KORTES
Everything posted by KORTES
  1. Congratulations on the work. It's a very intersting, one of a kind ship. My best regards.
  2. Dear Johann. Your work inspires admiration. My best regards.
  3. Thank you very much dear Colleagues. My best regards.
  4. Macrofilming,macrofilming.. It shows all the faults, that are invisible by the unaided eye. That's why I decided to redo the surface a bit.
  5. The fitting was made in place, I didn't fix a chimney in place, because I haven't decided yet whether to install it or not. When the oil dries, I'll try to polish it.
  6. I would like to show my galley stove. The material is a black hornbeam.
  7. Greettings dear Gery. Yes, you are right, this is the color of the oil- coated pear tree. Pear tree wood is one the my favourite. My best regards.
  8. Amazing work. Among everything else I would like to point out a mastery work with paint and the skills in making material loook vintage. It looks very authentical. My best regards, Alexander.
  9. I’ve made the mast hoop. I couldn’t find the brass of the required diameter, instead I had a bronze wire. I had troubles while blackening. I had to buy a special solution, which solved the problem.
  10. I made cables, and i’m starting assembling the spars. I started with bowsprit, finished assembling anchor bitt and some small pieces
  11. I'm very glad you found my working experience interesting. My best regards.
  12. I’ve made a fit check, on a dry. I’ll assemble it later, with the rigging.
  13. Jack-pins. I found the technology of making jack-pins in the report of Uriy Kimborovich (bim), that he used for his schooner “Izmail”, for what I’m very grateful to him. I made a simple device out of the materials I had. Material - pear tree. Firstly I prepared the bars of the desired diameter, and so as not to waste too much material (for the support fixture in the collet) I was carving from a long rod, as the length of the coordinate table would allow me.
  14. Thank you very much, Colleagues for such a high evaluation of my work. My best regards. Alexander
  15. Dear Keith, The hull of the yacht is of an amazing quality and beauty. And I think so too, that it would be a pity to hide it under the paint. I wish you inspiration in your work. My best regards.
  16. Before the soldering, the adjacents parts were grinded off. Afterwards - blackening and assembling.
  17. And then I proceed using the technology of the master-classes. I decided to solder at the big diameter, because when the dead-eye is swaged, the deformation in this area is minimal and the probability of damaging the solder is less.
  18. In order to make metal pieces of lashing cleat- dead eyes I have made a small rim out of a small -diameter bolt.
  19. I made dead eyes. I cut them from the pear tree. For the drilling I had to make one simple device.
