Everything posted by drobinson02199
- 218 replies
- Victory
- Caldercraft
My previous post (and the one above it that I replied to) have the background for what follows. I decided to address the mizzen alignment issue (shown again below) by moving the skylight and bitts over. So I installed a length of plank under the deck, topped it with some scrap .8 ply to represent the height of the poop deck template, and then installed a fitted plank. All of that allowed me to move over and center the skylight and the bitts on the mizzen hole. If you study it all from the end, you can see that it's all now misaligned with the flag lockers, but if you look at it from the side, it doesn't jump out at you, and I think will look fine once the shrouds and other rigging are up. Regards, David
- 218 replies
- Victory
- Caldercraft
Allan: Not the camera angle -- your sharp eye has caught it. When I fitted the poop deck, I sanded it to fit, but then put a dowel down into the mizzen hole and then brought the poop deck down over it. Was misaligned, so I widened the hole in the poop deck ply so it would fit, and then when I planked it I did so to narrow the hole again around the dowel. But it is slightly off-center. My guess is that things are misaligned down in the bowels of the hull, causing the mizzen to slightly tilt to starboard, and the effect of that by the time it gets to the poop deck is what you see. I think it all goes back to the "dummy barrel strips" in the early hull building. In retrospect, I should have sanded them down to slide into the frames more easily. As it was, I had to knock them into place with a hammer, and that probably knocked some things out of alignment. The issue with those is that you don't really understand how tight the fit is until they are halfway in, at which point it would be really difficult to remove and sand them. Would be helpful if the manual had a tip on this. And in fact, I'm not sure it's the fit at all -- as I now remember I think it was just the curve, even though I soaked them in the bathtub before installing them. The space between the bulkhead frames isn't sufficient to manage the curve as you go in, so what I had to do was bend them down at the next frame, then knock in with a hammer. Even very softened wood would have an issue here. The other effect of that is that when I ultimately go to install the dummy cannons, many of the holes their stems fit into are out of line -- some considerably. So I'm going to have to fashion anchors for them that I can fit in through the cannon ports and glue once inside. Regards, David
- 218 replies
- Victory
- Caldercraft
- 218 replies
- Victory
- Caldercraft
Finished up the bow by adding the mariners walk. The boomkins are built but missing from these pics, as I have them put away to avoid pranging them. Regards, David
- 218 replies
- Victory
- Caldercraft
I've built the starboard cathead. A couple of construction notes: For the blue rectangles on the front of the cathead, instead of trying to use tape to get them straight (too small a surface), I painted a section blue (on top of yellow) and then added 1x1 yellow-painted strips to create the rectangles. For bending the brass strip to create the curve, I used a philips screwdriver pushed through a drilled hole in a 5mm board, heated the strip, and then bent a section into a 180 (so the two sides parallel). Then hammered the curve flat. I then cut that 180 degree curve into two 90 degree segments. Lots and lots of touch ups required to get the blue stripe right. So one side done, and now on to the other. Regards, David
- 218 replies
- Victory
- Caldercraft
- 218 replies
- Victory
- Caldercraft
Installed the bow gratings and made the boomkins. The boomkins are dry-fitted using a pin in the knighthead, so that I can remove them for now (as the manual suggests) to keep from pranging them, and then reinstall them later. Regards, David
- 218 replies
- Victory
- Caldercraft
I've built the bow structure, which was something of an adventure. The manual calls for the curved rails on the stem to be mounted before the head timbers are done, but the head timbers provide a guide for the run of the upper curved rail, so I mounted those first. Then mounted the curved rails. The manual also calls for the remaining rails (horizontal and blue-trimmed vertical) to be mounted before the bow main rail, but again, it was much easier to install the two horizontal rails, then the bow main rail against the head timbers, and then cut the vertical blue-trimmed rails to fit under the bow main rail. By the way, the head-on picture gives the impression that the leftmost hawse hole is off kilter, but that's just an illusion of the inside of the drill hole. Finally, the manual tries to be specific around the head timbers at the aft end of the bow main rails, but the instructions are confusing although I think I finally got it right. For this section, I did a lot of advance dry fitting and thinking, referenced the invaluable pics on the Caldercraft website, and got the idea to pre-mount the head timbers from another build log on MSW. Next step is the bow gratings that fit inside this structure. Building this part reminded me of the difference between this model and some of the Amati ones I've built. For some reason, things just seem more complicated on this model. I think it may be the amount of cutting, fitting, and pre-painting of small parts that tend to stay in walnut on the Amati models. In any event, I'm happy building this, although my limited skills are sorely tested. Regards, David
- 218 replies
- Victory
- Caldercraft
- 218 replies
- Victory
- Caldercraft
Finished and painted the roundhouses, planked the beakhead deck, and added the painted brass decoration. Regards, David
- 218 replies
- Victory
- Caldercraft
Bill: Thanks for the nice comments. I'm glad the log is somewhat useful. Regards, David
- 218 replies
- Victory
- Caldercraft
Re my message above, here's a picture of one of the roundhouses in process. I've finished planking the other one, and there's a pretty curved shape before sanding, so sanding shouldn't be too hard. I'll glue some sandpaper to a stick and have at it. Regards, David
- 218 replies
- Victory
- Caldercraft
Graham: I have already given up on the idea of removing the roundhouses. Because the partial trim leaves some of the wale in place, there isn't really any way to just slide the roundhouse structure out -- you'd have to tilt it and the tabs wouldn't work properly. So I glued the patterns on to the bulkhead and have started planking, and will do the sanding carefully with a stick and some sandpaper. Regards, David
- 218 replies
- Victory
- Caldercraft
Built the railing across the bow. Next step is the roundhouses. I'm a bit wary of trying to sand them on the ship -- thinking about planking them while dry-fitted, and then removing for sanding. We'll see if I can pull that off. Might be blocked by the wale position at the bottom. Regards, David
- 218 replies
- Victory
- Caldercraft
Ship's wheel and binnacle finished and mounted. The scratches on the wheel are light reflection and don't show to the naked eye. Regards, David
- 218 replies
- Victory
- Caldercraft
Quarterdeck and two forecastle cannons built, painted, mounted and rigged. Full Disclosure: Those of you who are Victory aficionados and are sharp-eyed may see that I goofed with the two medium cannons. They are longer than the rest, and I was careful all through the building stage to isolate the slightly larger carriages and mount the right cannons to them. All good so far. Then as I started mounting the cannons, I picked those two up, intending to mount them on the forecastle where they belong. Phone call causes distraction. I come back, pick them up and promptly mount them at the stern in the lashed down position behind the screen. 🧐 They were glued down well, and rigged, so there they stay, and the forecastle gets two of the smaller cannons. It's a goof, but a small one in the scheme of things and the ship will look fine for me, and less fine for those of you who pay close attention to historical accuracy. Regards, David
- 218 replies
- Victory
- Caldercraft
Installed bulwark fittings on quarterdeck and forecastle: shot racks, kevels, and pin racks. I did the side pictured below second, and changed my approach after doing the port side first. On the port side, I tried to install the shot onto the shot racks after they were installed, and with the bulwark there to get in the way of the tweezers, it was really difficult. So on the starboard side (pictured), I installed the shot onto the racks off the ship (same for the pinrails), and then installed them. Also note that these pinrails are much better spaced than the ones on the bitts, about which there was discussion above. The side pictured is the one that will show when I display the model. Regards, David
- 218 replies
- Victory
- Caldercraft
Allan: I admire your attention to historical detail (and am amazed at some of the details you come up with), but I don't have the motivation to change the pins out. I've had cross-pieces become difficult in the past, and I solve it by either doubling up on a pin, or wrapping line on the cross piece. I took a sideways look at the assemblies after I got your first message, and there's actually a bit of room between many of the pins -- enough to sneak lines through if they aren't too thick. But thanks for the suggestions -- I'm always interested in getting them 😁 Regards, David
- 218 replies
- Victory
- Caldercraft
Lined the quarterdeck rigging opening and constructed the Main Companionway. The latter of those two was something of an adventure. The ladder for that opening was constructed many steps ago, to match in width to balusters already installed below on the upper gun deck. I was positioning it for gluing, it slipped out of the pliers, and fell down not just to the upper gun deck below, but through the opening in that deck and down to the lower gun deck (two decks below), and then out of sight. I had put some glue on the bottom of the ladder, and so I couldn't dislodge it by shaking the ship upside down, although I suspect I'd never have retrieved it anyway. Out of sight, gone forever. Fortunately, in my leftover parts box from prior builds, I had a ladder (in plain wood), so I stained it (picture below), and installed it into the main companionway. Not as elegant as the original, but serviceable. Now as I look at the Main Companionway railings, I realize that there are supposed to be lower railings parallel to the upper horizontal ones. I'll get to that later (maybe 🤔) Regards, David
- 218 replies
- Victory
- Caldercraft
Allan: You are quite right -- they are VERY close together, and I had that concern about rigging when I installed them. The holes in the cross-pieces are pre-drilled, and the pins are supplied, so this is the spacing that results. I was reluctant to install fewer pins for fear that I would need them all when it came time to rig. So I'll just make it work when that time comes. Regards, David
- 218 replies
- Victory
- Caldercraft
- 218 replies
- Victory
- Caldercraft
Quarterdeck Barricade assembled, painted and mounted. The instructions say to build this from the bottom up, but I found that alignment was easier if I built it from the top down to the lower rail, then mounted the wooden posts to the deck, and then mounted the assembly to those. Regards, David
- 218 replies
- Victory
- Caldercraft
Assembled, painted and mounted the forecastle breast beam assembly. This was a tricky assembly -- getting the belfry started and aligned, and finishing off the U parts of the horizontal beam. Regards, David
- 218 replies
- Victory
- Caldercraft
Finished the hatches and bitts on the forecastle, and varnished them. As I started the next assembly, I realized that if I stayed with natural walnut vs. black, the deck would not look as sharp as it should. So I went back and painted the skid beam (in place) black, as per the picture below. Regards, David
- 218 replies
- Victory
- Caldercraft
