Content Count
307 -
Calendar
Everything posted by Brucealanevans
ALERT Lesson learned: stain first, THEN place the monofilament pieces. I thought I was very careful with the glue but still ended up with many halos after first staining. Had to spend time touching up with matching paint. Thank heavens this is a slapdash beat up looking ship and end result was ok. Will give stain a sanding when dry, then wipe on a light final coat as I did with the inside.
- 67 replies
- philadelphia
- model shipways
Not my original idea. Chuck showed this on his barge prototype. Unfortunately here I had over 700 to do on the outside (many fewer inside. Just finished this morning. Did a google for black monofilament line and picked one supposedly 0.4mm diameter and used #76 drill bit. I think it came from Japan.
- 67 replies
- philadelphia
- model shipways
It's a fun kit because of the scale, although a bit of a monster for the same reason. I have an almost neurotic love of small detail and I think this kit is going to take me down that rabbit hole! have fun. Thanks all for the "likes"
- 67 replies
- philadelphia
- model shipways
Prior to staining the exterior, I've been working on placing the nails for the exterior planking. These were iron and clearly visible, as on the modern reconstruction. Drilled all the holes with a pin vise, slightly widening the entrance with a sharp awl. Placed short pieces of black mono-filament held with the needle nose pliers (tweezers don't work due to twisting or "snapping away" of the line piece) illustrated after dipping the end in a drop of CA. Then cut each nearly flush with the flush cutter illustrated. The second picture shows a row of holes, a row filled with the mono-fi
- 67 replies
- philadelphia
- model shipways
Added "nails" for the ceiling and decks with mono-filament line dipped in a touch of CA, inserted into pre-drilled holes, then clipped with a flush-cutter. Stained the interior. To get the used-up look sanded the central "traffic" areas after the first coat of Minwax stain dried and applied another light coat. Put in the knees and coaming with nails and bolts simulated. For the bolts cut out small circles with a punch from a card colored with magic marker, punched a small hole in the center with an awl, and slipped over a protruding piece of mono-filament line, glued down, and clippe
- 67 replies
- philadelphia
- model shipways
Finished the ceiling planking. Had a look at the Smithsonian plans which arrived afterwards, tho, and the interior planking was wider than the 1/4" (6 scale inches) the kit uses. Oh well. Put the decks in - I cut the deck pieces into individual planks as I didn't like the scribed planking which ended up really highlighting the midline join between the port and starboard pieces. The cuts "lost" enough of the total width that I had to add a small piece to either side to make up the difference. Suggested by the Ships in Scale series. Also some fiddling due to the "drift" of the false keel am
- 67 replies
- philadelphia
- model shipways
Finished the exterior planking and gave it a first sanding. Next is the ceiling interior planking. Here are some photos of current status, placed on the unfinished stand.
- 67 replies
- philadelphia
- model shipways
Good work Elijah! I have the bottom strake to go before I finish the exterior planking. So much 3-4 day travel over the last few (and next) weeks that it's hard to forge ahead. Are you planning on adding the nails to the exterior in some fashion? The photos seem to show nails rather than wooden pegs. Fresh water boat maybe? Bruce
- 216 replies
- model shipways
- gunboat
I thought I'd share the procedure that seems to work for me for spiling planks for this build, where the planks, due to the scale and the construction of the boat, are quite wide. I fit a template made from card stock to the upper plank and then mark the laser tick for the bottom of the new plank at each bulkhead on the template. After drawing a smooth line with the help of ships curves through those points, I cut out the template and double check its fit. I tape the template over an appropriate width plank and trace the edges, then cut outside the line with a knife and smoothly sand
- 67 replies
- philadelphia
- model shipways
Started in on the "easy" part of the planking - the first 3 strakes that are constant width. Instructions state aligning with the tops of the frames, but at the bow that seems off and the profile plans show an angled taper on the very end of the plank to meet the angle on the bow-piece. Also if aligned to the top the spacing is off according to the template for the bow strake widths. So I elevated the top of the first strake at the bow and will sand the taper on them as shown on the profile plans. Now the bottom of the 3 constant width strakes line up perfectly with the hood template at t
- 67 replies
- philadelphia
- model shipways
Glued everything down. I put in lateral supports in two sites along the false keel and drilled vertical holes for later mounting. I have a print of a period map of Lake Champlain that I want to work into the base if I can. Floor boards in the cockpits added as well as a few support pieces for the ceiling planks in the cockpits. I'm going to go weathered/grunge look with this build. Chose a grey stain for the inside and stained the cockpit floorboards before installing them. I have made the bailing well grungier as you can see in the second picture. I did put some very thin plank
- 67 replies
- philadelphia
- model shipways
Well, I got tired waiting for the replacement piece to arrive, so I worked on the keel, stem, and bowpiece I removed from the incompletely lasered sheet and managed to bring them up to useable form. I still need the replacement piece for a number of other parts, some quite small, that were very poorly laser cut. But I won't need them for a while. Keel was straight, and putting the bow and stem pieces on straightforward, as were constructing the bow and stem rabbets with shaped and glued on pieces as shown below. I cemented the floor, and glued the keel to it. Oh, Oh!
- 67 replies
- philadelphia
- model shipways
Yeah I have Chuck's pinnace on the shelf with some boxwood strips. Not sure when I'm going to get to that!😀
- 67 replies
- philadelphia
- model shipways
Kind of a bummer... sat down to get started with the first pieces - keel, stem, and stern piece - and found the thickset wasn't laser cut all the way thru and cutting the complicated notches with a knife resulted in unsatisfactory accuracy and snapped bits along the grain. Checked the other thicksets (all ok) and contacted Model Expo thru their website to request a replacement. Oh well, enforced holiday in the shipyard while I wait. If I had some materials I've ordered I'd use the time to build the brick stove but they're not here yet either. I'll work on other projects
- 67 replies
- philadelphia
- model shipways
I would love to add one 1/24 (1/2 scale or possibly G scale) figure to this ship to visually establish scale. I love the crewmen I added to the Morgan for that reason. A quick search didn't find much. Any suggestions for sources? I have searched the forums.
- 67 replies
- philadelphia
- model shipways
With the Charles W Morgan safely in her case awaiting only a brass engraved nameplate before moving upstairs, it's time to start a new project (projects?). Going to start with the gunboat Philadelphia which I've had on the shelf for some time. I need a break from 1/64 fully rigged ship so the Granado will wait for this project to be completed. [note: Granado will wait a while longer] I'm looking forward to (super)detailing a 1/24 build with minimal straight-forward rigging (at least compared to the Morgan). I've ordered replacement blocks and line from Chuck, and gathered mater
- 67 replies
- philadelphia
- model shipways
Build log tagged as finished, and some photos of the model uploaded to the gallery. Thanks to all. I'm going to build the gunboat Philadelphia next for a change of pace, expecting NOT to take anywhere near as long as the Morgan did. Replacement rope and blocks ordered. While doing that I'm going to spend some time practicing wood/mill skills for the Echo x-section.
Charles W Morgan MS 1:64 by Bruce Evans
Brucealanevans added images to a gallery album in Gallery of COMPLETED Kit-Built Ship Models
3 1/2 year build of Model Shipway's Charles W. Morgan. Aside from the keel and bulkheads, a few laser cut pieces for crosstrees and rails, and some cast metal bits, this is largely "here's some wood, make it look like this" kind of kit. My first fully rigged ship model, so a more than a bit of a challenge. I'm pleased with how it all worked out, although as my skills improved I would have done some things differently and better than I did when starting. -
Brucealanevans posted a gallery image in Gallery of COMPLETED Kit-Built Ship Models
From the album: Charles W Morgan MS 1:64 by Bruce Evans
The crew are from Scenery Unlimited. Since this was not a naval vessel, I was able to re-purpose various "workers" as deck hands. -
Showing the capstan -
Shows the tackle used to hoist the blubber strips off the whale
