RGL
Everything posted by RGL
  1. And the base outline of the diorama
  2. This like a Tamiya kit it comes together so well. It also includes 70 milk bottles, several milk churns and wooden milk boxes
  3. So from Tori Factory, some 3D printed stuff.
  4. Here’s a hint https://www.facebook.com/share/v/TtD4FpgcH8SpwF24/?mibextid=TGkgF5
  5. This kit is a beauty! Lots of choice of decals and another rabbit hole to go down as I have a plan for a diorama
  6. So step by step, foam base grooved with a wave. primer (I suggest you use an acrylic so it does not melt the foam) DAS putty to make the waves then a simple black primer blue for the ocean with lighter blue near the crests of waves clear gloss coat over the top and some foam Sea foam and spume and a clear resin coat
  7. So this is the OOB kit. The next one will be super detailed as a final product
  8. So these are my foam cutters. My intention will be to do a step by step tutorial
  9. So apparently there were quite a few variants of this little ship so I have some flexibility. as I said I built the entire kit in 20 minutes then bought another one to do properly with spares and aftermarket
  10. I bought this kit ages ago for when I needed a palate cleanser. So I got an aftermarket set (which is designed for a SSNModellbou kits it appears ) then parked it and pretty much forgot about it. I did pull it out once as I thought I’d make it as a sci-fi flying boat but saw the forgotten aftermarket set in the box and re parked it. Then I’ve been told again I’m presenting at our annual show so I asked online what people want and was told how to do seascapes. There are lots of I tube videos and about 7 ways of doing it but how to do it as a quick demo? So I used my foam cutter and make a progression of seascapes which will culminate in a complete model on a base in a sea. Now the kit! Not much to it. I built it in 20 minutes so I had a template to use.
  11. Lower hull, I still need to do some scribing but I’m also tossing up as to if I’ll put it in a resin base. anyways, the kit completely omits the fender which is on the stern. I glued two small strips of hardwood together and sanded it to shape. You can see from the white bits I’ve done a lot of putty so far.
  12. Hull together, some big seam gaps fixed up. next will be to scribe in some hull welds ,
