Posts posted by DanielD
19 hours ago, Mike Dowling said:
I’ll look and see, but as I recall I bought them from a store in California. I wanted a metal housing and when I called this place, the guy that answered the phone was very helpful, knew exactly the part I was talking about among the 100s of parts he had on his website, and answered my questions without hesitation. So I bought them from him and they arrived in a few days. They came with 12v bulbs, but not LED…but a clear 3mm LED fits nicely inside and looks amazing when lit.
I looked at the RB Model link that VitusBering listed above, and it has the same ones I bought near the bottom, see image below. I bought the second one in the list as the inside diameter is slightly more then the 3mm LEDs I’m using.
Hello all, I have a couple of updates, one of which I could use a little help. First, the last, for now, update on the chart room. Paint and lighting all finished, but still have to complete the second level.
Next, I’m struggling a bit with the scale of side marker lighting. In the same image as the chart room is my second attempt, this one made in brass. I think I have the shape close, see second image of the real AV port marker and housing, but I’m not sure about the scale. I have no measurements or drawings, just building by sight and this image I found on line. Clear images of the side marker lighting are very hard to find. I only have two and this is the better of them. What is your opinion? Side marker look okay or a bit too big?
- Mike Dowling, Knocklouder, clearway and 3 others
- 6
- hof00, VitusBering, clearway and 3 others
- 6
16 hours ago, VitusBering said:
That does look nice. Thanks for the tip!
VitusBering: somewhere in the above posts you made a comment something to the effect that any USC-C cable should work. After you came up with the idea about hiding a usb-c connector along the bottom of the false keel, I started to think that is what I would do, and will do. However, during my research, not all usb-c cables are the same. For example, if you get a power usb-c cable, it only contains 4 wires, the other potential pins on the plugs are not connected. Also, if you use a data cable, which you will need to use to have more then 4 wires, the cables are not connected straight through. For example, pin A2 (Tx1+) on one end will connect to B11 (Rx1+) on the other end of the cable, etc. For this reason, I will be using two circuit boards I listed above with a short data cable between them. Then I can map out, using a volt meter, a contact on one end to the correct pin on the other to make my entire system work. Using a usb-c connector on the base and at the bottom of the ship is a great idea! Just have to take a few things into consideration. Hope this helps.
Good evening mates, I’ve been out of town for a few days so no progress…but this evening I did sit down and start the 3D rivet application to the chart house. These are 3D decals that are applied with decal set liquid and slid in place over top of the primed surface. Once the rivets are “stuck” and dried in place, a second application of fixer is applied. I’ll finish the other sides then air brush the entire structure in white followed by the AV yellow and then the trim. So much work for such a small structure.
- Mike Dowling, Dave_E, VitusBering and 1 other
- 4
On 4/30/2023 at 7:54 PM, VitusBering said:
[edit] I did find a few examples of bare connectors but they didn't have a convenient way of mounting them except on a PCB.
VitusBering, I found a possible USB-C mountable solution at Amazon that might be easily mounted easy solder connections, at least for the female side of things. https://www.amazon.com/Type-Female-Receptacle-Breakout-Board/dp/B07771CFFM/ref=pd_bxgy_vft_med_img_sccl_2/137-8656501-6613113?pd_rd_w=5YN1B&content-id=amzn1.sym.26a5c67f-1a30-486b-bb90-b523ad38d5a0&pf_rd_p=26a5c67f-1a30-486b-bb90-b523ad38d5a0&pf_rd_r=E6MH61KVDG3QVJ9DAMFM&pd_rd_wg=WIG8G&pd_rd_r=bda83ae7-cbce-462b-8ddb-cbc7ee577fbd&pd_rd_i=B07771CFFM&psc=1
15 hours ago, VitusBering said:
The one I chose is a cable with male and female ends. I'll get a couple of them and cut the cables.
I plan to put a female end in the hull and another in the switch box.
Then any male-to-male usb cable should work to connect the two.
VitusBering, I think that will work for me just fine. Thank you for the info!- Dave_E and VitusBering
- 2
On 4/27/2023 at 9:26 AM, VitusBering said:
How are you planning to get power through the hull for lighting?
VitusBering, well…to be honest, I’m still looking for something. I need 9 contacts for my lighting plan, so even an RJ45 is too small. I like your idea of the usb-c connector. If I’m not mistaken, that supports 24 contacts/wires. Where did you find both the male and female ends? Did you find the actual bare connectors or did you find a cable to splice in?
- Keith Black and Dave_E
- 2
Good evening mates, this weekends build is all about the last deck structure located on the foredeck, the chart room. OcCre did a number on this structure, it was never meant to have fixtures installed inside as the walls have to be installed at the same time as the ceiling/deck of the upper floor. Also, I had to do some filing on the windows as OcCre made them rectangle and they should have a curve on both the top and bottom. This would have been so easy to have built in with the laser cutting, but they didn’t. 😞 The lights for this structure will be two fold, the chart room will come on with the deck lights while the storage room, the aft 1/3 of this structure, will have its lights come on with either of one port hole switches or the second one or both. I hope it will be a nice touch.
The chart room consists of a bright blue floor, four chart storage standing desks with glossy wood tops, wood stained interior and almond white ceiling and aft wall…all matching the real Amerigo Vespucci.
- Mike Dowling, clearway, VitusBering and 4 others
- 7
Congratulations Keith!
- Keith Black, Mr Whippy and clearway
- 2
- 1
9 hours ago, jbcallender said:
Daniel, what is the makers/specs of the chainplates that you bought? I don't like the kit ones, either.
Good morning JeffC, I bought mine from Ages of Sail out of California, but they are an Amati product (AM4090/05) you can probably get from many places. https://www.agesofsail.com/ecommerce/fittings/rigging-fittings/deadeyes-chainplates/amati-chainplate-with-deadeye-5mm-am4090-05.html
Good evening mates, well, I think this will be the last update for this structure on the main deck as I think I’m finished enhancing it over the stock kit. For starters, this structure is only temporarily installed on the deck, but an important build at this time for the added lighting, both inside and out that needs to be working before enclosing the hull with planking. Besides the lighting, other enhancements include signage, improved railing, window glazing for the port holes and the skylights, added the door, added roof supports, megaphone speakers, and several paint adjustments to make it look more like the real AV.
- clearway, king derelict, Keith Black and 2 others
- 3
- 2
12 hours ago, Mike Dowling said:
Anyway my question is, when you paint your hull, will you paint it gloss, satin or matt ? I can't work out what the real ship is painted with, can you? I am having serious trouble getting the hull 'metal' smooth and I think gloss will show up every flaw?
Mike, I've been looking at the hull, starting to think how I plan to paint everything. To me it looks like a satin, not really glossy but not matt either. I'll probably paint with what I have and put a satin clear sealer on everything. At least, that's my plan for now...subject to change.
- Dave_E, Keith Black and Mike Dowling
- 3
- Dave_E, clearway, king derelict and 2 others
- 5
On 4/17/2023 at 6:47 AM, VitusBering said:
What brand / model of voltage regulators are those? There are dozens of choices on Amazon with subtle differences. Also, if you're so inclined, I'd like to know what LEDs you use and whether you added resistors to the leads. Thank you, and I love the work you've done so far.
Good morning VitusBering,
The voltage regulators that I used I purchased from Amazon (https://www.amazon.com/dp/B09L49XQYD?ref=ppx_yo2ov_dt_b_product_details&th=1) specifically because each regulator can tolerate up to 3 amps and is adjustable from 1.5v to 35v with an input capability of 3-40v. Currently I'm running everything on a single 9v battery, but in the end all of the regulators will be built into the stand and plugged into a 3 amp 12v power brick. As it turns out, I love the adjustability of these regulators because I am able to easily adjust the brightness of each channel, so the deck lights can be turned down to a dim illumination. I use 3mm 1.8-2.3 volt various colored LED's with resistors that came with the LED's matched for 6v running voltage for full brightness at 20mA. I'm currently running my deck lights at about 3 volts, enough to turn on the LED's but allowing them to be dim, just to cast enough light that the viewer is able to see that the lighting works. My calculations indicate that I should be able to run about 150 20mA LED's on each regulator, but in reality, I'll cap out around a 200 LED's total for the project across several regulators. I hope this helps!
UPDATE: More helpful information (I hope)...The output voltage maximum will be 1.5 volts lower then the input voltage. For example, an input voltage of 9v, as with a standard rectangle battery and the way I have it running at the moment, the maximum output voltage will be 7.5 volts thus making the adjustable voltage regulator operational from 1.5 to 7.5 volts in this configuration. My final version will be operated from a 12 volt 3 amp power brick, thus giving my operating output range from 1.5 to 10.5 volts. Since I'm rigging my ship to run on 6 volts, all the 3mm LED's and the 6 volt motor for the propeller, this adjustable voltage regulator works perfectly.
Given these specs, I can run a total of 400 LED's at full brightness (@ 20mA) and the 6 volt motor all on a 3 amp power brick. With my newest projected configuration for the lighting of this project, I anticipate around 200 LED's and the 6v motor...which allows for some power to spare. However, I really don't think everything will be on at the same time, but it could!
Final bit of information, if anyone is interested...Below is my temporary control panel which allows easy access to the output voltage adjustment. When finished and the voltages all set for the final model, I will build them all into the stand with just the switch visible with a nice description tag. Currently planned, 1) Deck Lighting - all the outside visible lights, mostly on the main deck, 2-3) Cabin Lights 1 and Cabin Lights 2, my plan is to be able to have two sets of port holes light up, one set with scattered lights or compartments that will have a realistic look of some port holes lit while others are dim, and the second set just the opposite giving me the ability to choose one or the other, or both to have all the port holes lit, 4) Night lighting which is what the Amerigo Vespucci is famous for, the Green, White and Red deck lighting that casts colored light up into the masts, 5) Marker Lights, you guessed it, the red (port), green (starboard), white/amber (stern) and the white lantern that sits on the Mizzen boom, 6) Emergency lighting - only a single red and a single flashing red emergency lighting located on the main deck (unless I discover that more exists on the AV), and last 6) the motor which is in the bowels' of the ship and will turn the single propeller at about 35 rpm, about 1 revolution every 2 seconds, really quite slow but don't want to injury someone. Well, that's the plan...we will see how it goes, but so far, so good.
Good evening mates, time for an update. This weekend I spent time with more lighting. This time on the small structure on the main deck. This structure is only temporarily placed, but I have everything working.
Also, while impossible to see in any of these images, I installed the window glazing on all the port holes and skylights (not sure what the nautical name is for these) of this structure. Just a little more work to do and this one is finished. -
Mike, I'll keep that in mind. Right now I'm so far away from planking...I have so much more lighting to get finished, but now that the deck is completed, there should be rapid visual progress forthcoming.
- 2
8 hours ago, Mike Dowling said:
I have spent some time trying to decide whether to do the second planking or leave it as it is. I just can't make my mind up. The instructions say to do a second layer and then smother it in filler before final sanding. But if the first layer is ok and the hull is going to be painted any way what do you think?
Well, I guess this is a personal decision for the AV. Since it has a metal hull, our attempt is to plaster the wood and make it look like metal. So a second layer is probably not necessary. I’ll probably add the second layer because the two other models I built, some areas sanded to get a smooth finish thinned out making the wall somewhat transparent with bright lighting inside. So I was glad to add the second layer. Not sure how this one will turn out.
- 3
Do you not think it a bit of a risk putting fittings on the deck before the hull planking? I would be afraid of knocking them off/breaking them.
Mike, the equipment is only temporarily mounted, with a 1mm rod mounted into the bottom of each piece and drilled into the deck. Just a little twist and the pieces come off. I won’t have them in place when doing the planking. I have lighting that I need to place, not in the way of the equipment, and I have to have lighting and wiring all working before doing the hull as once the planking is done, no more access to the wires.
- Keith Black, Dave_E and clearway
- 3
Good evening everyone, it’s been a while since my last post. This week I was working on the fore deck with all the extra Amerigo Vespucci inspired inlay. I’m happy with the final product and started to temporarily place the deck hardware. To hold each piece of equipment in place I’m adding a 1mm post to the bottom each piece and drilling a hole in the deck for placement. So far, it’s all working well. Thanks for spending a little time with me on this journey.
- Dave_E, Mike Dowling, clearway and 1 other
- 4
- Dave_E, clearway and Keith Black
- 3
1 hour ago, Dave_E said:
What is that and how does it work?
I really have no idea; however, from the hint Keith gave, I did some research. It appears that a “scuttle” can be a type of water proof hatch, use for various tasks, one of which can be escape. Other uses I found include loading coal, diesel or food and even be opened for ventilation. I presume that the hatch opens in some way allowing direct access to the deck below and easy loading/unloading of supplies. Also, it appears that scuttles can be installed on the side of the ship as well, but they are more commonly called…a port hole.
- clearway, Keith Black and Dave_E
- 3
Amerigo Vespucci by DanielD - OcCre - 1:100
Good evening mates, another side marker update, both sides finished. Will get lighting working this weekend. Then on to the next lighting task.
