Posts posted by cog
Question: I made a wooden gearshift knob, lacquered it with a car clear aerosol gloss lacquer - multiple layers - but it is getting whitish now - most likely humidity - what can I do about that? Should I use a two component paint, or can it be the wood?
20 hours ago, RGL said:
AK makes a salt product but you need to use it very sparingly as it’s bloody strong, thus I did a white diluted undercoat L. They have a tutorial on Utube
used it on one of my destroyers, maybe it wasn't as strong when I bought my pot of stain
- Old Collingwood, Canute and mtaylor
3
On 1/3/2023 at 2:46 AM, RGL said:
My plan is to have one lowering a torpedo on one side forward and picking up cargo on the other side aft
As long as you do not load the cargo on board your subs, when those are low on explosive cigars 😇
- mtaylor, Old Collingwood and Canute
3
Best wishes to you and yours too.
Cargo hoist workings aren't to hard, you'll figure it out in a jiffy
- Old Collingwood, Canute and BANYAN
3
2 hours ago, RGL said:
Now a bit of hand chipping
Shrunk yourself?
Did you use chipping fluid or painted/splashed it on?
- Old Collingwood, BANYAN, Canute and 1 other
4
I'm fine, thank you, hope you and yours didn't over eat 😉
maybe this will give you some speed taping time
Looks more like taping time. Hope you’ve had a good Xmas .
- Canute, Old Collingwood, mtaylor and 2 others
5
10 hours ago, RGL said:
Finally some green slime. I’ll give this a day or so to dry properly as this is the best time to add fingerprints to your model.
I thought you had to "stamp" them to prove ownership 🤔
Nicely done (again) RGL
- Jack12477, Old Collingwood, mtaylor and 3 others
6
On 12/15/2022 at 7:50 PM, Roger Pellett said:
I keep a tube of Duco cement on my workbench. I use it for temporary glue joints such as the brass/plywood sandwiches that I make for ripping brass strips on my Byrnes Saw. The cement allows the plywood to be peeled away from the brass strip after sawing.
I buy mine at our local Ace Hardware. A tube costs less than $5.00.
Roger
Rogert, what blade do you use on your Byrnes for ripping brass strips?
7 hours ago, yvesvidal said:
I wonder how did they squeeze that plane on the lower deck....
Amputated wings, Yves
- Old Collingwood, Jack12477, mtaylor and 1 other
4
Great idea, filling the cargo holds. I might steal it for a future build. You are running at top speed again. Lovely work on the hull and holds
- Old Collingwood, Canute, king derelict and 2 others
4
1
Well done mate. Must have been rather nice to be amongst 500 models and bring home prizes!
Can't you make 5/16 rolls of parchment, quite sturdy and you can "slice" ringlets off ....
I'm getting older, so my response time leaves some what to be desired
Lovely build as per your usual...
Look forward to the sub build, since I’ve got that one in my stash too.
- Canute, mtaylor and Old Collingwood
3
You haven't even started and are already nearly finished!
3
No holes in the deck. It's not a sub. and having such an entrance wouldn't be practical in high seas, besides, these ships weren't known for their luxury, more discomfort ...
Why not put her in drydock again ... not sop messy with the water
She looks a million already ..
- popeye the sailor, mtaylor, Canute and 1 other
4
Clear lacquer turning white-ish
in Painting, finishing and weathering products and techniques
Thank you Joseph. In this case the lacquer was already dry for several months, but certainly worth while remembering!
