GrandpaPhil
Everything posted by GrandpaPhil
  1. I had to cut more planking strips. I made enough for the deck, too. The insides of the bulwarks are now planked. Time to seal them and paint them.
  2. I planked the inside of the port bulwark. It looks much better now. After I get the starboard side done, I’ll seal both bulwarks and paint them dark green like the Smithsonian’s model.
  3. Thank you, Mark. I cut the tape in 4 1/2” pieces and marked the plates, 3/4” apart, with a pounce wheel, which simulates the nails securing the plates to the hull. I did cut the individual plates apart where I needed to in order to follow the curves around the hull. There is only a single band of plating, due to the small size of the ship. Victory had 3, which is part of what took me so long when coppering it. This one went so much better.
  4. I cut out the gunports and sweep ports on the port side. I’m getting used to the bulwarks being spongy because they are made of pulp board. If I ever build another card model of a ship with guns, I will precut the sections with gunports. Lessons learned.
  5. That went well. I have now coppered two hulls. Note to self, always buy new copper tape, it works infinitely better, lol.
  6. One side is coppered. I used copper tape, a pounce wheel, an X-Acto knife, and a ruler. At 1/72 scale, a copper plate comes out to about 3/8” by 3/4”. This is making coppering the Prince de Neufchatel much easier than the Victory.
  7. I only planked down to the waterline because I am using contact paper for my second planking and the hull is going to be coppered below the waterline. Unlike a conventional second planking, the contact paper doesn’t add any thickness to the hull, so there is no reason to plank all the way down. I just sealed the hull in preparation for painting. I am going to base coat it black above the waterline. After it dries, I will copper the hull below the waterline. I am going to use copper tape and a pounce wheel, just like I did on the Victory.
  8. I made a display base today. The actual base is a premade piece of wood that I picked up at a yard sale this past summer. The cradle pieces I made out of 1/4” (6mm) thick basswood. I decided to do a little carving on them, just having fun (which is the whole point of this project anyway). The model is mounted off-center to allow for the bowsprit. I actually chose the mounting points based off of the model of the Prince de Neufchatel in the Smithsonian (I found a picture on their website). I am also going to use their color scheme.
  9. Thanks for all comments and all the likes! This has definitely been a learning process for me, but the best way to get better is to exceed your abilities! I just installed the wales. The Prince de Neufchatel is starting to look like a ship! I have also drawn out the cradle and applied the pattern to a sheet of basswood. I traced the hull shape at bulkheads D and 7, off the body plan, to get the inside shape, then I just hand drew the outside of the cradles. Then I folded the tracing paper over and reflected the cradle at the centerline.
  10. I cut the bulwarks to shape and attached the transom. I also closed up the gaps on the stern and cleaned up the underdeck a little. I’m going to lay down another underdeck piece on top of it, after planking and coppering the hull, to make everything even and lay down planking on top of that.
  11. Thank you very much, Mark! I’m looking forward to seeing how this turns out. This is my first scratch build, in a medium that I’m not the greatest with, so this is going to be interesting, lol.
  12. So far, so good. The second sanding is done and I think the hull is about ready for the second layer of planking, after I fix a few minor issues. I just traced and resized the rudder, bulwarks and deck, so I have my templates made. I need to cut down the bulwarks, so I can finish the stern and attach the transom, and wales, before I add the second layer of planking.
  13. I’m going to make them from wood. This is just going to be mostly card, but it will also have brass wire, copper tape and some wood parts.
