rwiederrich
  1. Clipperfan...my question to you is, Why not build your own version of Glory...you appear to have the intellect and historical prowess to build a very accurate representation. I think we spoke on this before. Any thoughts? Rob
  2. Indeed...they were both 2050 tons as close to Glory's 2102 tons. Glory's stern was less elliptical and she was a bit longer. Never the less, she was very similar. Good point. Rob
  3. My Earlier attempt to recreate the lines of Glory was met with some disappointment...based solely upon the limited material and media I was working with/from. A Revell Cutty Sark hull. My next attempt will be a more accurate hull model of the Glory. Your contributions are well accepted...thank you. Rob
  4. It's clear from the Peabody Museum image that the Glory had a nice trim/sharp entry. Note the copper line drawn out and also note the image of her at rest with her salty waterline imposed on her hull. Despite the slight perspective distortion...it can be devised she had a sharp entry...but was slightly more robust as you proceeded back along her notable flat floor and shallow deadrise. I feel I will be able to produce from these plans...comparing to the images of her hull...a pretty good representation. Thanks for your input and evaluation. Rob
  5. Yes Bruma..I too tried your method..but still the scale was off for me too. I did , however devise a press to impress or emboss the lateral stretch into the sails...similar to what you have created with your sails. The wrinkles and creases caused by the stretching sail to the sheet points is a very convincing effect...but I had to make the call as to what minute detail had to be eliminated to achieved the overall look I wanted Here is an image of the experiment, the sail is not cut or billowed completely...just the stretching was tested. Rob
  6. I added stunning sails booms to the Great Republic..just no sails. My booms *Hung* below the yard were as some are on top of the yard.....both methods were used. Rob
  7. You may have mentioned it earlier...but what do you do as a profession, if I may ask? If designing and creating the intricate tooling is one of your favorite things to do, then I can only assume you have engineering and machining in your background? There are other folks on this forum who are acute in fabricating their own tooling to create their models as well. What a skill......what a desire. I built telescopes too...but I don't always have to build the tools to build the telescopes. What a hobby. mmmmmmm Rob
  8. Thank you for the explanation. *extra* tools? I am quite overly impressed with the amount of custom tooling you have already amassed. I can't wait to see what other genius you have imagined that you still need! Rob
  9. Isaac Webb would be doing flips if he could in any way have had a similar technological advantage to building his clippers. With near robotic precision the process of cutting, fairing, pinning and assembly has taken the lengthy eye/hand approach out of building a fine ship model.....not to mention the time required of such practices. One question: From our vantage point (the viewer), and with compressed photographic evidence, one could imply, through lack of process data, that you have completed this much work in only weeks. You either are working 18+ hours a day, You have mastered an expeditious acuity that baffles simple thinkers, or...... my original premise is correct, and that you have compressed months of true labor and have edited it for our delightful consumption. Regardless how you're pulling this build off, it is as masterfully done as it could even be imagined. Rob
  10. Amazing! I’ve seen it done other ways but not at the expense of specialized CNC Machining. Ever so impressive. Following in anticipation
  11. Magnificent! By what means did you create the brass bands (Strips) for the iron lattice works? Hand scribed or with a paper cutter of sorts? Uniformity can be a challenge...so too, to prevent *curling*. Good job. Rob
  12. Indeed..production imagery can induce production error if one is not particularly tasked with the imaging. Not to mention, as perfectionists, it is not within us to parrade our failures...even in process. Production of finely crafted members is the ultimate goal anyway....it doesn't hurt our sensitive egos either. I live by this motto: *Quality is never an accident, it is always the result of high intention, sincere effort, intelligent direction and skillful execution. It represents the wise choice of many alternatives* From what I gather, you exhibit this motto in spades. Rob
  13. What the H**L......Wait! How are you producing these members...what was your process for creating the pumps and windless...everything is far too clean and shows no signs of soldering or casting. The end results are amazingly astounding....perfection in miniature metallurgy........ Where are your fabrication steps.......? Your work is as perfect as can be imagined...but you are leaving out the manufacturing steps...Is that by design? Rob
  14. What are we witnessing here? We are witnessing mastery, we are witnessing the highest degree of miniature shipwright carpentry that I have ever seen, or IMA, has ever been witnessed or recorded. To begin with, (If that can even be accomplished), how does one come by and acquire an overwhelming collection of specialized, extremely well manufactured tooling, especially designed for such an adventure? That is my first bewildered question, and secondly, the skill and acuity, coupled with an extreme control over time management must be characteristics of an extremely disciplined individual....who on the planet can master all of these so successfully? What species of individual are we in the presence of? I'm beyond impressed...on so many levels....that I can hardly articulate the appropriate words of astonishment! I'm glued to this thread to its completion or until my heart gives out...……. Rob(re-evaluating my model making perydime)
  15. I was going to say the same thing..... Smokin.....beautiful work.
  16. Nice....I can assume your attentions are needed elseward….Been some time since you posted any updates...how you doing? I know the summer months can fill up with so many other things that need doing. Rob
  17. Vladimir...your corrections are spot on.....looks like the prototype for sure....well done. Rob
  18. Sorry for the delay. Yes I added the sail (when I furled the sail) while the yard was off the mast. However all the billowing paper sails were added after the yard was added to the mast and they were all set to the cant I desired. Rob
  19. Just added another painting to my collection..here is an original oil by Bill Larsen, Titled: Spirit of the Sea. It looks great in my library.
  20. Here are some better images of the hull lines. And a bit larger... and by combining the 4 profiles you will have the entire plan...
