GrandpaPhil
Everything posted by GrandpaPhil
  1. Thank you very much, Mark! I’m looking forward to seeing how this turns out. This is my first scratch build, in a medium that I’m not the greatest with, so this is going to be interesting, lol.
  2. So far, so good. The second sanding is done and I think the hull is about ready for the second layer of planking, after I fix a few minor issues. I just traced and resized the rudder, bulwarks and deck, so I have my templates made. I need to cut down the bulwarks, so I can finish the stern and attach the transom, and wales, before I add the second layer of planking.
  3. I’m going to make them from wood. This is just going to be mostly card, but it will also have brass wire, copper tape and some wood parts.
  4. First coat of putty is on! Waiting for it to dry. Note: this is going to get sanded outside, lol
  5. Thank you very much, I’m learning as I go. I think that after I sand the hull smooth, I’m going to attach the wales and apply the second layer of planking, along with planking the inside of the bulwarks. Then I’ll apply the gunport and sweep port pattern and cut the bulwarks to shape.
  6. 1st layer of planking is on. After it completely dries, I will use filler to smooth it out.
  7. Question, what’s the best way to do bulwarks on a card model, when you have sweep ports and gunports?
  8. Making progress. I’m getting the technique for shaping and fitting the hull pieces down. Victory is sitting patiently in the background.
  9. The hull is strengthening up nicely. I’ll be able to tell you more after I get it done.
  10. I’m making progress on the hull. I also broke my breakwater, so I made a new one, lol.
  11. My pulp board just came in, so here we go. I’ll let you know how covering the hull goes.
  12. I got a little bit done on the Victory. I made one of the entry port canopies.
  13. Due to a minor issue resulting from the placement of my templates on the poster board and the page split of the plans in the book, I had to cut the deck pieces between bulkheads 1 and 2 and remove about 3/16”. I have the forward deck pieces and bulkheads permanently installed. As soon as they finish drying I will pull the aft deck pieces and double them.
  14. Patrick, Thank you and welcome aboard! Have a Merry Christmas and a Happy New Year! Phil
  15. Thank you! Much appreciated! I’ve definitely been learning a lot with this project! I’ve answered all of my own questions about rescaling plans and transferring from the books, just by doing it.
  16. I doubled the forward deck pieces, which should remove the waviness. I will double the aft deck pieces after I install the forward frames permanently.
  17. Amazing work on both the Sovereign Of The Seas and the Royal Katherine!
