Everything posted by RGL
Milk delivery wagon by RGL - FINISHED - Miniart - 1/35
RGL replied to RGL's topic in Non-ship/categorised builds
Here’s a hint https://www.facebook.com/share/v/TtD4FpgcH8SpwF24/?mibextid=TGkgF5 -
- 12 replies
- Kriegsfischkutter
- ICM
So step by step, foam base grooved with a wave. primer (I suggest you use an acrylic so it does not melt the foam) DAS putty to make the waves then a simple black primer blue for the ocean with lighter blue near the crests of waves clear gloss coat over the top and some foam Sea foam and spume and a clear resin coat
- 12 replies
- Kriegsfischkutter
- ICM
- 12 replies
- Kriegsfischkutter
- ICM
- 12 replies
- Kriegsfischkutter
- ICM
- 12 replies
- Kriegsfischkutter
- ICM
- 12 replies
- Kriegsfischkutter
- ICM
- 12 replies
- Kriegsfischkutter
- ICM
So apparently there were quite a few variants of this little ship so I have some flexibility. as I said I built the entire kit in 20 minutes then bought another one to do properly with spares and aftermarket
- 12 replies
- Kriegsfischkutter
- ICM
I bought this kit ages ago for when I needed a palate cleanser. So I got an aftermarket set (which is designed for a SSNModellbou kits it appears ) then parked it and pretty much forgot about it. I did pull it out once as I thought I’d make it as a sci-fi flying boat but saw the forgotten aftermarket set in the box and re parked it. Then I’ve been told again I’m presenting at our annual show so I asked online what people want and was told how to do seascapes. There are lots of I tube videos and about 7 ways of doing it but how to do it as a quick demo? So I used my foam cutter and make a progression of seascapes which will culminate in a complete model on a base in a sea. Now the kit! Not much to it. I built it in 20 minutes so I had a template to use.
- 12 replies
- Kriegsfischkutter
- ICM
Lower hull, I still need to do some scribing but I’m also tossing up as to if I’ll put it in a resin base. anyways, the kit completely omits the fender which is on the stern. I glued two small strips of hardwood together and sanded it to shape. You can see from the white bits I’ve done a lot of putty so far.
Photo time, there is a Russian language modelling site which I have gotten the images off. It appears that the boats were a brown water navy during the soviet era.
This thing is certainly going to take a LOT of paint. Not a hard build and being Soviet it’s pretty industrial
Time to get back to ships (well boats), I bought this monster and after doing some weathered 1/35 military stuff I’m ready for this. As it’s So yet era I can weather the absolute hell out of it and add some decent size figures.
Pretty much spot on but December 1918; this will be on the name plate. Also I’ve ordered a set of punch magazine from 1918 armistice to go with it and a French victory medal. There are heaps and heaps of photos of artillery parks post war where the barrels are written on in chalk by the claiming battalions. Here in Australia a there are artillery pieces in front of nearly all RSL’s.
