Everything posted by bruce d
Hello Joseph, welcome to the forum. You have asked a good question, thank you, and I will watch for the answer(s). It may well depend on when and where, but let's see what happens. Why not post a bit about yourself and your project in the New Members Introduction thread? Regards, Bruce
Think of it as adding 'character' to the model.
- 505 replies
- vanguard models
- Sphinx
Best wishes for next week and looking forward to seeing your finished Sphinx. I really like the colours and wood together, perhaps it is the lighting or maybe you are just good at this: either way it stands out among the logs. All the best, Bruce
- 505 replies
- vanguard models
- Sphinx
HMS VICTORY 1765 by albert - 1/48
bruce d replied to albert's topic in - Build logs for subjects built 1751 - 1800
Albert, that is a great log and it is going to be a beautiful model. -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
bruce d replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Seriously, it is wonderful. 👍- 475 replies
? That is a surprise. Can I ask what size blade are you using? I ask because I want to know if there is a limitation on the saw that I am not aware of. I have cut 22mm oak on mine, am I possibly exceeding spec? I like what you are doing with this build. Bruce
A contemporary view of the deck with capstan and other fittings pf a British ship is always worth a closer look. This one is another Library of Congress find: Library of Congress Control Number 2014649352 Title On the deck of the British ship Buffalo / engraved by J.R. Smith ; drawn from nature by A. Earle. Summary Print shows a capstan on a ship deck and other vessel components. Contributor Names Smith, John Rubens, 1775-1849, engraver Wikipedia says: HMS Buffalo (1813) was a 16-gun storeship previously the East Indiaman Hindostan. She was purchased in 1813 and wrecked in 1840 off Mercury Bay. She was significant in the colonisation of South Australia.
It looks great, I always get something from your posts so keep it up please. Best wishes for the procedure. Bruce
- 505 replies
- vanguard models
- Sphinx
Pat on the back for asking and trying to do the right thing.
Barry, a warm welcome to MSW from the UK.
Where can I buy this tool?
bruce d replied to EricWilliamMarshall's topic in Modeling tools and Workshop Equipment
Here in the UK that would be known as a 'Yankee' drill. There are also Yankee screwdrivers along the same lines. HTH Bruce -
New Member from waaaaay South of the Border
bruce d replied to Smokeyr67's topic in New member Introductions
Hello Smokey and a warm welcome to MSW from the UK. 👍 -
Hello Jesse, welcome to MSW from the UK 👍
Hello Melissa, welcome to MSW. Plenty of people here to chip in with advice/answers on the issues you will face. I am looking forward to seeing your build log, several people here have a soft spot for working boats. Your sky-gazing gear sounds serious! Bruce
PILLAR DRILL : A tall upright machine useful for suddenly snatching flat metal bar out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it. WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t' PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. MOLE GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH : Used almost entirely for setting on fire various flammable objects in your workshop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.. HYDRAULIC JACK : Used for lowering a car to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. BAND SAW : A large stationary power saw primarily used by most people to cut good metal sheet into smaller pieces that more easily fit into the bin after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect. PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to butcher Phillips screw heads. STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms. PRY BAR: See Screwdriver HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit. STANLEY KNIFE : Used to open and slice through the contents of parcels delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. ADJUSTABLE SPANNER aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as one size fits all, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in injury ,swearing and multiple threats to any inanimate objects within the immediate vicinity. BASTARD TOOL : Any handy tool that you grab and throw across the garage while yelling BASTARD at the top of your voice . It is also, most often, the next tool that you will need.
