KORTES
Everything posted by KORTES
  1. I had to take my time, the profile is rather difficult to make. After molding the profile I left a small width margin and made the final refinements after gluing it, already in place.
  2. I would like to present my attempts in making cap rail taffrail. I waited a long time to approach it, finding the right technology, finally setting for the plank bending with further refining. To start, I had to prepare a pattern, and as I had to bend the lath with a big margin(the original size 1,5:22 mm), I had to make reinforced fixators. I have made two samples, refining them while adjusting them in place.
  3. Dear Michael and Keith I’m very touched by your attention to my work.
  4. Cap rail fore body. Material - black hornbeam, after installing, I fixed it in place with 0,6 mm brass nails.
  5. Now it’s time to make cap rail and waterways. I bent it after putting under steam, using a pattern. After fixation i dried it using a hot air gun - it speeds up the process.
  6. Basically I’ve finished nailing. I finally got around to overhang. It is painted, taffrail is covered with pear tree and black hornbeam. I made it with a small margin, when the enclosures are set I will finish the taffrail.
  7. Thank you very much my dear colleagues. Dear Michael. I have a pause in building "SPERWER" - I'm making sails. That's why I decided to show on the forum my last finished work Unfortunately I don't belong to the masters who work quickly. Once, I have apent two weeks of my vacation to make nailing.
  8. I have finished sketching, I still have half of the broadside to be filled with treenails.
  9. The hell is waiting to be done. For now I am making sketches.
  10. My greetings, dear Dave. Before the beginning of the building I realised the necessity of such instrument.Unfortunately, to my point of view, the PROXXON instruments are unreasonably expensive . That is why I have found in the internet photo of such instrument and asked my brother, who works with metal, to make me one. As a result I have two machines in one and it was a lot cheaper.
  11. Treenails of the deck. Unfortunately, I didn’t master the make using the syringe needle, after a few failed tries I gave it up… I haven’t had enough patience. I decided to sharpen on the grinder. After some try-outs I opted for the pear tree instead of the toothpicks. D=0,6 mm.
  12. I have finished the covering of the second broadside. Sketching and putting treenail in place are still to be done. I’m still trying out on samples. As I will have to drill a lot, the manual drill will not be the best solution, I had to work on and upgrade my mini-drill. I bought it on flea-market a long time ago, but couldn’t find any use of it. Yesterday I installed a small switch and now I’m testing it.
  13. Dear druxey, Yes, you are right, making this decision wasn't easy, but I had an example of the outstanding Masters in front of me and I really wanted to get even if for a little closer to their quality of work. In the end I was satisfied with the results, even though I had to redo my work many times. Plus I have gotten experience out of it. Dear BETAQDAVE, It's hard to give a definite answer on the choice of the method of making a hull. I found this method used by Snarlev, and at that moment I thought it was the easiest and the least labor consuming.When working on "Sperwer" I used a different method, and I could say that each one has its own advantages. Dear KeithAug, The covering was removed by means of heating by a hot air gun, it wasn't hard due to the fact that I used PVA glue. My best regards, Alexander.
  14. After some consideration, I decided to re-do the covering.
  15. Now, some of mistakes… In order to warn my colleagues, who , just like me , don’t have too much experience, I wanted to highlight my mistake in the process of covering. More than once in the working process I made sure that THE BEST IS THE ENEMY OF THE GOOD. After having completed the covering I decided , following the example of the Masters, to highlight the joints between the laths a bit. As a result, I haven’t succeeded in it, but I ruined the covering. The reason turned out to be banal – the glue on the plank ends, which wasn’t erased in time.
  16. Rubbing strip and two upper belts I decided to make out of black hornbeam. It turned out to be a very technological material.
