GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
- 355 replies
- prince de neufchatel
- schooner
(and 3 more)
Thank you very much, I’m learning as I go. I think that after I sand the hull smooth, I’m going to attach the wales and apply the second layer of planking, along with planking the inside of the bulwarks. Then I’ll apply the gunport and sweep port pattern and cut the bulwarks to shape.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
Question, what’s the best way to do bulwarks on a card model, when you have sweep ports and gunports?
- 355 replies
- schooner
(and 3 more)
Merry Christmas Mark and a Happy New Year!
- 355 replies
- schooner
(and 3 more)
Making progress. I’m getting the technique for shaping and fitting the hull pieces down. Victory is sitting patiently in the background.
- 355 replies
- schooner
(and 3 more)
The hull is strengthening up nicely. I’ll be able to tell you more after I get it done.
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
Aft deck pieces are now doubled.
- 355 replies
- schooner
(and 3 more)
Due to a minor issue resulting from the placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”. I have the forward deck pieces and bulkheads permanently installed. As soon as they finish drying I will pull the aft deck pieces and double them.
- 355 replies
- schooner
(and 3 more)
HMS VICTORY 1765 by albert - 1/48
GrandpaPhil replied to albert's topic in - Build logs for subjects built 1751 - 1800
Very cool! -
Patrick, Thank you and welcome aboard! Have a Merry Christmas and a Happy New Year! Phil
- 355 replies
- schooner
(and 3 more)
Thank you! Much appreciated! I’ve definitely been learning a lot with this project! I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
- 355 replies
- schooner
(and 3 more)
I doubled the forward deck pieces, which should remove the waviness. I will double the aft deck pieces after I install the forward frames permanently.
- 355 replies
- schooner
(and 3 more)
Amazing work on both the Sovereign Of The Seas and the Royal Katherine!
- 1,035 replies
- royal katherine
- ship of the line
I also need to double the deck pieces
- 355 replies
- schooner
(and 3 more)
It needs some (read a lot of) adjustments to bring everything into line, but I’ve made it to the initial dry fit point.
- 355 replies
- schooner
(and 3 more)
Quick question, what’s the best way to install a transom on a card model? Should I just build up the stern frames like any other model, or just glue it to the stern after installing the deck and covering the hull?
- 355 replies
- schooner
(and 3 more)
- 355 replies
- schooner
(and 3 more)
Thank you for the information. I’ll remember that for next time. There are several ships in his books that I would like to build. Buying the plans in sheets would be very convenient. I never actually scanned these, I just traced them and enlarged the tracings. This has been a highly educational project. I’ve been learning a lot. It’s been a lot of fun too, I’ve never built from scratch before.
- 355 replies
- schooner
(and 3 more)
The only drawback to the posterboard is that I am having to double it in order to build up to the 1mm thickness that Ab mentioned in his tutorial. But, so far so good. I traced the deck camber from Zu Monfeld and enlarged it to make a template which I transferred to the bulkheads. I’m currently in the process of doubling the bulkheads below the main deck to gain more area to glue to.
- 355 replies
- schooner
(and 3 more)
