Brucealanevans
  • Content Count
    307
Everything posted by Brucealanevans
  1. Thanks for the likes. Each time I make a decision about what to do next I lean towards something “different”. Don’t think I’ll ever build another masted gunship. Been there done that. If I ever finish this build I believe the galley is next. After a visit to Malta a few years ago I will modify the La Real (Dusek) to at least resemble a Knights of Malta galley from the era of the Great Siege.
  2. Yup there is a lot of exacting work in the construction of this hull. I have a Dusek galley and Grenado in my stash but I don’t know if I’ll get to them. I’ll be working on the Confederacy for some time yet. would like to build the galley but may give the grenado away. I have a very fiddly Fokker triplane model I’ll eager to build. I may take that to our second home to work on when we spend time there, as I would only need a smaller set of tools and no need for my power tools or airbrush stuff. Running out of display room in the house anyway - 5 ships not including the current p
  3. Milestone of sorts today. I finished the exterior of the hull - rudder constructed and placed, and photo-etch bits including the sweep port hinges. Next work day begins work on the interior! In general I'm reasonably pleased with things so far, given that this model is at the bleeding edge of my abilities. I didn't want to take the rudder off after the number of times I had pins snap off, so I've decided to leave it in place and fix it with a couple of clamps (removed for the pictures) to protect it from inadvertent forced movement.
  4. No I didn’t use those. In fact once the false deck is on the holes for the short mast “stubs” - this is an admiralty model - are quite shallow with the central spine of the frame just below the holes. I suppose if one wanted to do a fully rigged model one could cut out from the frame and use those for support. or they’re just for setting the angle of the abbreviated masts. But then why 2 of each. mid PM Chuck P and ask him.
  5. Returned from a month at our second place in Marblehead, MA (no shipyard in the house there at this point) and got back to work on this monster of a model. Have finished up the stern and quarter galleries with all decorative trim items. Pretty happy with the result given all of the minor mis-alignments, insufficient sandings to follow the prescribed curves, and so on causing multiple work-arounds to have things at least OK in the end. Unfortunately, it does look like the yard-hand putting the letters on the stern had a bit too much grog. End of a chapter. I cleaned up the s
  6. Quick question: I was curiously trying to fit the drop decoration metal piece underneath the quarter gallery. The instructions say it is notched for the wale, but it isn't, and for it to fit a truly prodigious amount of filing would be necessary to create a notch to allow it to lie against the sides so that the upper surface of the casting fits against the "floor" of the quarter gallery. Is it supposed to be notched as the instructions imply/say? Do I need to request replacements if they are (now) notched? I shudder to think of the work and metal dust that will be required/creat
  7. Finished the transom and quarter gallery windows, and re-positioned a trim strip on the transom to make a more symmetric appearance and make certain of a constant height space for the decorative strip below the windows and the "CONFEDERACY" name letters. Next will be the decorations, but that will have to wait until after our 2 visits out east to put our Marblehead second home in order. The closeup makes the black paint look bad - much better in person.
  8. Finished the transom and quarter galleries, ready for the windows. This involved a lot of re-work and not an inconsiderable amount of wood filler. Every slight error or discrepancy in the placement of the stern frames, side blocks, curve sanding, and placement of the initial planking strakes can add up. Doing this again, I'd be even more meticulous about precise placement with engraved lines, distances prescribed, and sanding the gentle curves of the stern and the transom prior to placement of the transom piece. I think building the rear of this model accurately, beginning with the frame
  9. Brief side trip to install cap rail on the transom. note to those who follow : if you use the laser cut cap rails on either side (as I did) since the exposed 1/4 “ surface is cross grain it will stain darker than the thin strip in the middle that completes the cap rail. (Noted after staining by this builder. Not a huge deal but appearance would be improved if I had anticipated this) Maybe a sealant would help
  10. Finished the bulwark thinning. Not my favorite modeling job. Only working on the model a couple of hours a day so took a while. Now onto the quarter gallery construction!
  11. Chuck:
    a quick Confederacy question.
    when thinning bulwarks to 1/8 “ at the top, what should I aim at at the deck level so that everything works out for interior planking, deck planking, framing etc.
    thanks in advance.
    bruce
  12. I need some help here from Confederacy veterans. I know I need to thin the bulwarks at the top to 1/8”. how thin do they need to be at the deck level for the deck planking to work out?
  13. Finished up the initial work on the stern and on the bases of the quarter galleries. Some of the alignment of the pieces was not perfect, but by and large I was able to compensate. Getting all those pieces starting with the stern frames and the associated bits in perfect alignment was the hardest thing on this build for me so far (except for the endless planking). Now on the the bulwark thinning (UGH). I have not been looking forward to this from the very start.
  14. Received my replacement piece from Model Expo. Shaped, stained, and fastened the sternpost on and trimmed the keel to fit. touched up some staining where worn by the clamps of the building board. In general, reasonably pleased. Not a great look at the bow where the planks below the wales meet the bow stem, but acceptable (except when I look at it of course) Now ready to start on the stern.
  15. While waiting for my replacement piece from Model Expo for the Confederacy, I got twitchy modeling fingers. So I turned to the very first ship model I built back around 1980 - Mantua Model 1:50 HMS Schooner Sharke. I don't remember exactly why I cut that project short after doing most of the rigging. I never properly dealt with the 2 yards after putting the uphauls on them. Just tied a string from mast top to top yard ends and down to main yard tips and then to a belaying pin just to hold them in place. Also didn't mount the falconets - as I recall had trouble getting the uprights fo
  16. Finished the planking. Only did a couple of strakes per day so took a while. A fair amount of fiddling. Didn't (I guess) taper the bow strakes enough so ended up having some severe tapering and several drop planks added to the final 2 belts. In the stern, ended up with the same problem, probably due to the fact that I wrapped the black painted wales around the stern but didn't take that into account when I started the planking below the wales and blindly added widened planks per instructions. Overall, met my goal of not requiring filler/painting so I'll be able to clear finish the plankin
  17. After planking 10 strakes below the wales on both sides, I inspected the bow configuration. I was very unhappy with the job, and determined that the line was wrong, especially with the planks diverging away from the foremost bulkhead. The problem appeared to be insufficient/downright wrong faring of the block in front of the bulkhead leading into the stem, which should have been gradually beveled better as it moves down towards the keel. The error forced a more bluff contour to the planks which then could not fully contact the first bulkhead. Ugh. So, with a heavy heart, I removed th
  18. Finished port side first planking belt below the wales. Only doing perhaps 2 strakes per day - each plank, especially at bow and stern - is a mini project with bending, twisting, beveling, etc, to try and get it neat enough that no filler or painting over filler required. Would like to be able to just give a wipe on poly finish to these planks. The edgewise bending jig included in the kit is a real life-saver! Bow especially hard and a bit wonky on this side, but overall looks ok. Have given the planks a preliminary sanding to make sure of the look and fit. Will clean up the meeting
  19. Just finished the starboard side above the wales. Now ready to begin planking below the wales. My goal is to go slowly, treat each plank as a project, and strive for an acceptable look without having to resort to filler and painting. We shall see. Reasonably happy with the look so far. Measuring midships yields 33 1/8 “ planks. Plan 11 in initial belt in this building board configuration on each side before turning her over to work on the bottom belt.
  20. Finished painting and molding strips on the port side. Reasonably happy with this so far. I do need help: Looking ahead to planking below the wales I see the strakes at the rear are run off the frame and sanded smooth prior to adding the stern post which, according to the instructions "will be added later" The finished pictures of the planking below the wales before beginning work on the quarter galleries and the stern, however, show the stern post in place. I can't find in the instructions where and exactly how it is added, which seems to involve making an appropriate hole in t
  21. Finished the channel wales doubling and the "black strake" and stained everything (on one side). Now placing the main wales that will be black. I'm pre-painting the beveled edges so that I don't have to do any touchy taping/brushwork to get a nice sharp border. I did the aft end first since the bends/twists involved were the most intimidating so I went there first. As Mark Twain supposedly said, "Eat a live frog first thing in the morning and nothing worse will happen to you all day." Or something to that effect. When these are done, I'll sand and then finish the black pain
  22. Finished the planking above the wales. Cut out the quarterdeck gun port lintels and touched up the red paint. Did a fair amount of sanding of the planks. Almost ready to (gulp) stain what's been done so far. A few of the strakes are a bit rough and will require a bit more sanding before that. Will paint when I'm ready to put on the trim pieces - likely after I add the 3 lower wales and double up all the wales.
