. -
Am I missing something? I don't see the article in the NRG resources. -
I'm not sure how far you plan to go on this restoration. A couple of your pics show the deck which looks pretty dirty. I can't really see what shape the deck furniture is in. Sadly I can't help you with the rigging. But I would suggest getting any deck cleaning and repairs done before you start rigging. The more string you have running around the boat the harder it becomes to do that sort of work.
Matching Deck Colors
mikiek replied to hof00's topic in Painting, finishing and weathering products and techniques
Are the washes applied by brush? I seem to remember using a paper towel or a rag. All of the above? -
Hey Wefalck - just so I'm clear, when you say "wash" in your process what exactly do you mean? Thanks.... -
As Welfacks photo shows, you will want to put some color randomness on your sticks. Nothing ever comes out perfectly in one shade. You'll want some sticks darker/lighter than others. I also agree, you'll need to mix several colors to get you closer to what you want and it may be literally just a drop or two of some of the secondary colors. Keep good notes on how much base you started with and how many drops of additional colors. You may have to make another batch down the line. -
Very nice cross section. I love those builds. I realize the OP was quite a while back but I would be interested in hearing your progress on this one. Maybe by now you are done. Post some pics.
- 4 replies
- vasa
- cross-section
As usual I am bypassing all the difficult decisions that are in my face. The instructions call it something different, but I call it the waterways as would any credible plans. There is a stick that needs to wrap around the ribs from the inside. Once this stick is in place, there is a gap between the stick and the inner hull. The plans call for placing a shaped piece of stick placed in between each rib. YEAH RIGHT. Are you freaking kidding me? There is no way to even tell what that shape would be. This is a total joke. Instead, I have cut 2x3mm sticks into pieces that fit between the ribs and then just glued them into place using white glue. After 10-15 minutes (before the white glue dries) I just go in with a sharp knife blade and shear off the excess. A little sanding helps to smooth out the surface. I just can't keep from thrashing the wood in this kit. Total garbage. As you see in the pics below, the more I sand the worse it gets. Honestly, I thought sanding was supposed to remove shreds and splinters. Not bring on more. 😒
- 62 replies
- lancia armata
- panart
Been working on the cap rails. As mentioned above and according to the instructions, the bow end of the rails requires 4-5 trapezoidal pieces shaped in an effort to lay on top of the bow curvature. Sadly, there is no pattern provided so it's totally up to the builder to figure out the shape of each piece. In other words a WAG. I guess I got lucky - it came out reasonably well. The ugly part is the curve between the upper and lower rail. The kit provides a "wood ring" that you are supposed to cut out a chunk and lay it on the curved edge. Unfortunately there was no direction at all on how to shape that curve. And the shape I ended up with doesn't come close to matching the ring. Will either require a buttload of sanding or I will dump the ring and try to bend something to fit the curve.
- 62 replies
- lancia armata
- panart
Fantastic! The write-up will be a big help for many of us. Thank you to all that made this happen. -
I agree. I have used the article twice and I am aware of others that have used it as well. It would be a great addition to the library. -
Went ahead and colored the inner hull. Probably the first time of many. I used Minwax PreStain and then Minwax Natural stain. This stain doesn't have any color but it adds a "wet" look to the wood. I use it probably more than any other. I think it did help to revitalize the dead looking walnut. If I decide that's what I want, I will lay down a couple coats of matte varnish. I have also started work on the cap rails. Instructions call for making several trapezoidal pieces up at the bow in order to get the correct bend. I was tempted to try to just bend an entire stick, but the sticks are 3.5x10mm and they are not interested in edge bending 😒
- 62 replies
- lancia armata
- panart
He-he - so much for "back to planking". I have added the ribs to the inner hull. The drawing was kinda confusing. One drawing showed the hull with no ribs, the next showed the hull with ribs in place. No mention of size or spacing. I finally noticed a side drawing and determined I needed 2x3mm sticks. There is a full scale drawing that showed the ribs on 19mm centers. Rightly or wrongly that's what I went with. The rib size looks a little wimpy IMO but it is what it is. I thought I would have to physically bend a few of them to fit but it turned out that brute force and gluing with CA worked OK. I'm thinking pretty soon I need to stain & finish the inner hull. There's a whole bunch of stuff that will be going on the decks and inner hull. Trying to color them later will be problematic. I suspect I will go with my old stand in - Natural stain with a satin finish. It will be interesting to see if that revives the walnut or not. It looks pretty shabby at this point.
- 62 replies
- lancia armata
- panart
Mark - The name sounds familiar. I believe that is the one. It showed a 4 plank pattern, 5 plank and I believe all the way up to 8. I would be really grateful if you can find it. I'll abide by any requirements you have. If you would prefer to email it to me I can PM you my email. Many thanks... -
"If I'm understanding you correctly you would know when the garboard is in its proper place when the next plank up can rest on it without bending." This is correct. Another thing you can do is take the stick that will be your GB and put the bow end into your rabbet about midship. Lay as much of the edge in the rabbet towards the stern. Then start sliding the stick forwards in the rabbet toward the bow keeping a close eye on that leading end. You will either see the stick start to move upwards when it gets to the stem or it may just stop and not slide anymore. That's where it should lay. You can then do whatever shaping you need to do to the front end of the stick.
I prefer painting and usually with a brush. There are some alligator clips that have a stick coming out the back. Clamp the piece then hold the stick between thumb and forefinger. You can easily rotate the piece by rolling the stick between your fingers. Stab the stick in a piece of styrofoam to let it dry. As with any paint job go light or you may end up with drip marks. Tamiya makes a great color called Rubber Black. It's even flatter than their Flat Black. Imagine the color of a clean car tire (no ArmorAll 😀) and that's about what it looks like. There's a lot less fuss using paint.
" I realized when I bent the bow end of the port garboard strake to fit into the rabbit it had the unintended effect of bending the tip upwards as well due to Obscure Geometry. So of course all the subsequent planking follow this upward curve. " The garboards should go in straight - no bending. Yes there will be a lot of twisting and turning but no bending. I you find that it is wanting to bend up at the bow most likely it is pushed too far forward. You should be able to lay the next strake on the top edge of the garboard and it should sit flush. I usually try to pin the garboard in place then lay the next strake on top just to see how the two will mesh. Then adjust and glue the GB. As you found out, if the GB is bending all subsequent sticks will want to bend as well.
Still more going on with the hull interior. I will have to get back to the exterior very soon (see below). It has been fun working on the innards of the boat. A nice break from finishing the 3rd layer planking. A few pics of what has been done: The biggest problem I see is that the instructions (if you can call them that) specify limewood for a lot of the trim. This wood is hideously ugly and when laid on top of some shredded walnut looks absolutely pathetic. And somewhere down the line I expect the instructions to say "just paint all the limewood". I say this because the limewood pieces look totally hideous. They are going to have to be colored somehow and it would be way easier to paint them before they are glued to the build. I did finish off planking the transom and was about to trim up the edges when I realized that I can't do that until I complete the 3rd planking. So, sadly I will need to get back to the 3rd planking. Yup, I'm a procrastinator for sure, but the time has come. 😒
- 62 replies
- lancia armata
- panart
As stated above I had to grind out all the extensions. The planking at all those points, broke off easier than I had anticipated. It took a little sanding to remove all the crusty glue remains from the inner hull. As I have begun to apply the various deck base pieces a few pics will show how pathetic the fit actually is. Some I was able to sand down to make a reasonable fit. Others just simply suck. Most likely the deck planking will end up covering the big gaps. And then there are some frame pieces that have some sort of chunk taken out of them and then a separate piece that fills in the same chunk. This has happened on multiple occasions. I mean really WHY? How stupid can it get? My laziness has me working on the hull interior rather than finishing the 3rd hull layer. I discovered one big screw up this evening. While working on the interior I have been using wood from the same bundle that was supposed to be used for the final planking. WRONG! I kinda happened to remember that there was another bundle of sticks still remaining in the kit box. Some of those sticks are supposed to be used for all the decking planks. So I have been using the wrong sticks to plank all the decks. Hopefully I will have enough plank sticks to finish the hull. The fun never ends..... Apparently the editor has gone bonkers again. Not sure why the above pic has been embedded again. I can't delete it.
- 62 replies
- lancia armata
- panart
While still futzing with the 3rd plank layer, I have realized that I can start working on the interior components. There are 4 "deck" levels. Each has a base layer cut from a laser template. Every base will be be planked. Here is the biggest base. There is one serious problem that is coming up and I am not sure how to handle it. As I have mentioned from the start of this thread, most of the frames are breakaway, cut to allow for the top 2/3 of the frame to be broken off. You can see this in the above pic. You can also see that in the few remaining full frames (the 1st and the last) there is some extension at the sides. Well now surprise, all of the circled material needs to be removed. The problem is that it is all plywood. Thick stuff. It will not be removed with a knife. Given the position, it will also not be removed with some sort of handsaw. So WTF? The only thing I can think of is to break out the Foredom flex shaft and grind it all away. If anyone has a better idea please let me know. I guess I need to rag on Panart a bit more. According to plans, those frame extensions looked like they were going to be permanent and like a fool I glued plank strakes to them. Now not only do the extensions have to go, but all the strakes have to be unattached from them. Another pitiful design decision. I will already start to warn anyone - Panart kits are extremely difficult to work with. Materials are sub par, instructions/plans are really bad - they often contradict each other. If you are a beginner, I would look elsewhere for something to build.
- 62 replies
- lancia armata
- panart
Still working on plank layer 3. Unlike the other layers, I am working strake by strake. Shaping a stick for starboard and then duplicating the same shape for a port stick. Honestly, while this is the suggested method for planking I am seeing some holes in this theory. Mainly, it is based on the fact that both hull sides are shaped identically. Obviously to me, at least in this build, that is not the case. I suspect that this is the same situation in a lot of builds. I have had to do additional shaping after a strake is glued, which means that the strake on one side probably doesn't match the strake on the other side. I have laid about 3 strakes down from the wale. Since then I have been working up from the garboard and have a total of 4 strakes up from the keel rabbet. As was my intention, there is a very mellow downward curve in the strakes below the wale. This will come into play much more as the lower and upper strakes get closer to each other. As with the 2nd layer, so far I have been totally eyeballing the strakes. No bands or dividers so far. I suspect that when I get down to a 2" - 2 1//2" space between the upper strakes and the lower, I will need to inject a single band and use the dividers to help shape the last few sticks. I still gotta gripe about the wood in this kit. It is really sad. I find it almost impossible to sand. It starts out feathered and frayed after cutting. But even sanding with 1000 grit sponge it just keeps splintering. The surface of the wood is totally destroyed, tons of flakes and feathers. I'm tempted to shoot a pic with a macro lense close up to show just how poor the wood is. Here you can see some of the splintering. This was after using 1000 grit sanding sponge. More splintering. Not just at the strake edge, but look closely at the 3 sticks. This was after using a 1500 grit sanding sponge. Nice downward curve on the upper strakes. Here you can see the pathetic irregular thickness of the plank sticks. I have a bunch of walnut stock which I could use and probably eliminate a lot of these problems. I am resisting using that stock because I still have this gut feeling that I may at some point just trash this entire build. Don't want to waste good wood for this project.
- 62 replies
- lancia armata
- panart
Sparky - interesting thought. I do sometimes get so intense on one way of thinking that I overlook the obvious. After reading your suggestion I immediately jumped up and out to the shop to check it out. Sadly, flipping that deck base just made things worse. But I do appreciate your slap in the face to sometimes rethink things.
- 62 replies
- lancia armata
- panart
Brass Blackening Building Time Survey
mikiek replied to Dave_E's topic in Metal Work, Soldering and Metal Fittings
All of these responses are a good reason to consider painting the parts black rather than trying to corrode them into a black condition. Much simpler and totally foolproof. -
Taking an ambitious start on layer 3. I laid a wale on both sides. On layer 2, I had to deal with a planking curve that basically went upwards a little ways back from the bow. You can see some of that in previous posts. This ended up with a lot of bending which IMO never works out all that well. For layer 3, I decided to aggressively reverse that pattern. After the wale I immediately added a 1:2 stealer to start to bring that same curve downwards. The next few sticks will be individual, but given the number of stealers required for layer 2, I will be watching closely. It will probably require more stealers and those are much easier applied in the wide area directly below the wale. On layer 2 I think I waited too long. The stealers were added where the hull shape had lots of changes - down around in the deadwood. I have been bitching about the wood for this kit and I have to say it is only getting worse. The sticks for layer 3 are pathetic. Uneven trimming on the edges, extremely poor thickness dimensions and the overall quality (or lack of). When trying to cut or sand an edge a little off angle the sticks feather and fray to a ridiculous degree. I try to sand away some feathering and that only brings on more. The walnut sticks are garbage. Here's some images of where I am 1/2 of the first stealer - You can already see that the plank curve is working downwards rather than upwards like in the 2nd layer. As I mentioned above, each strake is being cut and shaped and the same strake on the opposite side is being duplicated. So far this has kept both sides of the boat in sync. Cisco - this is actually the proper way to use the pin clamps. You stab the pin in the substrate, and then use the edge of the knurly part to actually hold something down. This leaves no holes in the final layer. This works most of the time but there will be occasions where where you have to stab a pin in the final layer. The plank edge obviously still needs some shaping. But you can already see how we are initiating a curve downwards. This truly helps the overall layout of the strakes. That upwards bend of the curve on layer 2 really gave me a lot of grief, Looking forward, not sure what this piece is called but it is obviously not sitting square inside the hull. Major gaps on each side. Not sure if this is by design, or due to the inability to glue hull strakes to a frame which ends up compromising the hull shape. Richard, if you are still following, let me know if you experienced the same issue with your build. Have also been doing a ton of sanding on the inner planking. I thought a lot of it would be covered up, but you can see by the above pic that almost the entire inside hull will be visible. Bummer!
- 62 replies
- lancia armata
- panart
