HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
petervisser
Everything posted by petervisser
  1. While adding coats of paint to the hull, I decided to make a custom stand for the model. Billing did supply one, but it was rather small. I was able to buy a small sheet of mahogany at my hobby store in town and I had some mahogony strips so I was off to the races. This handy little device gave me the inside shapes of the cradle. I normally use the drawings to get the shape, but the bulkheads were not included in them. The stand without varathane. The finished stand with some felt to protect the hull.
  2. Thanks again for the encouragement everyone. This really is a fun boat to build and I am enjoying it very much. After the primer coats had cured, I decided to give the rubbing strakes a couple of coats of finish white. Humbrol paints are my preference and I have had good results with all my models with their enamel. When the white had dried I applied the Tamaiya masking tape to mask the strakes. I had mixed results with this as I used short lengths of tape to mask. It might have been better to use a single length. Live and learn... As you can see, it is going to take several coats to cover the white. I was really excited to add some colour to the model at this stage. With three colours making up the hull, it took a bit of planning and masking to finish the hull.
  3. Hi Gil, Well, I for one had to do a double take to determine which was the model gunport and which was the real one. Beautiful work indeed. Thanks for re-doing your build log. Lots of great techniques to emulate! Peter
  4. Hi Robert, I just caught up on your build log of the Mars and really enjoyed it. Your techniques are very well carried out and your model looks beautiful. Thanks for sharing your work. It's an inspiration to me to try some of your methods. Happy building! Peter
  5. While prepping the hull and waiting for the paint to dry, I tackled the side boards and the rudder. I decided to laminate both sides of the rudder and one side each of the side boards with mahogany strips I had on hand. They add a little more wood lustre to the model. I only put the mahogany strips on the outboard sides of the side boards and painted the inboard sides the same colour as the hull. On the right, the strips are glued to the laser cut side board, and the left one has the extra material removed with a combination of X-acto knives and sanding block. Here is the laser cut rudder ready for its strips to be laminated. The mahogany strips are applied and ready for some varathane. Here the components are ready. Billing supplies decorative decals for these pieces that I will apply closer to the finish of the build.
  6. Thanks very much gents. "Atta boy's" are always welcome. To start the hull painting process, I used a sanding sealer primer on the wood. I applied a couple of coats and smoothed the hull between coats with some extra fine steel wool. I wanted a nice smooth finish. This is the product used to prime the hull. The first coat of primer applied. The stand is temporary as it was surplus to another model. The hull is now ready for the top coats.
  7. Hi Neale, Great build log of your Victory. Your technique for planking your model is VERY comprehensive and you have helped many of us understand how it can be done with greater accuracy and correctness. Thanks for taking all the time to post all your excelllent photos. Peter
  8. Hi Gil, I have just finished looking through your fantastic build log of the Victory. Stunning workmanship with lots of great build techniques. Thanks for posting all the great photos of your progress. They are inspiring to be sure! Cheers, Peter
  9. Although not called for in the plans, I decided to add some rubbing strakes to the hull. The lower ones helped in that it made for a nice pin stripe and more detail. I would expect an actual vessel to have one there also to protect the hull when tying up. The upper ones were added to help support the cap rail. There wasn't a cap rail supplied with the model. The plans suggested a 1.8 x 2.0 mm strip be used, But I didn't like that idea. So I used some small square stock to glue to the outside of the gunwale so to allow the cap rail something to sit on and adhere to. The strakes add a little something to the hull details. Now I am ready to paint the hull.
  10. Thanks for your kind remarks Jan and John. Yes it is a shame that Billing doesn't market the boat as a working vessel. It would make an interesting subject. However, a colourful yacht has a bit more appeal to the masses... like me I guess! Mr. Billing is a little stingy with the wood on this particular model. Although the hull panels were of fairly good design in that they laid on the bulkheads (except for the one I pointed out earlier) the two middle panels were a tiny bit short on length by a millimeter or two. I could have sanded the transom down so that the panels reached the after face of the transom, but I decided on a different approach. I glued a thin sheet to the transom, which created a small gap at the sides of the hull. After sanding the extra sheet to the outside dimensions of the transom, I filled the gaps with wood filler. Here you can just see that the hull panel was not quite long enough. Here I added the sheet to the transom to create the gap. Another view also showing how the panels did not quite meet up. It was an easy fix to deal with both these issues. A filler piece is added to the gap between the hull panels. A little wood filler to fix Mr. Billing's mistake... Here a closer look. Using my sanding block after the wood filler dried, hid the slight defect perfectly.
  11. Once all the panels were in place and the glue had dried, I could remove the dowel heads and fair the hull. This was a very satisfying stage because the hull was nce and smooth, ready for fondling... She is now taking on a nice shape, and will soon be ready for some paint.
  12. Thanks for all the nice comments guys. Yes she is a pretty little boat and it is a shame that it is not more widely available. It makes for a very nice beginners kit. Sjors, I could read your Dutch! I am able to read a little bit still after all these years. I was a little tike when we came across on the old Rijndam. This summer my wife and I are coming to Holland again for a holiday and visit with family. We are renting a motor yacht and sailing the canals in Friesland with my cousin. Hopefuly we won't run over any zeeschouws.... At any rate, here are a few more pics of my model... Going back to the hull planking, I glued the panels to the bulkheads using super glue and held them with finishing nails so that they stayed. They are not the nails I would normally use because they are way too big. But they were all I had at the time. Once the glue had cured I removed the finishing nails and replaced them with wood dowels. I also planked over the bow deck with some mahogany strips I had laying around. I used black thread between them to simulate the caulking. I made sure to drill some pilot hole first before pushing the nails home. Here the wood dowels have replaced the finishing nails so that the hull can be sanded smooth. No matter how hard I tried, I ended up with a gap between the panels. I simply made a wedge to fill it in. The gap on the other side was much smaller and was filled with wood filler.
  13. Hi Buck, Yes, I love them too and have a couple more waiting in the wings! Peter
  14. I am skipping back to the cabin bulkhead here so you can see how I made the windows. I learned a trick from a fellow modeller on the old DDM website. He was a Russian who was building a Corel Bellona. On his model he used a floppy disk sheet to simulate windows. They had a very realistic look on his gallery windows and I have used it here on this model to good effect. I have often thought back to his model and wondered how he is getting on with his project. It was one of the finest models I have ever seen.. These disks are becoming rare with the advent of thumb drives, but I find some all the time at work squirreled away. Just rip open the plastic case and the perfect window material presents itself. Here you can see the window material in place. The only thing missing is the lace curtains the Dutch use to dress their windows! Can't have it all...
  15. Thanks John. Coming from a Dutchman, that means alot! I started building this model last year and had a build log going on the previous version of MSW. So please don't think that this model is being built at lightning speed! The next step in construction was fastening the hull sheets to the bulkheads. I steamed them all and had nice bends applied so that there would be little stress when they were applied to the frames. I temporarily attached a strip of wood to the keel so that the garboard stake would be tucked under and held secure while the glue dried at the bow. Here the garboard strakes are in place and the next hull panels are ready to be applied. Each panel is laser cut, so it makes life very easy. I marked the panel with pencil so I know where the bulkheads are. The panels are the perfect shape and attached to the bulkheads nicely. I have made it a habit of using wood dowels to help hold planks, or in this case, hull panels in place. It is added insurance that they are on the model permanently.
  16. Hallo Piet and thank you for the fascinating thread you have begun regarding the submarine on which you father served. Such an interesting story and one even I can relate to. My mother was in Indonesia with her father and mother, brothers and sisters when the Japanese invaded. Five years of total hell. You have chosen a subject vessel with which you have some personal history and there are none finer. I will follow your log closely as there are not many of this type of vessel featured on this site. When I was younger, I read many books of fiction regarding the submarines of WWII. I enjoyed them very much. Good luck with your build. I'm sure it will be very satisfying. Cheers, Peter
  17. Onward ho... Next step is to add the hull sheets to the bulkheads. There are only three per side so "planking" in not the long drawn out process that a normal ship is. However, prep work is still important and the bulkheads have to be bevelled to avoid sharp kinks. I really like my sanding blocks for bevelling bulkheads. Now that the bulkheads bave been sanded, the hull panels can be attached. As you can tell, some bending will have to take place before they can be glued in place. The kettle is great for bending these large sheets of ply. I just had to hold them above the spout while bending them to shape. These panels are simply dry fitted to the bulkhead frames.
  18. Hi Wayne. No I don't mind one bit. Hope you enjoy the ride! The next stage involved adding the deck, the cockpit sole and the lazarette top. The deck has quite alot of sheer and I had to bend the sheet so it conformed to the tops of the bulkheads. For this I use the plank bender extordinnaire, the electic kettle! Just make sure you wear some heavy leather gloves. The sheet and kettle exhaust in pretty toasty! I've used a few plank bending techniques in the past including Billing's tip of using a candle flame. I had a few singed planks and finger tips using that method. The kettle is my favourite by far. In the photo above the deck is in place as well as the cabin and cabin top. All pieces are laser cut so assembly is a snap. However, I did not use the laser cut piece for the cabin top. It was a single sheet of thin ply, and I am at a loss as to how Mr. Billing meant us to form its shape. There in not only a sheer bend lengthwise, but also a camber. I opted to use strips of mahogony that I had laying around which I was going to lacquer. That way the planks could bend to the sheer as they conformed to the camber athwartships. In the end, I decided to paint the cabin top. I used mahogany strips to laminate the cabin bulkhead and lazarette. The printed sheets don't compliment the model one bit. It added a bit of work but the results are worth the effort. I also used narrow strips of mahogony to simulate a deck grate on the cockpit sole.
  19. The framing was a pretty simple affair and I just had to make sure that everything was square. A couple of stringers are added to secure the bulkheads and add a little support to the deck. All the frames fit snuggly to the keel. It's a little hard to imagine that this will look anything like a pretty boat at this stage. Stage one complete!
  20. Hi Everybody, This is my attempt at building Billing's zeeschouw. It is a great kit for beginners I think as the constuction is simple and some basic skills can be acquired pretty easily. The kit won't take years of building so one shouldn't lose interest during the construction. I decided to build it because I noticed lots of these models in Dutch front windows and they looked pretty fun. After the Unicorn, I was ready for a nice easy model to build that was also unique in its own way and pretty to look at. Zeeschouws were originally built as small fishing vessels in the Netherlands. As fishing became more efficient with larger vessels, this type of boat was converted to sailing yachts for pleasure boaters. You can see many zeeschouws sailing in the waterways of the Netherlands. So without further ado... Here she is as dsplayed on the box. Unfortunately, the kit is not widely available and the best place to purchase one is through an online store in the Netherlands. I bought mine while on holiday there. This is the box the model is packaged in. Billing has chosen to ship three different models in the same box to save costs I presume. The model the box contains is marked with an "X". And so the process begins. A small building board is required along with some square stock to start the framing on the keel. These are not included with the kit. All the pieces are laser cut and fit together nicely.
  21. Hi Hamilton, I used Lennarth Petersson's book, "Rigging Period Ship Models" when I rigged the Unicorn. He has a series of easy to follow drawwings for the standing and running rigging. He uses a frigate to illustrate his drawings, but the principles would be very much alike. I highly recommend it. Cheers, Peter
  22. With the coil in place, and all lacquered up, I use an old paint brush handle to hold the coil in place to dry. It's best to leave a short tail which ensures the coil won't unravel while it's drying. Here are some pic's showing the last of the process... Push the coil towards the deck. If it is the right size, it won't have a tendancy to spring back to the horizontal. The paint brush handle helps hold the coil in place. Here, several coils are being done at once. Once you get going, it's best to do several at a time to keep the momentum! I have kept some tails to these coils so they won't unravel. And voila! All done! On to the next ones...
  23. The process continues with adding more loops the coil as described in the last post. With each loop, give the coil another coat of lacquer. This ensures that you previous loops won't unwindl. Don't worry about applying too much. Once dry, the matte laquer won't be noticeable. Using the hook, I am able to make all the coils the same diameter. Once you have a few coils looped, the rest will go on a little easier. When the desired number of loops are made to the coil, dab a little more lacquer to the coil to even out the strands.
  24. Hi Everybody, Sorry for the interuption. And yes, supper was delicious! The next steps require a bit of dexterity. Give the line a little twist and form a loop. Again, right hand lay - clockwise, left hand lay - counterclockwise. With the "riggers" tool, walk the loop towards the pin as shown in the picture below. Slip the loop over the top of the pin and apply some lacquer to help hold it in place. I have a hook tool that I use for tugging on the loop to see how if the coil is the correct diameter for reaching the deck.
  25. Hi Everybody, Ian asked me to re-post my method of coiling down lines on the belaying pins for the running rigging. This in my preferred method for doing so. I do not want to claim that this is the only way to do so. Some of you have devised clever ways of doing this task. However, this method has worked for me for the past 4 models, so I'm sticking with it. It does require lots of patience and a bit of hand eye co-ordination. But with a bit of practice it will come naturally and seem less arduous. I have devised a simple tool which allows me to coil the line from the opposite side of the model making it easier and practical. It is made using a paint brush handle with the bristles removed. A hole is drilled in the end which allows a flat toothpick to be inserted. The wide side of the toothpick has a V filed into it to form a notch. The toothpick is a weak link which will break first before doing damage to the model due to overstress. I also use copious amounts of matt lacquer and a small paint brush for applying the lacquer. The first thing I do is wax the line. This removes the fuzzines the line may have and gives it some "grip" when its turned off at the belaying pin. Run the line from its beginning on the mast or yard, through its various blocks and down to the deck and pin rail where it terminates. Make sure the tail of the line is a good 12 inches (30 cms.) so you have something to work with. You will need it to secure the line from the opposite side of the model. Lead the line under the pin rail and form a figure 8 over the top with a half hitch. The beeswax comes into its own here as it helps hold the line at the pin without backing off allowing slack in the line. As insurance I put a drop of CA glue at the half hitch when I'm happy with the lead and tension. Now the "fun" part. Apply some lacquer along the first 6" (15 cm) from the belaying pin. This gives the line some memory as you coil the line around the pin. With right hand line, coil the line clockwise around the top of the pin. Left hand line is coiled counter-clockwise around the pin. With each coil around the pin, apply a bit more lacquer. This helps retain the number of coils formed so far. Twisting the line in the direction of the coils helps also. The coil diameter should be such that when it is pushed down to the deck, it will stay in place and not spring horizontal . The first coil should be of this diameter and the subsequent coils made to be the same. I form about half a dozen coils at each pin which appears to be adequate. Hopefully the photos that accompany this post will make the procedure make more sense. These are the tools used for this fun and sometimes frustrating little exercise. Pictured are the beeswax, lacquer, and "riggers" tools. If you look closely at the picture above, you can see why it's necessary to work from the opposite side of the model. The line is lead down from the mast, hooked round the bottom of the pin and half htiched round the top half of the pin. The wax helps holds the knot in place until the CA glue is applied. Next a bit of lacquer is applied to the line to help make it a bit more manageable. More later, supper's ready....
