herask
Posts posted by herask
  1. Nate, I wholeheartedly agree. I'm also done with framing (tight race this one is 🤣), and the work/procrastinate ratio in my case was waaaay in favor of "I don't feel like working on frames right now" 😁. I remember when working on Pegasus, the most fun I had was while working on decks... still some work to do before those...
  2. I thought of making the hull shell in Fusion 360 or Plasticity, but that involves using one more software, learning user interface, learning CAD workflow, import export...
    The truth is, as I grow older I'm less and less inclined to bother myself with unnecessary cr... er, stuff. so I kept things simple and did everything within blender... great piece of software that one... 😁
  3. ok, here you can see a NURBS curve, and bellow is a simple vertex extruded edge with subdivision modifier lvl4.
    the result is almost the same, yet allows for more freedom than CAD program. at least for me. I like pushing vertices around, although the result might not be the perfect smooth shape as with CAD, but that's OK, I'm not designing mechanical device, I'm merely making a visualization of one...
    here you can see the ship's hull which I duplicated and then cut out frames, which I then shrinkwrap back on the first hull shell to keep the shape of all the frames consistent:
  4. oh, now I get it. we'll, I think that Blender is a mixed bag when it comes to complex shapes. on one hand, CAD software allows greater precision in modeling but only if you already know what you're doing and have detailed plans. on the other hand, if you're stuck with badly scanned plans with a lot of distortion, then Blender allows for easier adjustments and corrections along the way.
    at least that's the way I see it. to give you more precise answer I'd have to build one of these ships fully in CAD to really get to know both camps.
  5. thank you for your comments, guys! 😊 glad you like the ship.
    Waldemar, to answer your question is Blender really optimal for this? honestly, I don't know. it handled Pegasus pretty well, so I guess it will handle Pandora as equally well, and that's probably what matters the most. "if it works...", right?
    the thing is, the ship is not really that detailed. I'm making the frames the same way I made those for Pegasus, despite now having newer computer and beefier GPU, because I don't really need that much polygons. if you look at the renders at the shipyard, you can't really see facets and edges although they're quite large. just look at this screengrab from Blender:
    that's pretty much low poly mesh right there. for an object that's quite as tall as this frame is, you'd think you'd notice polygons when camera gets close, but in reality that's not (always) the case. so there was no need to go overboard with subdivision modifiers and whatnot. so, yeah, I think that Blender is OK for this.
    I thought about making Pandora in Fusion360 or Plasticity, and as much as I'd like to do it in CAD program I seriously doubt I'd have as much fun as I have working in Blender. we just clicked from day one like 13 years ago and I still enjoy using it, and even if Blender wasn't optimal tool for this (and there's no reason for me to think it isn't) I'd still be using it because it's the tool I'm most comfortable with, and that's what matters the most.
    oh, and since UE5 literally eats polygons for breakfast because of Nanite tech, I could've exported Pandora with subsurf modifier even if I wasn't going to use it in Blender, but I actually forgot to add it... 🤣
  6. Nate, thank you for the illustration, this makes things a lot clearer and a lot more sense that what I had in mind. my version is simplified (or unnecessary complicated, depends on one's view). your way is actually a lot better and now I'll have to rework those frames. good thing I'm reworking cant frames anyway (that's a as far as I got), so no biggie. thank you again...
    just one more question. was raising wood continuous like mine or did it have scores for frames?
  7. hey Nate! thank you for your input. ok, let's see...
    1. I like modeling my vehicles so they face either X+ or Y- axis, and viewed from front or right orthographic view. no particular reason, that's how I started modeling, I guess, by following tutorials. it's the second nature to me by now. if I oriented Pandora on Y- axis, from right ortho, the ship would be oriented from right to left on screen, the plans would be viewed from back, thus appearing mirrored. so for me only other choice was front ortho and X+ axis orientation. plans just sit naturally that way...
    2. I put my origin there so when adjusting and resizing plans they scale from one side instead of from the middle. easier to adjust... I might as well move everything to (+) station now. good point...
    3. no, I haven't yet. I'll deal with it once I get there. I already figured this out once, just have to remember how...
    4. the origin will stay at the bottom of the false keel. so when you drag the ship into the scene in UE5 it snaps to terrain instead of sinking in to wherever the origin is. again, just personal preference...
    5. you mean, the rabbet stops here:
    hm, yeah, my rabbet goes al the way to the sternpost and twists like on Pegasus. but then, what that line actually is, the one that goes beyond red mark?
    6. I didn't model the rabbet with the straight bottom rabbet. again, my resembles that on Pegasus. can you clarify or show on your model a bit more? I can't really visualize it...
    7. I believe that false keel was laid sometimes later by knocking off those smallest top pieces of wood on keel blocks and slipping false keel inside... I think I've read it somewhere but for the life of me can't remember where... but in 3D visualizations it doesn't really matter, it's just easier to position everything right from the start and add stuff later than move stuff back and fort, especially with hundreds of objects in the scene. yeah, some things might float in the air at some point :D
