Posts posted by DSiemens
Omega - have to admit I had to look up chuffed to see what that meant. I've never heard the term before but yes. I'm very chuffed. Shes coming along nicely.
Piet - Do it! Miniatures are to much fun. Any excuse to get a ship under glass is a good one. It's funny you say that because you miniature is making me want to build another at that scale.
- popeye the sailor, IgorSky, Piet and 9 others
- 12
CW. I think she'll look just fine with out the sails. The really early ships in bottles didn't typically have sails either. The technique seems to have been passed around in the early 1900s and was more prevelent in 1910ish and later. I've only seen a very few sibs pretty 1900 that did have sails and they were rare exceptions.
I'm interested in the method your using its different then I'm used to. Then theres a lot of methods that I don't know and no right or wrong way of doing it.
Looking good CW. I do like the change in the bows print. Great work. As far as the booms go there's several methods. The easiest is Don Hubbard's method where you attach the gaff and boom to the mast. Then glue the sail onto the gaff only. When the shups in the bottle position the sail over the boom. Glue down as necessary. Jim Goodwin uses a method where the gaff and boom are attached to a line that runs through the mast. This makes inserting into the bottle easier because the whole sail can go in before the ship and then it's pulled into place. You do have to cut a few more lines though. Actually the absolute simplest way would be to use cloth sails. Then let the masts fold as they will. The gaff and boom tied on loosely so they can fold with the mast.
- Landlubber Mike, IgorSky, Omega1234 and 1 other
- 4
A bit of a catastrophe on this one. The shelf it was sitting on gave out. I have some plans for putting her in a new case but she won't be going back into a bottle. I'd like to get a nice sea under her. Any ideas on what to use? Without the constraints of a bottle I would like to make it look really nice.
- mtaylor and GrandpaPhil
- 2
Piet I love the scale you chose yout doing a fantastic job with it. Good choice using filiment for the rigging. It realy is hard finding anything small enough to work. Also good choice using paper. Ithe isn't as forgiving as wood but it can take the scale better.
One thing you might look up is a company called cards of wood. Www.cardsofwood.Com They sell business cards and other paper products made out of wood. They have wood veneer you can put through your printer. It should work better than your .5 mm.
Keep up the great work I'm excited to see how she turns out.
J-class Yacht by IgorSky - FINISHED - Scale 1/300 - BOTTLE
I wonder if they did that to make it easier to tack. With the end cut off it looks like it would pass over the other jib more easily.
