Everything posted by RGL
- 1,090 replies
- showcase models
- vendetta
Yes I’m aware of the 1/250. This one was $100 with the PE included so I grabbed it while I could
It’s all about ease of painting, if I can dry fit it so it fits properly before painting I will so it is off ship. It’s easier to paint and work on a small piece than sticking it all together then painting. You just can get enough detail that way (well I can’t). If I get all the superstructures done without gluing them to the deck it allows them to be added when painted and then production line for the fittings and weapons.
So good to see you back on Vendetta! I use 2 lamps, one on each side. Plus optivisor now. My suggestion for the railings is rip them off and just get a cheap generics set and paint them on the fret.
- 1,090 replies
- showcase models
- vendetta
I only learnt about that (annealing) last year!!!! Damn it would have saved me some grief. Good to see you back.
So courtesy of Gerhard Koop, some of the final photos of Z 25 before she became The French destroyer Hoche
I find rattle can, can loose detail, but an acrylic primer cones off PE when you mask it.
Absolutely, you’d be better off with a clean slate. It’s only noticeable as a mold (and a very good one) from close up. You’ve got lots of PE, just like me you obviously don’t know when to stop. The best advice I can give you is use the Tamiya white primer through an airbrush on the PE as it sticks so much better
I gave the etched in hull detail another layer of rattle can primer. Metal deck glued down which I’ll use airbrush primer as the detail is so fine. You can see how the CA brings up fingerprints so well .
Yep. There is a heap of types of these builds online all saying the bow is out. I disagree after studying the existing photos of her, but the hawser holes are in the wrong place. The kit is a hodge podge of “as built’ and 1942.
The bloke who designed the ships (models) and owned the company died, so when they’re gone they’re gone unless someone bought the dies
- 1,090 replies
- showcase models
- vendetta
I think after 6 months their might be a decent pe set. I’ve seen the pre orders, there is also new aircraft and a generic PE too. Should be a good weathering opportunity too.
- 1,090 replies
- showcase models
- vendetta
The maker of this kit is now deceased so it will eventually run out of stock thus I wanted to do the final version as Vendetta was the last one that survived the war (for the RAN anyway). there was going to be a Langley AV 3 released later this year which would make a good group build
- 1,090 replies
- showcase models
- vendetta
Yes mate, Emden, Seydlitz, Graf Zeppelin.... I have her 2 coats of rattle can primer, then I’ve etched in the weld lines (I’ve researched a lot and it’s really hard to find any photos of her Hull that have panel lines but zooming right in show them. I will give her another coat of primer then a red/brown undercoat that will be the base coat for chipping.
Bad experience at 18 with Southern comfort. Warm beers are not something we are brought up with (I did have an experience with some warm a Korean Beer in East Timor with some Koreans and some dried salted squid.)
- 1,090 replies
- showcase models
- vendetta
Nope, probably the worst beer in Oz, universally hated. It’s Vile. I think the Northern European version is different to the Australian concoction.
- 1,090 replies
- showcase models
- vendetta
