Everything posted by Slowhand
Travis, I am a long way off putting the tops on the bulwarks as I still need to plank the decks and then the lower half of the hull. Thinking of using a steam box which I’ve made but yet to use, haven’t bought he steamer yet. Looking at wood in the kit it will be interesting to see if it bends enough. Surprised if it bends with the admirals tongs. As a last resort I’ll buy flexible beech and stain it. That always works for me. steve
Finished the planking above the wales, but looked too light, I had tested samples of African walnut with a coloured Danish Oil and it looked perfect just about dark enough. Coating the ship with this oil and what a disappointment every blemish, wood glue stain was revealed. Lightly sanded down and reapplying no better, tried staining with medium oak no better. Everything had to come off, continuing without being happy with the hull would be a killer. Looking at my San Martin, covering with mahogany and finishing with diluted poly u varnish has aged well so that’s what I did. Going for the chunky finish using the grain and the texture of the planking to give an old galleon look. Looking on the bright side I can remove planking on hulls and decks quite easily and redo.
I saw a very nice planked deck of the OcCre Albatross. Can’t find the post now. The lime planks had been finished with Shellac and the slightly different grain on different planks had been high-lighted . Buying Shellac flakes, orangey ones in particular is quite easy but the methylated spirits is more difficult, much of it has blue dye added. Then I read that ‘sanding sealer’ which you can buy in UK has the same purpose and can be used to French polish. In fact I have some in my shed😊😊. I wonder if they are the same or is it worth making the effort to make my own Shellac?
After a few weeks with my new Proxxon Table saw toy, I am confused about the mitre ruler and fence. There doesn’t appear to be an easy way to cut a length a distance of 10mm from the blade. Positioning the fence at the 0mm mark on the ruler doesn’t place the fence right next to the blade, even adjusting the sub mm knob. I suppose I can use a steel ruler to place the fence 10mm from the centre of the blade but it makes the fine adjustment thumb wheel a bit of a gimmick. Stop press - changed blade to a 0.5mm kerf and fence is much closer to blade when at zero position. 😄😄 Awaiting digital callipers as ageing eyesight makes viewing the gauge harder and specs add distortion. Going old is great 😢😢
Steven, I carved the profile in the lime by hand with a bit of sanding and in couple of hours ready to slice up with the saw repeated for a two more profiles. Kiln dried lime so the very best quality. Surprised how clean the cuts were as to me the blade looks looks quite big with a kerf of 1.5mm. Got a bit carried away making brackets but galleons of that era looked quite ornate, expect Spanish to be similar to Dutch and Venetian. Painting curtesy of Rijk Museum, Netherlands.
Byrnes Table Saw on Ebay UK
Slowhand replied to No Idea's topic in Modeling tools and Workshop Equipment
Hmm a bit expensive £1250 -
Been awaiting arrival of my new toy a table saw, intended to use some walnut wood turning pen blanks for brackets for stern balconies. Too hard and carving by hand with gouges set my tennis elbow off. Some dried cherry proved too difficult to carve as splinters kept breaking off so back to my old friend lime. Carved effectively a small architrave and sliced it with the Proxxon.
Whilst concentrating on getting windows the correct shape I lost sight of the fact the lower balcony should in line with step above transom and the windows would need to be lower. What to do? Without too much bother I cut out and raised the step and replanked. So now it’s on to carving the wooden brackets similar to Costeo’s version last image that’ll be interesting. As I said when I began no exposed metal or ply in this build.
I’ll certainly keep an eye on this build, very interesting subject in the thick of the action at Jutland.
- 78 replies
- Derfflinger
- Flyhawk
Lind, This is all I use a LED panel using 240v power. I find placed at the side creates less shadow on the side of ship I’am working on. Not particularly powerful 11.5W. I bought it in B & Q a UK superstore. I prefer natural daylight whenever possible. SORRY misread your post you meant internal lighting in the ship.
I think you’re doing a great job on the Hood the wooden deck is well worth the cost. The amount of detail in these kits is amazing and building one is a job for the insane. I tried the Invincible and had major problems with the casemate guns and the bridge. Then she took a hit from the Derfflinger 😂😂. Tempted to try again.
