Everything posted by LyleK1
Welcome Herby! If I might suggest, put your build log link in your signature. I'd love to see the build!
Two down and many to go! Please leave a comment on the way I've set the sails... I'm looking for that furled and dry-set state. Although the sails are well made, they are bulky and I think will be better displayed with a mix. Additionally, I get the added bonus of leaving the ship easier to view since the sails will be one way or the other. So far, I think it looks good. Thoughts?
Still some time before our next trips get started! So back at it! The fore top gallant yard and sail were hung today. I attached the halyard to the yard and then bent (?) the sail to the yard. After tightening and knotting, I ran the halyard line to the deck for attaching later. I also attached blocks on the lower corners of the sails for rigging. I'll set the sail after getting the yard rigged. On we go!
Sorry about the long delay... spring and summer activities are in full swing! Didn't work on the Bounty this month at all except today! As promised a few months back, here is the procedure I use for weathering/aging my sails: Gather up your sails, a bowl of water and tea bags or in my case, tea cups (you'll see!). Also a few rubber bands are needed. 1. Wet the sail... make sure it is completely soaked and then the excess squeezed out. You can see the "cups" I used but tea bags work just fine too. 2. Sprinkle the tea particles very heavily around the edges of the sail. Be liberal with the tea on the edges. Add more tea particles to the center portion, randomly making heavier spots. 3. Press the tea particles into the sail with your fingers/hand. They won't all stay in place but enough will. Fold over the sail and ball it up real tight. Wrap a rubber band or two around the sail to keep it balled up. 4. Dip them into the water very quickly and remove. Let the sails set for at least 1-1.5 hours. The longer left, the darker the color. So, be careful not to go too far! 5. Remove the rubber bands and unfold the sail. Using a stiff brush, removing as much of the tea particles as possible. 6. Using a hair dryer (or you can just let them dry naturally), dry the sails and remove the remaining tea particles. The sails will lighten up a bit as they dry. The following pictures are wet sails: And here are the same sails dried and ready to be worked: The sails are weathered, splotchy and dingy around the edges... perfect for an aged model. Hope this answers some of the questions I received about ageing the sails!
Finished already!!? She looks beautiful! Well done, Bob!
- 56 replies
- Sea of Galilee Boat
- SE Miller
Well done, Bob! Looking very smart!
- 56 replies
- SE Miller
It took a little finessing to get mine off the strong back but ultimately, it did come off without any damage! Hope yours does too.
- 56 replies
- SE Miller
I have the Rikon 10-3061. It's the same model but has 1/2 HP. I use it for many things and highly recommend it. It's easy to operate, easy to change blades and cut accurately.
Looking good! Now the fun begins. Take your time with the next few planks... it progressively gets tougher to bend and twist them. The better the joint, the less sanding later! There are spots on my build that were mighty thin! Have fun!
- 56 replies
- SE Miller
Good luck! It was a fun build. You can access my log to the same build below, if you're interested. I'll be pulling up a chair to watch!
- 56 replies
- SE Miller
Off I go on the yards and associated hardware. To start, I used my mini lathe to taper the yards to the sizes shown on the plans: Once they are tapered, the reinforcements were added. I used clothes pins to hold the pieces while the glue dried: And then sanded: The cleats were cut and sanded: And installed per the plans: The booms were a bit of conundrum. The kit provided brass wire and flat strips to make the the mounting hardware... what a joke! I attempted to make a set and they turned out looking like... well, lets just say, they did not look good! While doing some research, I was going through Tim Moore's log on his Bounty (I use it a lot!) and "borrowed" his method! I purchased some small aluminum tubing with I.D.'s similar to the O.D.'s of the yards and booms. Using a miter and handsaw, I cut pieces to size and used CA glue to join them as needed. Additionally, I used the brass wire for the end mount by drilling a small hole in the tube and the yard: It took some time to figure out a system but in the end, I got a good result. Unfortunately, painting the aluminum is not working out as the paint just wipes off! I'll be touching the pieces up as needed. For future yards, I purchased Jax Aluminum Blackener to solve this problem. I'll have it in time for the next set. Then the end cleats were made and installed: Yards assembled for the fore mast: Footropes and the beginnings of the blocks and tackle in progress: I'll post a few more pictures once the yards are done for the fore mast. The process is identical for the main mast and I'll not bore you by showing the process all over again! Once I get started on the mizzen mast, I'll post more details.
Standing rigging completed! Some odd things with this kit on the location of the backstay tie offs... took a while to figure out but that's the norm for this kit! I'll start on the yards next. Also, I'll get some better pictures of the standing rigging in a few days. Not really a lot to talk about as the rigging was pretty straightforward. Especially, using the books mentioned further up the log! Next up date during the yard construction.
Ha! Thanks for the comment! I laugh because most have not noticed or bothered to mention them! Those are "Fancy toothpicks" purchased at the grocery store... worked out pretty well! Thanks for stopping in and commenting. I am currently working on the shrouds and ratlines... port side is done, starboard side in progress. An update coming soon!
Masts done... the only wood work left are the yards! A number of pictures to help future builders... The blocks are all in place too. As I noted in my previous post, I glued the main mast into place before adding the standing rigging lines. That made adding them a bit tricky but I managed: All the shrouds are ready to be completed but I still need to add the stays, etc. See the spaghetti below! I made a major (to me) blunder when I accidently bumped one of the stern lanterns knocking it loose and severing the wire to the lamp. Unfortunately, I don't see a way to fix the wire, the lamp is repairable. I was pretty upset as I've been really careful for two years and all it took was a little bump from my sleeve to do the damage. Nothing I can do.... but move on. Standing rigging lines will be added. Then the masts will be glued into place and the shrouds attached... Oh boy! More knots!! An update will follow.
Lots of pictures today... Making up for the lack of instructions and pictures in the kit! The plans are fairly good and with the help of other build logs, I've managed to get the foremast and main mast completed, short of some paint and mounting the blocks. So, let's get to some pictures... First up was the main mast as I found out that I was short on walnut round stock for the foremast by 2cm. I ordered some and it arrived quickly. The mast head was reamed out and fitted onto the mast: I should point out that the fore and main masts are similar in construction with the main difference being the total length. The mast caps were shaped with a rattail file and glued into place on the mast head: The mast stiffeners were glued into place and then sanded to shape: A hole was drilled as per the plans and the mast placed for reference: Next, I added more mast stiffeners and sanded to shape: Assembled the platforms and bees for all three masts: Glued the bees into place along with paint and weathering: I got a little ahead of myself by mounting the mast and gluing into place by not adding the blocks and not treating the mast with boiled linseed oil... Oops! It'll just mean a little extra work with the blocks, in particular, as I'll need to do the work standing up! I guess I was a little excited to get it in place! Getting the masts straight from side to side and fore and aft was a bit difficult but ultimately, turned out close to perfect: Note that I show the foremast in place but it hasn't been glued yet as I need to add the blocks, paint and oil! I'll finish these up over the next day or two and get the mizzen mast in place before moving on to the standing rigging for the upper masts. See you all soon!
