Haliburton
Everything posted by Haliburton
  1. Thanks CDW Scott
  2. Hi Chris, you can be sure that this site will be where the build log goes, that project is a bit down the line however! Scott
  3. Thanks Keith, I will check that out! Scott
  4. I have the Trumpeter 1/350 Warspite and am wondering what after-market photo etch upgrades are out there that are compatible with this kit. Everything I've seen is geared to the Academy version. I wonder how much trouble I will have if I use the Academy photo-etch? Thoughts? Thanks - Scott
  5. The case was well worth it Mike - it compliments the build so nicely! Scott
  6. Congratulations on a fine build Mike! Please show us the cased model when you can. Scott
  7. Hi Mike, it's been a long time since I dropped in on your build, wow it is looking great! I love your detailed photo narratives! Scott
  8. Mike, this is coming together really nicely - great work! Scott
  9. Do these volumes and accompanying plans come with a recommended bill of materials re: wood types and quantities? This would be a far future project for me, but was curious. Scott
  10. Hi Mike, a great update and as Per said a really well done tutorial on how you use the dividers. Scott
  11. Great info, thank you Bruce Scott
  12. Hi Mark, on-line, Lee Valley has a taig miniature lathe which can be bought in either a wood or metal configuration (same price). You can then buy the accessories to change the configuration depending on which one you started with. Based on your note however I wonder if this is a situation where the twig unit doesn't do either wood or metal very well. Scott
  13. Hi Lehman, it looks like the bed for the taig is 15 inches? Is it easy to convert wood to metal?
  14. Thanks Nirvana for getting back to me - Scott
  15. As I continue research on lathes I wondered if there are any experiences with the taig mini woodworking lathe on offer from lee valley? Looks like you can add a conversion kit for metal. Nirvana, is that the set-up you have? Scott
  16. Do you have a scroll saw? I wonder if that would be easier. Scott
  17. Mike, maybe you can experiment with a different stain or a stain pen to even it out a bit, or maybe some surface sanding to lighten the dark areas? Scott
  18. Hi Mike, wow you are making great progress on this. I recall in another build log some discussion about the fact that there are no oars. Are you going to scratch some up? Scott
  19. Thanks very much John(s). texxan5 John, I'm still doing research but will let you know if I end up wanting to go the Proxxon route. Scott
  20. Thanks Per - will check them out. Lots of positive feedback on the site for the proxxon db250 too.
  21. Thanks John, what is the particular sherline model you are using?
