DanielD
Everything posted by DanielD
  1. Time for another update mates, but really not a lot of visual progress. I have finished the rain gutters on each and every porthole! I have included a couple close shots to visualize the difference. i used 0.5mm brass wire and shaped around a proper sized drill, cut to achieve the look on the AV, then glued in place with very thin CA glue, wicking up the excess with a paper towel. I thought that would be it; however, when I looked close at my installation, I realized it looked like I glued on a piece of wire. Next I sanded each gutter to flatten the edge so it looked more realistic. A few more attachments for the hull, then another round of primer before paint. Before sanding, just the wire rain gutter. After sanding, a more square look.
  2. Mike, I do plan on installing sails; however, this time around I’m planning on furled sails as I’m planning on a spectacular night light display, and…I’ve never done furled sails before (experience). My last ship, HMS Terror by OcCre I hand made my sails. It’s a lot of work, satisfying, but…did I mention it’s a lot of work.
  3. Good morning mates, it's been awhile since my last post. I have been busy out in the yard, so little time in the shipyard. However, I have been trouble shooting a recent issue... Last week, I was demonstrating the ships lighting features to a visitor and then turned on the motor for the screw. It ran for about two seconds then stopped! I checked the voltage, the wiring, everything external that I could check, and still nothing. I was feeling a bit disheartened as at this point there is no way to get to the motor it's self. Last night I was looking over the model, a bit frustrated, just toggling on/off the button for the motor, when it all of the sudden started working again! Here is what I think is happening. The unit I used is a geared motor so that the revolutions are about 30 per minute (don't want to hurt anyone). In this particular device, the gears are exposed and I did not take steps to protect the gears. As you can see above, the Amerigo Vespucci has a ton of port holes that have to be drilled in through the hull. This will unavoidably cause wood chips to enter into the hull. I believe that one of these small chips temporarily was wedged into the gears of the motor, which stopped it from working. At least that's all I can think of as the wiring is well secured and not likely a problem. Lesson learned, the next time I use this motor in a ship where I won't be able to access the engine compartment, I will take steps to protect the exposed gears. Oh well, all is now as it should be. UPDATE: I have completed the port hole rain gutters on the starboard side and now mass producing the ones for the port side. Should have some visual updates later this weekend.
  4. Good evening mates, no progress on the AV today, but I did take a couple of low light shots that better show lighting effect.
  5. And…another project I’ve been thinking about and working on, the rain gutters which my wife calls the eyebrows 😊. I have the look I’m striving for, now to make a jig so I can produce exactly the same part, 174 times.
  6. One problem I encountered when installing the “square” portholes is getting them to sit flush with the side of the ship. As you can see from an image blow up, these portholes should be flush, but the kit supplied metal pieces are instructed to be just be stuck to the side. However, the initial pieces are 2mm thick and just didn’t look good sitting on the surface of the hull, and I wanted them to light up along with the other portholes. I ended up grinding each tiny piece down to 0.5mm thick, then carving into the 0.5mm second planking so they inset into the hull to get a nearly flush detail look.
  7. Good weekend mates, I just realized that it’s been a while since my last update, but we have been busy with outside projects. Regardless, I’m still making some progress on the AV. In this update, I have completed installing all the port holes, both the round and square versions, and happy to report that I have been able to get the lighting to work on all except one porthole on each side at the bow which is directly over a large area of bow support, so no lighting in that area. Still, I’m very pleased with the outcome. Quick refresher, the goal of my porthole lighting is to simulate a real life night scenario (first image), where not all the portholes are lit at the same time. I have two versions of lighted portholes, which I can have one or the other set lit, or can have both on which lights all of the portholes.
  8. Hi Mike, the instructions are indeed a little vague. The one image that shows a 20mm spacing could imply 20mm between each port hole, but according to the 1:1 drawing, the spacing is not equal the entire length of the ship. So, like you, I measured each one from a zero reference point. I picked the left most port hole on the bow 1:1 drawing as my zero point, then measured each hole from there. I have the bottom row of port holes to finish later tonight, then see what I can do about the square openings. I want to inset the metal piece that came with the kit so that it is basically flush with the hull, or maybe be extended 1/2 mm like the brass fittings that act as port holes. Ideally, both the port holes and the square hatches should be flush with the hull, but I'm not getting nice clean holes so the brass grommet is needed. Once I have all the port holes fitted, I'll prime everything one more time, the paint the entire hull white, let dry, mask off the white stripes, pain everything black, let dry, mask off everything except the yellow/gold and paint that, lastly masking off everything except the green bottom. There have been a couple of painting schemes over the years with a red bottom, a black bottom and a dark green. I like the green, so that is what I have planned.
  9. Good evening mates, time for another update. Today, working on the starboard port holes and learning that all the planning in the lighting seems to be working. There are three settings for the port hole lighting, 1) some portholes lit, 2) the opposite portholes lit, and 3) all on. The images below show the plan come to fruition.
  10. Good afternoon mates, todays update is sponsored by…sorry, got carried away. I was able to finish the second planking, fill most of the seams and wood grain, and have the primer/sealer airbrushed on. Now have to let sit for 24 hours or so to let primer cure. But progress is progress.
  11. I love your ability to make the plastic look wood real and weathered! Great job.
  12. Good evening mates, time for another hull update. I have to say I have discovered my favorite way to adhere the second layer of planking! Okay, I didn’t”discover” this method, but it is the first time I have used it, and might I say it was glorious. The method I’m speaking of is what OcCre calls for in the instructions, using contact cement. Using this method one applies the rubber like glue to both surfaces, wait until it dries, then press the two pieces together with pressure for an immediate permanent adhesion. What I loved about contact cement, it was not messy, was dry while I set the pieces in place and was quick (immediate) adhesion, like CA glue without the mess. What I didn’t like was the smell. The admiral sent me to the garage for this task with the outside door open, you know, good ventilation per the instructions. I’m very pleased with the results. Only the starboard side done, but good progress.
  13. Good evening mates, another hull update. I have finished the first planking layer, sanded, filled some cracks, sanded again and now it’s ready for the second and final plank layer. After all the pounding, gluing, and sanding, I’m happy to report that all the electrical still works! Now to figure out the best adhesive to adhere the thin planks. I have used PVA and CA glue in the past. Both are messy. The PVA glue is more wet and warps the thin planks and is fairly slow drying so slow progress with the time I have to work on project. CA glue is fast, but makes the wood hard and difficult to sand and in this case I need to sand, fill, and repeat until very smooth to simulate a metal finish.. The instructions call for contact cement. Coat the hull and a few planks, let dry, and press into place for a permanent adhesion. I’ve never tried this method…anyone have experience with this contact cement? Clearway suggested Evo-stick fast setting wood glue, which may work, but still takes an hour ish to set and I only have an hour or so a few nights a week to work in the ship yard, so this might be too slow to make good progress. Other ideas appreciated.
  14. Good evening mates, another hull update. I have the main hull first planking basically finished with a few angled planks to manufacture and set, but the hard part is finished.
  15. Good evening everyone, time for another update. Still working on the first planking layer, but working both sides equally to prevent hull warping. If you look closely, you can see the USB-C plug to get power on board for all the lighting and motor.
  16. Hi Keith, good to hear from you. I do plan to use the kit supplies second planking as the Amerigo Vespucci is a metal hulled ship so the quality of wood I use is not critical. I will have to fill in any imperfections and sand very smooth and paint with filler primer, sand again, paint again, then add the detail rivets and supports all before final paint. A slow process for sure. Daniel
  17. Good afternoon mates, thought I would make a quick update. I finally have all the lighting and associated wiring finished and secured. Today I started laying down the first layer of planking. So far, going as planned, but it sure is tedious slow work.
  18. VitusBering, that is a very good question and the answer is yes/no. Let me explain, (No) I am not planning on having any capability to replace a LED. But, (Yes) 1) I am taking steps to protect the LEDs by making sure they all are matched with resisters to protect from overloading the LED, 2) I am running less voltage and thus leas than the maximum current so LED is not likely to fail, and 3) I am using voltage regulators that relatively slowly go from zero to maximum set voltage so as to not shock the LED. Basically, I should get 30+ years or more out of the lighting based on how often I will actually have the display on. If a LED goes out, I can evaluate based on location if it’s even worth it to fix. For example, the night up lighting is important for the look of the ship (the green, white, red look of the Italian flag) and those are easy to access and replace. The LEDs inside the structures or in the hull, I doubt if anyone besides me will notice.
  19. Mike, at the time, I was talking about the bow anchors. Indeed the AV has 3 bow anchors, one on the port side and two on the starboard. In addition, the AV also has one anchor on either side of the stern for a total of five. Here are the pictures that I quickly found that show all of them.
  20. Good evening mates, it’s been awhile since my last post, not because I haven’t been working on the AV, but because what I’ve been working on is not visual progress. I’ve been working on the last major lighting project that I have planned for my Amerigo Vespucci, the port hole lighting. My goal is to attempt to light the lower decks similar to what occurs in real life, meaning, not all the lower deck lights will be on at the same time (see image below). My plan is to light two sets of port holes. I can have one set on, or the second set, or if I choose, both sets which will light all of the port holes. I am planning on some deck planks between each set of lights to prevent light bleeding from one level to the next…just not made it that far yet. Thanks for stopping by.
  21. I used the same number as in the real AV, but it was just yesterday I noticed that there is a red light at the top of each mast…not sure how I want to handle that 🤔
  22. Good evening everyone, thanks for stopping by. In this episode, I have finished or nearly finished the night green-white-red up-lighting the AV is famous for. Hard to see without any of the mast hardware, but I am getting light up to the top of each mast.
