Thank you very much for that information....I'm for sure looking into it......thanks. Rob
- 3,560 replies
- clipper
- hull model
Glad things are moving forward Keith and the new recruit is learning the ropes. Good to see you at work again on this wonderful ship. Rob
Riiight...I see what you were saying. that connection does lend itself to some flex and give and adjustment. Yes...her bowsprit is square as it enters the bow and is turned just exiting over the hood. In this and some other images it is evident the jibboom is milled in like fashion. I've had copies of this figurehead image for years...not with such clarity though. I used it when making a comparison image of my 1/96 Glory build. This clear images also shows the true nameboard lettering...with Glory and Seas in large letters while *of the* is in smaller font Rob
- 3,560 replies
- clipper
- hull model
I'm fully not sure what shackle point you are referencing, but the short bracing arm that is supporting the inner bobstay that is attached to the cutwater is interesting. It is reminiscent of the extender found on the Cutty Sark between the cutwater and her bobstay. This is a very clear image of her bow section...perfect for replicating her members. I've not seen this clear of an example of this image before. Great joy! Rob
- 3,560 replies
- clipper
- hull model
One thing I noticed and you may have too. An unrelated item...a iron bar that is bolted just forward of her bow name plate that extends down to the tip of her naval hood...just behind the figurehead's hip? It shows up on the port side closeup of her figurehead as well? Is it supporting the hood? Rob
- 3,560 replies
- clipper
- hull model
Having a good quality set of drawings will be wonderful. I'm keeping her sheer open for corrections and like I mentioned earlier...her bulkheads are currently mobile, so I can make any corrections, substitutions...etc. The near profile image of her just after fitting out...it our best profile of her showing her at ballast....probably riding as high as she can get...clearly showing her quite vertical cutwater and entry...following her aft one can easily see her exit lines. Her sheer is nice and profiled...not to mention her clean copper/muntz line. All of this coupled with your drawings will aid in producing the most accurate hull of Glory..I feel is possible. And that is fine because we are our own best critics.....since the less discriminating eye wouldn't know the difference anyway. I'm so glad we have come to this place...again...thanks for your wonderful contributions. Rob
- 3,560 replies
- clipper
- hull model
Added several more bulkheads today...one last one for the stern to cut out. They are all fee and will be moved around and relocated for optimal planking...then I will glue them in and then add the bulkhead spacers. Rob
- 3,560 replies
- clipper
- hull model
HMCSS Victoria 1855 by BANYAN - 1:72
rwiederrich replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Pat...I concur with Ed. The fids from what I gather were of iron....they were required to hold large loads. My study shows that some fids had rounded bottoms to compensate for rake. This is not concrete, however. Here is an image of the Charles W Morgan during a turn of the century refit. You can clearly see the fid through the mast foot. I wouldn't expect them to be made of wood, unless the application was not extreme. Rob- 1,006 replies
- gun dispatch vessel
- victoria
Clipperfan..I see you changed your profile picture to that of the Glory of the Seas......cool. Rob
- 3,560 replies
- clipper
- hull model
You know...as I study this image, it reminds me of just how big these vessels were....look at the size of the men on the forecastle...….and the height of the bow from keel to rail. Then imagine further, by knowing that the Great Republic(which was built 16 years earlier), was nearly 100ft longer and over 20ft deeper then the Glory. She had to be a sight, in her enormity. Rob(Love clippers)
- 3,560 replies
- clipper
- hull model
It's good we have these images we can rely upon and repost for clarity and refamiliarization. In her launching image, if you draw a line down from her free hanging anchor(a good plumb), you can clearly see she had a very near vertical entry in her stem. Probably only several degrees(I don't have anything to measure currently). The Star of Empire, probably was an inspiration for Glory, since she is just a few ft longer and her dimensions are very similar. Cept Donald rarely created the same model, other then his sister examples. Rob
- 3,560 replies
- clipper
- hull model
Yes....I gathered that after I looked at your drawings and I remembered you had the practical shipbuilding book...but still was not clear if McKay(Donald's brother) had included any of Glory in his collection. Thank you again. However...the bulkhead drawing (Of the ship), does show promise as to be quite similar to those of Glory...that might have been the *confusing* factor for me. Your encouragement and motivation are always uplifting. Rob
- 3,560 replies
- clipper
- hull model
? Druxey...what vessel is that for? Not sure it is the Glory of the Seas.....unless I'm missing something terribly. Rob
- 3,560 replies
- clipper
- hull model
That's right...you have that book....think you can pop off a smidge of an image that you have? ………….Pls pls pls pls….. Rob(Just means I'm not far off...huh?)
- 3,560 replies
- clipper
- hull model
I just use my saber saw to cut out the bulkheads and my table top band saw to cut out the keel section. I drew out an example of vertical for Vladimir....by recognizing the vertical anchor hanging on her port side. Utilizing the anchor shank as a reference, I deduced the rough angulation of the bow....and she is surprisingly vertical. Coupled with her dockside image at her conversion to a salmon cannary….it is clear she did not have a swooping entry like Great Republic. The best educated guess is all we really have. I'm looking forward to your contributions and your final drawings for your own contribution. Exciting....isn't it? Thanks for the fine comments and encouragements. Rob
- 3,560 replies
- clipper
- hull model
Thanks Pat...oh...I have plenty of errors to manage and fix...but that is what is so fun about this for me. Unlike EdT's magnificent Young America, where every element must be perfect to align itself with other perfect members...I can get away with some sloppy workmanship...because its all about the end result. If I need to *wedge* or *fill* to compensate for an error...it will be covered up with something else and then drenched in copious amounts of glue, bondo, epoxy, wax, paint....etc. Yes...she is developing some nice lines. My plan is to place all the bulkheads and then correct the deck lines, by adding shims and will be doing the same for the bulwark members as well....cutting them or adding to them to create the correct sheer and proper balance for the rail. Thanks for the fine comment. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
That's looking magnificent. I'm not gluing any bulkheads so I can easily move or remove any that needs adjustment. Love your work. Rob
- 3,560 replies
- clipper
- hull model
Mind you..I will be actually pinning and gluing plank sheets in place later...just taking measurements and looking now. Gotta go help my daughter hang some sheetrock..... Rob
- 3,560 replies
- clipper
- hull model
I temporarily added some planking on the sides to give some contour effect...to visualize the curves being generated and to allow me to make any adjustments to the bulkheads. Rob
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Oh...one other observation I failed to mention. Since the Glory was of a *Medium* clipper design, McKay would have desired to increase her entrance and exit buoyancy(the real cause of Hogging). So to do this, her entrance would have been more vertical, allowing for a more rotund entry underwater. A sweeping bow would lessen her forward buoyancy, not to mention her cargo carrying ability. The opposite can be said about perceptions of her entry if one looks at her dockside view when she was being converted into a cannery. Her entry looks nearly vertical. I cut out and added 2 more bulkheads, but had to leave on an errand and didn't get any images. Bulkhead 5 is the one where she transitions to the main deck from her forecastle deck. Rob
- 3,560 replies
- clipper
- hull model
Yes.... optical illusions can play an enormous role in our perceptions of what we think we see. In this particular case, I would defer to the clearer, less processed image of her fitting out. Because we have other clear images of her that would concur and lend credence to the actuality of that image. The former image, though it is of the Glory, is suspect, because of other distortions we have already recognized. If we understand spacial distortions and those found in the optics of the period, such as spherical, choma and chromatic aberrations....(Not to mention the poor quality of the image), we can then again disregard these distortions for what we know to actually be the truth. I don't believe the Glory suffered from any severe *Hogging*. McKay, in his design of her, not only included iron cross banding in its prevention, but he also added extreme internal cross bracing with wood structures as well. She was overly reinforced against hogging. I do have an image of Dashing Wave in Seattle and she was severely Hogged. I'm sticking with the clearest and most optically accurate images we currently have of her...and utilizing an acquired acuteness for being able to distinguish proportions based upon comparative analysis, I think I can give a real good college try at building an accurate representation. Of course I'll need to rely also upon a copious amount of self assuredness too and faith in God. Your input in these matters has been instrumental. Rob
- 3,560 replies
- clipper
- hull model
