Who's to say McKay didn't have loads of copper in his warehouse...and he wanted to use it up before moving onto Muntz metal? Coming from you...that last statement is disturbing.🤪 When have you ever known me to diverge from the historical facts..... for an artistic option? I expect to either be corrected by you, or given your concurrence, but to simply give up and defer to, *It's your model, your choice*, Well.....I find that out of character. Not to mention the expression that must have been on your face while you were typing that.🤣 But as I posted earlier...Duncan McLean stated she was coppered below. I think he would have made the correct distinction. Unless I'm totally off base here. Rob
I didn’t want to step on your toes, but the plate example you gave of an actual hull is more of what you’re looking for. The nail impressions need to be imprints not headed. Good job Rob
- 44 replies
- Cutty Sark
- Sergal
Well you don't want the nails to protrude like rivet heads. You're doing so well....don't make that mistake. Rob
- 44 replies
- Cutty Sark
- Sergal
Well McLean says the portico is aft of the mizzen. Champelle's rendering puts the portico in just about the same place that you placed it...without the roof access and stanchioned rail. I'm opting to keep this configuration since it found resolution with others. Also his poop height and portico roof align with the main rail and monkey rail prospectively. As far as the spider band is concerned.....since the mizzen has a fife rail...no spider band is needed...just the spanker boom foot rest. The spanker gaff lift can be purchased and belayed at the fife rail.....unless the forward portico roof rail can also act as a fife rail...which would make sense. Rob
Yes...I noticed that a while ago, while researching her. I think that brace is an effort to stabilize her warping and sagging due to age and hogging. Same goes for the iron rods supporting her Hood. And remember when I asked about the anchor billboards....Glory didn't have any.......Well not till she was near her later years.....cuz she Shure had some installed some time in her latter life....cuz she has them in this image before she was scrapped...
It’s funny that there can be several other drawings that slightly differ. , when in fact NcKay’s half model contains all the raw data. The trouble lays with interpretation. We need to reconcile them , forcing them to agree with the half model. Even though, as a builders reference, it lacks the keel and monkey rail. Hence the rub of reconciliation. Behind the scenes……much deliberation and study have been employed thus far. To keep these initial pages as limited as possible. Folks like to see model building being done on a model building log. Much will follow when the paperwork is settled on, so wood can be cut. Full speed ahead….and on till morning. Rob
I believe so. I plan on rigging her in this manner...without the Howes double topsails. I want to keep that ginormous topsail to show how much sail had to be brought in when that monster had to be furled. Sailors could loose and furl that sail several times in the course of a watch....and in the freezing rain, in the dead of night...it was a stinker. It wasn't till the dawn of the Downeaster that the double topgallant came into practice. So much easier on the crew if you have to drop and furl half the canvas. Plus in many cases you didn't even have to furl the upper topsail but drop it so it hid in front of the lower topsail...eliminating its effectiveness. Rob
- 85 replies
- Cutty Sark
- Sergal
Your right, not until late 1853~ mid 1854 did Many begin to accept and change to the Howes rigged double topsail. McKay's Great Republic(1853), initially was rigged with the Forbes double topsail design...which Howes modified and improved. Every McKay clipper after was rigged with Howes designed double topsails. Rob
Well...I knew that...but Flying Cloud has been modeled to death.....I meant Staghound...which has of yet found good representation. I meant she is the one you continually advertised as a favorite. Any number of good clipper designs could have made Flying Clouds record times...given the right season...weather...tides...tenacious hard driving captain...etc..etc.. She just happens to be the right design, put into the right conditions to pull it all off. Rob
We have been working diligently to conclude the drawing of Staghound. One correction needs to be remedied. Staghound had 12" waterways molted to the deck frames and to complete the decking, 3.5" deck strakes were bolted to the deck frames as well. This means the actual deck line is 8.5" below the sheer line or planksheer. Vlad has done a magnificent job drawing out the lines, and as Rich has stated.....the true deck level must be attained before mast position can be finalized. We are close to that point and a final drawing will be forth coming....just a few keel issues to resolve first. Thanks for following along. Rob
