cog
Posts posted by cog
  1. That worked rather nicely. I found some room for improvement. Like this, I could only put a center in with a certain diameter. I thought about the drill ... If I could put a drill head on the slide ... you could would have a lot more possibilities. I had an old drill, took it apart and used the axel from the head. Luckily for me it all fitted perfectly
    In the near future I want to make an eye to stabalise a thin piece of wood. I'll be extending the post than.
  2. Next thing: make a slider, so different sizes kan be fit between the drill and the opposing center
    Made on each side of the base plank a groove so the slider won't budge. In the triangular side of the slider I drilled a couple holes to pass some dowels through. Drilled a hole large enough for the revolving center I bought (€ 19.--). Made a clamp on it to fix the slider on the required distance from the drillhead
    post-33-0-30236300-1361050397_thumb.jpgpost-33-0-84955100-1361050401_thumb.jpgpost-33-0-85350300-1361050405_thumb.jpgpost-33-0-84836900-1361050410_thumb.jpgpost-33-0-11845200-1361050415_thumb.jpg
  3. Well, I'll be building this one up, for I have to go through the paheses as I build this one (still rather recent)
    The plank which supports is approximately 1 meter x 20 cm x 2.5 cm. The others are 1.8 cm thick. It's all pine wood. Took some of the thinner planks and made a base for the drill. Drilled/sawed a hole the size of the forward part of the drill body  which normally would hold the handle. Cut a groove in the plank from the top to the top of the hole so It can clamp the drill. The images show it better than I can explain in my poor English ..
    After that I took a router and made a groove all over the length, and twoo lesser ones on the side of that one which I 'll use for alluminium strips. The use of those will become apparent.
    post-33-0-54741400-1361040210_thumb.jpgpost-33-0-71529500-1361040214_thumb.jpgpost-33-0-95889000-1361040218_thumb.jpgpost-33-0-77707300-1361040222_thumb.jpg
    Some chisseling to be done ..
    and fitting the strips ...
    post-33-0-45414500-1361040299_thumb.jpgpost-33-0-70350200-1361040303_thumb.jpgpost-33-0-30857200-1361040308_thumb.jpg
