Everything posted by RGL
Getting some paint on the deck. The kit has it as fairly smooth but I know there are panels on it so I’ve improvised with the airbrush. Several shades of grey, once nice and dry I’ll do some filters
A couple of shots of Eskimo in her 1944 coat then 1945. You can see the depth charge throwers and racks amidships. I’ve also show a photo of the focsle on a tribal class which shows the flanges (if that’s it) for the chain and smoke pots
The plans have the focsle area with a checker plate and non slip strips. The kit has horribly raised bits and no non slip strips. When I bought the Pontos Marat upgrade to get the torpedo booms for the Borodino, it had lots of little steel strips which I’ve used here. The bits where the chain goes into the hull are little resin upgrades I got on a IJN set but I’ll have to add flywheels later.
So I got the airbrush out today. They seem to need to warm up a bit, so black preshading and the bootstrap done then masked over. Next will be the lower hull.
- 1,090 replies
- showcase models
- vendetta
Sir Humphrey; “Well that is certainly one option prime minister “
- 1,090 replies
- showcase models
- vendetta
So Langley Av3 is out next month. Who’s in?
- 1,090 replies
- showcase models
- vendetta
The hawser holes have a lip which was obviously removed when I moved them, and the lip of the hole in the focsle (I’m sure it has a name), both replaced with plastic card. you can see from this late war photo of a damaged bow on a Tribal the lips, and also the 2 smoke pots.
My local hobby shop has very few paints available, and even online there is not a big selection. If I painted with a hairy stick I’d be quite concerned I’d run out.
- 168 replies
- Scharnhorst
- Flyhawk
So you’re seeing double, HMS Eskimo (I’ll do her as a late ‘44) with a different porthole ratio as she lost her bow in 1942.
Well done mate! I’ll make a start on the next one soon.
- 1,090 replies
- showcase models
- vendetta
Didn’t like the bracing so I replaced it with metal. The guns are from Micromaster which came with a second hand HMS Eskimo kit.
I was fortunate enough to be with the UN in East Timor at the turn of the century, and a African bloke asked me why I couldn’t speak French, I tried to explain that Australia is the middle of nowhere, we don’t need to. He wasn’t happy with that answer but I didn’t have to go back to Africa.
- 1,090 replies
- showcase models
- vendetta
So finally arrived from France today (the French post office sent it back to the shop once because apparently Australia does not exist) I got a twin flack for Z-25 (I’ll get to it) and some signal lamps and Hedge hogs for the next Vendetta. Nice touch the chocolates
- 1,090 replies
- showcase models
- vendetta
