GrandpaPhil
Everything posted by GrandpaPhil
  1. First coat of putty is on! Waiting for it to dry. Note: this is going to get sanded outside, lol
  2. Thank you very much, I’m learning as I go. I think that after I sand the hull smooth, I’m going to attach the wales and apply the second layer of planking, along with planking the inside of the bulwarks. Then I’ll apply the gunport and sweep port pattern and cut the bulwarks to shape.
  3. 1st layer of planking is on. After it completely dries, I will use filler to smooth it out.
  4. Question, what’s the best way to do bulwarks on a card model, when you have sweep ports and gunports?
  5. Making progress. I’m getting the technique for shaping and fitting the hull pieces down. Victory is sitting patiently in the background.
  6. The hull is strengthening up nicely. I’ll be able to tell you more after I get it done.
  7. I’m making progress on the hull. I also broke my breakwater, so I made a new one, lol.
  8. My pulp board just came in, so here we go. I’ll let you know how covering the hull goes.
  9. I got a little bit done on the Victory. I made one of the entry port canopies.
  10. Due to a minor issue resulting from the placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”. I have the forward deck pieces and bulkheads permanently installed. As soon as they finish drying I will pull the aft deck pieces and double them.
  11. Patrick, Thank you and welcome aboard! Have a Merry Christmas and a Happy New Year! Phil
  12. Thank you! Much appreciated! I’ve definitely been learning a lot with this project! I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
  13. I doubled the forward deck pieces, which should remove the waviness. I will double the aft deck pieces after I install the forward frames permanently.
  14. Amazing work on both the Sovereign Of The Seas and the Royal Katherine!
  15. It needs some (read a lot of) adjustments to bring everything into line, but I’ve made it to the initial dry fit point.
  16. Quick question, what’s the best way to install a transom on a card model? Should I just build up the stern frames like any other model, or just glue it to the stern after installing the deck and covering the hull?
  17. Thank you for the information. I’ll remember that for next time. There are several ships in his books that I would like to build. Buying the plans in sheets would be very convenient. I never actually scanned these, I just traced them and enlarged the tracings. This has been a highly educational project. I’ve been learning a lot. It’s been a lot of fun too, I’ve never built from scratch before.
  18. The only drawback to the posterboard is that I am having to double it in order to build up to the 1mm thickness that Ab mentioned in his tutorial. But, so far so good. I traced the deck camber from Zu Monfeld and enlarged it to make a template which I transferred to the bulkheads. I’m currently in the process of doubling the bulkheads below the main deck to gain more area to glue to.
