Everything posted by KORTES
	I had to take my time, the profile is rather difficult to make. After molding the profile I left a small width margin and made the final refinements after gluing it, already in place.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	I would like to present my attempts in making cap rail taffrail. I waited a long time to approach it, finding the right technology, finally setting for the plank bending with further refining. To start, I had to prepare a pattern, and as I had to bend the lath with a big margin(the original size 1,5:22 mm), I had to make reinforced fixators. I have made two samples, refining them while adjusting them in place.
- 306 replies
- schooner
 - la jacinthe
	Dear Michael and Keith I’m very touched by your attention to my work.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	Cap rail fore body. Material - black hornbeam, after installing, I fixed it in place with 0,6 mm brass nails.
- 306 replies
- schooner
 - la jacinthe
	Now it’s time to make cap rail and waterways. I bent it after putting under steam, using a pattern. After fixation i dried it using a hot air gun - it speeds up the process.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	Basically I’ve finished nailing. I finally got around to overhang. It is painted, taffrail is covered with pear tree and black hornbeam. I made it with a small margin, when the enclosures are set I will finish the taffrail.
- 306 replies
- schooner
 - la jacinthe
	Thank you very much my dear colleagues. Dear Michael. I have a pause in building "SPERWER" - I'm making sails. That's why I decided to show on the forum my last finished work Unfortunately I don't belong to the masters who work quickly. Once, I have apent two weeks of my vacation to make nailing.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	My greetings, dear Dave. Before the beginning of the building I realised the necessity of such instrument.Unfortunately, to my point of view, the PROXXON instruments are unreasonably expensive . That is why I have found in the internet photo of such instrument and asked my brother, who works with metal, to make me one. As a result I have two machines in one and it was a lot cheaper.
- 306 replies
- schooner
 - la jacinthe
	Treenails of the deck. Unfortunately, I didn’t master the make using the syringe needle, after a few failed tries I gave it up… I haven’t had enough patience. I decided to sharpen on the grinder. After some try-outs I opted for the pear tree instead of the toothpicks. D=0,6 mm.
- 306 replies
- schooner
 - la jacinthe
	I have finished the covering of the second broadside. Sketching and putting treenail in place are still to be done. I’m still trying out on samples. As I will have to drill a lot, the manual drill will not be the best solution, I had to work on and upgrade my mini-drill. I bought it on flea-market a long time ago, but couldn’t find any use of it. Yesterday I installed a small switch and now I’m testing it.
- 306 replies
- schooner
 - la jacinthe
	Dear druxey, Yes, you are right, making this decision wasn't easy, but I had an example of the outstanding Masters in front of me and I really wanted to get even if for a little closer to their quality of work. In the end I was satisfied with the results, even though I had to redo my work many times. Plus I have gotten experience out of it. Dear BETAQDAVE, It's hard to give a definite answer on the choice of the method of making a hull. I found this method used by Snarlev, and at that moment I thought it was the easiest and the least labor consuming.When working on "Sperwer" I used a different method, and I could say that each one has its own advantages. Dear KeithAug, The covering was removed by means of heating by a hot air gun, it wasn't hard due to the fact that I used PVA glue. My best regards, Alexander.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	Now, some of mistakes… In order to warn my colleagues, who , just like me , don’t have too much experience, I wanted to highlight my mistake in the process of covering. More than once in the working process I made sure that THE BEST IS THE ENEMY OF THE GOOD. After having completed the covering I decided , following the example of the Masters, to highlight the joints between the laths a bit. As a result, I haven’t succeeded in it, but I ruined the covering. The reason turned out to be banal – the glue on the plank ends, which wasn’t erased in time.
- 306 replies
- schooner
 - la jacinthe
- 306 replies
- schooner
 - la jacinthe
	Rubbing strip and two upper belts I decided to make out of black hornbeam. It turned out to be a very technological material.
- 306 replies
- schooner
 - la jacinthe
