Posts posted by Rainbow
Hey folks,
Steve, I'm interested in your log as well as in the model itself which I was considering to do in my break period from Corsair
May I use this opportunity and ask you what do you think about the model quality? The instructions? Since eventually I'll pretty much just follow them and use what's inside the box and will be more than happy to get some feedback
- Canute, Elijah, CaptainSteve and 1 other
4
Just wondering are there any updates/news regarding the 1/64 of Victory?
- Sjors, zoly99sask, SimonV and 3 others
6
Hey Joe,
Yeah I think as well I'll need some sander soon since it's annoying and really slowly to do this manually (feasible but still...).
If you have such disk sander ->
I see it's application but for example how I'll sand the planking (or balsa wood below it if needed) with it? Can't really imagine that.@Elijah - you mean hand dremel with some Sanding Disc/Sanding Band? That might be more useful I guess.
Or might continue with this haha
- Jolley Roger and Elijah
2
2
I'm not sure about your question, but I'm glad you were able to find some balsa!
I mean about the wood stripes for the planking - do I still need to soak them in water and then use the above bending tool or just use the tool right away
From this video I get the idea I can get without the exposure to water
So after all I decide to follow what everyone said and fill some of the frames. Also I was finally able to manage to obtain 1 balsa wood stripe (1000x100x20 mm).
It's a lot easier and faster to work with it
The only "problem" is cutting it with the blade might be a little bit picky since it's 20mm width but other than that is pretty easy
Also I reuse some of wood that remained
Also I'm expecting few more tools one of which is this one:
Do I still need to soak the stripes when using it (ended with them instead of the heat one kit that I posted before)?
Hmm can you point where exactly (like with picture)? Since where I put it right now was already runway through the entire frame (by the kit and so was in the manual.
Starting from the central frames, glue and pin the master strake, no. 38, using the frame slots as a guide. Line the hull on both sides simultaneously, i.e. for each strake fitted to the left side fit its opposite number on the right side.
Hey guys,
I'm watching Black Sails serial and was wondering does some of the ships from it exist like a wooden model kits?
Especially the Spanish one -> Urca de Lima since it seems to be really good looking.
https://en.wikipedia.org/wiki/Urca_de_Lima
http://black-sails.wikia.com/wiki/Urca_de_Lima
As you might have guess I had the same issues on the other side as well
Not so bad from the inside:
Hopefully all this stuffs will be covered good after the final planking/lining
Of course as with all parts until now, the fitment remains a problem...
Same for the stern:
For which I also had a bending problem
P.S.: Can you recommend me a tool (even with link) that is used to bend such parts or all parts? Because I start to get the feeling that without such tool it's pretty much impossible not to break them
- BLACK VIKING and Elijah
2
Thanks for the info Paul!
Actually to prove you are right today I had the first "mistake"
Which kind a make me angry/upset. But then I remembered I've seen that in another build log and I think I manage to fix the problem
Now I'm working on the other side and I know it will be tight fit but I hope everything turns out just right
Will keep you up to date guys
USS Constitution by xken - Model Shipways - Scale 1:76.8
Insane details! Really great build and so much notes and well documented, nice.
